I “only” want to switch my Intertechno actors.
For that, I want to use a Transmitter like explanined here.
I installed WringPi and Raspberry-remote.
Wenn I paste th code
When you copy paste this line you have to either be in the directory which contains send or specify the full path.
The tutorial is sequentially, so you have to follow it step by step. Which would have placed you in the right directory. As you compile send before testing.
[13:24:12] openhabian@openHABianPi:~$ cd SourceCode
[13:24:14] openhabian@openHABianPi:~/SourceCode$ cd 433Utils/RPi_utils
[13:24:30] openhabian@openHABianPi:~/SourceCode/433Utils/RPi_utils$ make send
make: *** No rule to make target '../rc-switch/RCSwitch.o', needed by 'send'. Stop.
Think it would probably run…
But my plugs are selflearning (IT-1500), so they have got 26 Bits.
Like explained here.
I tried to send the code:
is01010010101011101000000110010011
But the answer is:
Sending 433 MHz remote plug control codes, hardcoded on wiringpi pin 0.
Usage: ./send <systemCode> <unitCode> <command> [pulseLength]
systemCode - First five settings of Type A 10 pole DIP switch, e.g. 11111
unitCode - Switch number [1 .. 5] or [10000 .. 00001]
command - 0 for OFF and 1 for ON
pulseLength - optional pulse length
I don´t understand the Intertechno Binding either, because there is no explanation for noobs - how ever
