Not all Tabs are shown in Add-ons Menu
  • Platform information:
    • Hardware: Raspberry Pi 3 B
    • OS: Debian strech
    • Java Runtime Environment: Java™ SE Runtime Environment (build 1.8.0_65-b17)
    • openHAB version: 2.2.0
  • Issue of the topic: In the Add-ons Menu in Paper UI not all Tabs are shown. Only “Bindings”, “Misc”, and “Voice” are shown. “User Interfaces”, “Persistence”, “Actions”, and “Transformations” are missing.
What did you choose as the package when first setting up OH?
I did a package repository installation from openHAB 2 Stable Repository.
What I mean is when you first opened up the dashboard after first installing, what did you choose? Demo, Simple, Expert, etc.
I could not remeber what I did choose, but I found it in OPENHAB_USERDATA/etc/org.openhab.addons.cfg. It says ‘package = simple’.
That explains it. When you choose simple a default set of addons in each of those categories are installed and those categories are removed as part of the simplification.
I think you can change it in services/system.cfg or maybe addons.cfg
The comments list the valid options I think.
Thank you very much! Setting ‘package = standard’ in services/addons.cfg solved the problem.
