Node-Red on OH3
Correct! I managed as well to get it working. Steps taken:
  • from openhabian install nodered including openhab specific nodes
  • create an api token in OH, use this as username in the config node
  • done!
If not, check you are on version 1.1.8 from the OH node (you can find this in the pallette). If not, reinstall nodered from the openhabian menu.
