Hi thanks, i was able to get it working be sending a trigger node with the command twice
somehow it works
but looks like a workaround…
i am also sending Command , i am still not clear why the magic home Binding\Controller the dimmer value has is own life , but i was able to get it to work
Code for NR
[{"id":"9a33bd66.ccbcd","type":"subflow","name":"Color to Number(LED)","info":"","category":"","in":[{"x":140,"y":280,"wires":[{"id":"a7caabeb.b06d98"}]}],"out":[{"x":635.3332901000977,"y":188.6666693687439,"wires":[{"id":"29f069a9.72dc36","port":0},{"id":"289fca31.d499b6","port":0},{"id":"58ac06d2.ed39f8","port":0},{"id":"9d2f1c21.0c204","port":0},{"id":"a5792872.bd9aa8","port":0},{"id":"6f462838.d07f48","port":0},{"id":"6e7ee828.f19d38","port":0}]},{"x":1120,"y":320,"wires":[{"id":"c28b5e7b.f3726","port":0}]}],"env":[]},{"id":"a7caabeb.b06d98","type":"switch","z":"9a33bd66.ccbcd","name":"","property":"payload","propertyType":"msg","rules":[{"t":"cont","v":"Blue","vt":"str"},{"t":"cont","v":"Turkiz","vt":"str"},{"t":"cont","v":"Yeloow","vt":"str"},{"t":"cont","v":"Red","vt":"str"},{"t":"cont","v":"Green","vt":"str"},{"t":"cont","v":"White","vt":"str"},{"t":"cont","v":"Cops","vt":"str"}],"checkall":"true","repair":false,"outputs":7,"x":290,"y":280,"wires":[["29f069a9.72dc36"],["289fca31.d499b6"],["58ac06d2.ed39f8"],["9d2f1c21.0c204"],["a5792872.bd9aa8"],["6e7ee828.f19d38"],["6f462838.d07f48"]]},{"id":"29f069a9.72dc36","type":"change","z":"9a33bd66.ccbcd","name":"blue","rules":[{"t":"set","p":"payload","pt":"msg","to":"40","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":430,"y":80,"wires":[[]]},{"id":"289fca31.d499b6","type":"change","z":"9a33bd66.ccbcd","name":"turkiz","rules":[{"t":"set","p":"payload","pt":"msg","to":"42","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":430,"y":120,"wires":[[]]},{"id":"58ac06d2.ed39f8","type":"change","z":"9a33bd66.ccbcd","name":"yeloow","rules":[{"t":"set","p":"payload","pt":"msg","to":"41","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":440,"y":160,"wires":[[]]},{"id":"9d2f1c21.0c204","type":"change","z":"9a33bd66.ccbcd","name":"red","rules":[{"t":"set","p":"payload","pt":"msg","to":"37","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":430,"y":200,"wires":[[]]},{"id":"a5792872.bd9aa8","type":"change","z":"9a33bd66.ccbcd","name":"Green","rules":[{"t":"set","p":"payload","pt":"msg","to":"39","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":430,"y":240,"wires":[[]]},{"id":"6f462838.d07f48","type":"change","z":"9a33bd66.ccbcd","name":"Cops","rules":[{"t":"set","p":"payload","pt":"msg","to":"46","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":850,"y":320,"wires":[["c28b5e7b.f3726"]]},{"id":"c28b5e7b.f3726","type":"trigger","z":"9a33bd66.ccbcd","op1":"96","op2":"96","op1type":"str","op2type":"str","duration":"8","extend":false,"units":"s","reset":"","bytopic":"all","name":"","x":980,"y":320,"wires":[[]]},{"id":"6e7ee828.f19d38","type":"change","z":"9a33bd66.ccbcd","name":"White","rules":[{"t":"set","p":"payload","pt":"msg","to":"44","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":430,"y":280,"wires":[[]]},{"id":"bb5be404.3bdd58","type":"mqtt in","z":"769a52c2.f1db8c","name":"","topic":"/ledStrip","qos":"2","datatype":"auto","broker":"b31d9a1b.fc5e78","x":180,"y":1400,"wires":[["2ba58c68.ae2174"]]},{"id":"8d8b7378.99d04","type":"openhab2-out","z":"769a52c2.f1db8c","name":"LED Strip PC OFF","controller":"e7fc0463.749968","itemname":"PCLed_Power","topic":"ItemCommand","payload":"OFF","x":1124,"y":1514,"wires":[[]]},{"id":"bbab9f1b.3a7ab","type":"openhab2-out","z":"769a52c2.f1db8c","name":"LED Strip PC ON","controller":"e7fc0463.749968","itemname":"PCLed_Power","topic":"ItemCommand","payload":"ON","x":1330,"y":1560,"wires":[[]]},{"id":"9a246d58.6f0f9","type":"delay","z":"769a52c2.f1db8c","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1140,"y":1560,"wires":[["bbab9f1b.3a7ab"]]},{"id":"42020ec7.d9d6b","type":"delay","z":"769a52c2.f1db8c","name":"","pauseType":"delay","timeout":"2","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1160,"y":1606,"wires":[["db9a259f.778758"]]},{"id":"4047bdf5.840394","type":"openhab2-out","z":"769a52c2.f1db8c","name":"LED Strip PC Prog","controller":"e7fc0463.749968","itemname":"PCLed_Program","topic":"ItemCommand","payload":"","x":1610,"y":1600,"wires":[[]]},{"id":"4f89c331.21531c","type":"function","z":"769a52c2.f1db8c","name":"","func":"\nreturn msg;","outputs":1,"noerr":0,"x":850,"y":1600,"wires":[["5015bdb4.3d5294","8d8b7378.99d04","717694ca.80adec"]]},{"id":"db9a259f.778758","type":"subflow:9a33bd66.ccbcd","z":"769a52c2.f1db8c","name":"","env":[],"x":1360,"y":1606,"wires":[["4047bdf5.840394"],["e2b26ca.014da9"]]},{"id":"812440b.78b74c","type":"switch","z":"769a52c2.f1db8c","name":"PC Strip","property":"payload","propertyType":"msg","rules":[{"t":"cont","v":"PC","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":680,"y":1600,"wires":[["4f89c331.21531c"]]},{"id":"f94994ed.c6f848","type":"openhab2-out","z":"769a52c2.f1db8c","name":"LED Strip Saloon OFF","controller":"e7fc0463.749968","itemname":"SaloonLED_Power","topic":"ItemCommand","payload":"OFF","x":1144,"y":1660,"wires":[[]]},{"id":"df134b56.023398","type":"openhab2-out","z":"769a52c2.f1db8c","name":"LED Strip Saloon ON","controller":"e7fc0463.749968","itemname":"SaloonLED_Power","topic":"ItemCommand","payload":"ON","x":1340,"y":1706,"wires":[[]]},{"id":"53fd4eeb.fb074","type":"delay","z":"769a52c2.f1db8c","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1146,"y":1706,"wires":[["df134b56.023398"]]},{"id":"bf71bc67.808db","type":"delay","z":"769a52c2.f1db8c","name":"","pauseType":"delay","timeout":"2","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1160,"y":1747,"wires":[["81f9b0c7.948fa"]]},{"id":"1c1537e2.1750c8","type":"openhab2-out","z":"769a52c2.f1db8c","name":"LED Strip Saloon Prog","controller":"e7fc0463.749968","itemname":"SaloonLED_Program","topic":"ItemCommand","payload":"","x":1620,"y":1742,"wires":[[]]},{"id":"1567f9fd.ba2616","type":"function","z":"769a52c2.f1db8c","name":"","func":"\nreturn msg;","outputs":1,"noerr":0,"x":850,"y":1744,"wires":[["f94994ed.c6f848","7f7e6b76.bc84e4","9cc94d1c.24c94"]]},{"id":"81f9b0c7.948fa","type":"subflow:9a33bd66.ccbcd","z":"769a52c2.f1db8c","name":"","env":[],"x":1360,"y":1748,"wires":[["1c1537e2.1750c8"],["1acdec.2c596215"]]},{"id":"758a23c2.b2b6fc","type":"switch","z":"769a52c2.f1db8c","name":"Saloon Strip","property":"payload","propertyType":"msg","rules":[{"t":"cont","v":"Saloon","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":690,"y":1744,"wires":[["1567f9fd.ba2616"]]},{"id":"c5082ad2.e91d08","type":"openhab2-out","z":"769a52c2.f1db8c","name":"LED Strip Bed OFF","controller":"e7fc0463.749968","itemname":"WiFiLED_Power","topic":"ItemCommand","payload":"OFF","x":1150,"y":1819,"wires":[[]]},{"id":"4bb26d8c.0d9df4","type":"openhab2-out","z":"769a52c2.f1db8c","name":"LED Strip Bed ON","controller":"e7fc0463.749968","itemname":"WiFiLED_Power","topic":"ItemCommand","payload":"ON","x":1341,"y":1861,"wires":[[]]},{"id":"c97b728f.b969c","type":"delay","z":"769a52c2.f1db8c","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1140,"y":1861,"wires":[["4bb26d8c.0d9df4"]]},{"id":"917e7e27.dcc26","type":"delay","z":"769a52c2.f1db8c","name":"","pauseType":"delay","timeout":"2","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1160,"y":1906,"wires":[["5323859a.bb0ccc"]]},{"id":"4f635e2f.7d99e","type":"openhab2-out","z":"769a52c2.f1db8c","name":"LED Strip Bed Prog","controller":"e7fc0463.749968","itemname":"WiFiLED_Program","topic":"ItemCommand","payload":"","x":1610,"y":1900,"wires":[[]]},{"id":"d9d26da2.b53f5","type":"function","z":"769a52c2.f1db8c","name":"","func":"\nreturn msg;","outputs":1,"noerr":0,"x":836,"y":1899,"wires":[["c5082ad2.e91d08","762b62ea.e388bc","b36e46.cefbe1b8"]]},{"id":"5323859a.bb0ccc","type":"subflow:9a33bd66.ccbcd","z":"769a52c2.f1db8c","name":"","env":[],"x":1380,"y":1906,"wires":[["4f635e2f.7d99e"],["ed197ff6.2b414"]]},{"id":"8f08580c.64e258","type":"switch","z":"769a52c2.f1db8c","name":"Bed Strip","property":"payload","propertyType":"msg","rules":[{"t":"cont","v":"Bed","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":660,"y":1899,"wires":[["d9d26da2.b53f5"]]},{"id":"43e92fba.82edf","type":"openhab2-out","z":"769a52c2.f1db8c","name":"LED Strip Kitchen OFF","controller":"e7fc0463.749968","itemname":"KitchenLED_Power","topic":"ItemCommand","payload":"OFF","x":1172,"y":1980,"wires":[[]]},{"id":"97375814.36bdd8","type":"openhab2-out","z":"769a52c2.f1db8c","name":"LED Strip Kitchen ON","controller":"e7fc0463.749968","itemname":"KitchenLED_Power","topic":"ItemCommand","payload":"ON","x":1348,"y":2020,"wires":[[]]},{"id":"3b501fdf.e0b45","type":"delay","z":"769a52c2.f1db8c","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1148,"y":2020,"wires":[["97375814.36bdd8"]]},{"id":"c80a56c9.128418","type":"delay","z":"769a52c2.f1db8c","name":"","pauseType":"delay","timeout":"2","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1160,"y":2060,"wires":[["c2a94eb.22d46b"]]},{"id":"a456047.34400f8","type":"openhab2-out","z":"769a52c2.f1db8c","name":"LED Strip Kitchen Prog","controller":"e7fc0463.749968","itemname":"KitchenLED_Program","topic":"ItemCommand","payload":"","x":1638,"y":2053,"wires":[[]]},{"id":"850608e7.6c9318","type":"function","z":"769a52c2.f1db8c","name":"","func":"\nreturn msg;","outputs":1,"noerr":0,"x":836,"y":2054,"wires":[["ca9a3724.4e3938","43e92fba.82edf","79d03ed5.7389a"]]},{"id":"c2a94eb.22d46b","type":"subflow:9a33bd66.ccbcd","z":"769a52c2.f1db8c","name":"","env":[],"x":1360,"y":2060,"wires":[["a456047.34400f8"],["9550d9f9.79d458"]]},{"id":"35875f7a.21886","type":"switch","z":"769a52c2.f1db8c","name":"Kitchen Strip","property":"payload","propertyType":"msg","rules":[{"t":"cont","v":"Kitchen","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":670,"y":2054,"wires":[["850608e7.6c9318"]]},{"id":"4488937c.7c7a9c","type":"switch","z":"769a52c2.f1db8c","name":"ALL","property":"payload","propertyType":"msg","rules":[{"t":"cont","v":"LEDS","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":490,"y":1400,"wires":[["11283bbc.ab7e24","4f89c331.21531c","9492385.3c43dc8","5b2c45e6.8d305c"]]},{"id":"2ba58c68.ae2174","type":"function","z":"769a52c2.f1db8c","name":"","func":"\nreturn msg;","outputs":1,"noerr":0,"x":310,"y":1400,"wires":[["4488937c.7c7a9c","812440b.78b74c","8f08580c.64e258","35875f7a.21886","758a23c2.b2b6fc"]]},{"id":"11283bbc.ab7e24","type":"delay","z":"769a52c2.f1db8c","name":"","pauseType":"delay","timeout":"250","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":710,"y":1680,"wires":[["1567f9fd.ba2616"]]},{"id":"9492385.3c43dc8","type":"delay","z":"769a52c2.f1db8c","name":"","pauseType":"delay","timeout":"500","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":710,"y":1820,"wires":[["d9d26da2.b53f5"]]},{"id":"5b2c45e6.8d305c","type":"delay","z":"769a52c2.f1db8c","name":"","pauseType":"delay","timeout":"750","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":710,"y":1980,"wires":[["850608e7.6c9318"]]},{"id":"e2b26ca.014da9","type":"delay","z":"769a52c2.f1db8c","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1580,"y":1674,"wires":[["d9158acc.ec3318"]]},{"id":"d9158acc.ec3318","type":"openhab2-out","z":"769a52c2.f1db8c","name":"LED Strip PC Prog Speed","controller":"e7fc0463.749968","itemname":"PCLed_ProgramSpeed","topic":"ItemCommand","payload":"","x":1770,"y":1674,"wires":[[]]},{"id":"1acdec.2c596215","type":"delay","z":"769a52c2.f1db8c","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1580,"y":1826,"wires":[["e4963c20.44cb5"]]},{"id":"e4963c20.44cb5","type":"openhab2-out","z":"769a52c2.f1db8c","name":"LED Strip Saloon Prog Speed","controller":"e7fc0463.749968","itemname":"SaloonLED_ProgramSpeed","topic":"ItemCommand","payload":"","x":1790,"y":1826,"wires":[[]]},{"id":"ed197ff6.2b414","type":"delay","z":"769a52c2.f1db8c","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1580,"y":1980,"wires":[["dfef198e.503bb8"]]},{"id":"dfef198e.503bb8","type":"openhab2-out","z":"769a52c2.f1db8c","name":"LED Strip Bed Prog Speed","controller":"e7fc0463.749968","itemname":"WiFiLED_ProgramSpeed","topic":"ItemCommand","payload":"","x":1780,"y":1980,"wires":[[]]},{"id":"9550d9f9.79d458","type":"delay","z":"769a52c2.f1db8c","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1588,"y":2138,"wires":[["828da50c.3bba08"]]},{"id":"828da50c.3bba08","type":"openhab2-out","z":"769a52c2.f1db8c","name":"LED Strip Kitchen Prog Speed","controller":"e7fc0463.749968","itemname":"KitchenLED_ProgramSpeed","topic":"ItemCommand","payload":"","x":1798,"y":2138,"wires":[[]]},{"id":"5015bdb4.3d5294","type":"switch","z":"769a52c2.f1db8c","name":"","property":"payload","propertyType":"msg","rules":[{"t":"cont","v":"Off","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":1009,"y":1554,"wires":[[],["9a246d58.6f0f9"]]},{"id":"7f7e6b76.bc84e4","type":"switch","z":"769a52c2.f1db8c","name":"","property":"payload","propertyType":"msg","rules":[{"t":"cont","v":"Off","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":1010,"y":1699,"wires":[[],["53fd4eeb.fb074"]]},{"id":"762b62ea.e388bc","type":"switch","z":"769a52c2.f1db8c","name":"","property":"payload","propertyType":"msg","rules":[{"t":"cont","v":"Off","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":1010,"y":1855,"wires":[[],["c97b728f.b969c"]]},{"id":"ca9a3724.4e3938","type":"switch","z":"769a52c2.f1db8c","name":"","property":"payload","propertyType":"msg","rules":[{"t":"cont","v":"Off","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":1011,"y":2013,"wires":[[],["3b501fdf.e0b45"]]},{"id":"9cc94d1c.24c94","type":"switch","z":"769a52c2.f1db8c","name":"","property":"payload","propertyType":"msg","rules":[{"t":"cont","v":"Off","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":1010,"y":1740,"wires":[[],["bf71bc67.808db"]]},{"id":"79d03ed5.7389a","type":"switch","z":"769a52c2.f1db8c","name":"","property":"payload","propertyType":"msg","rules":[{"t":"cont","v":"Off","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":1010,"y":2053,"wires":[[],["c80a56c9.128418"]]},{"id":"b36e46.cefbe1b8","type":"switch","z":"769a52c2.f1db8c","name":"","property":"payload","propertyType":"msg","rules":[{"t":"cont","v":"Off","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":1010,"y":1899,"wires":[[],["917e7e27.dcc26"]]},{"id":"717694ca.80adec","type":"switch","z":"769a52c2.f1db8c","name":"","property":"payload","propertyType":"msg","rules":[{"t":"cont","v":"Off","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":1010,"y":1600,"wires":[[],["42020ec7.d9d6b"]]},{"id":"b31d9a1b.fc5e78","type":"mqtt-broker","z":"","name":"Node red","broker":"192.168.1.103","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"e7fc0463.749968","type":"openhab2-controller","z":"","name":"openhab","protocol":"http","host":"localhost","port":"8080","path":"","username":"","password":""}]
thanks for the help
