Both have suddenly given me errors. For NTP it’s: Offline: Communication Error. The timeserver hostname 0.pool.ntp.org is unknown → returning current sytem time instead.
For Yahoo Weather it’s: The Yahoo Weather API is not available for the location xxxxxx.
Duh I feel dumb now. Turns out one of my network adapters had removed its static configuration, so once I set that back up, restarted OH2, back to working. And here I thought it might have been something to do with the binding instead…
Look in event.log and verify that it actually isn’t changing.
Get a second opinion and look at the CPU temp using some opther program.
If indeed that item isn’t being refreshed as it should, put the systeminfo binding into debug or trace logging to see if you can find out anything useful.
With logs in hand, file an issue on the binding if necessary.
