If you enter
system:property
on the karaf console, what results do you see for
user.country=
user.language=
This is what I’d expect the formatter to use
user.country=DE
user.country.format=CA
user.language=de
user.language.format=en
strangely there is something .format which i have no idea where to change/how?
humm, looks like the culprit. I had not thought of “sub-settings” at work. The .format
version will be used by the formatter only. Seems unlikely it got randomly set to CA. Sorry I do not how to alter, or better remove, these settings. Maybe something in ...openHAB/runtime/bin/setenv
thanks to your hint i was able to find where it is driven
so
user.country=DE
user.language=de
are from /etc/default/locale -> LC_MESSAGE
are used from /etc/default/locale -> LANG
so yeah, messed up locales, but ironically messed up by openhabian-config tool
Sneaky. What was fix, just edit the offending lines, remove them, or re-run the tool?
No openhabian here, presumably why I have no user.xxx.format
system settings (and formatter will use the base settings)
fix is pretty easy, just manually update locale and because I want english console but EU numbers etc. I did:
- Edit /etc/locale.gen and make sure that both en_US.UTF-8 and regional eg. de_DE.UTF-8 are uncommented.
- Run “sudo locale-gen”
- Edit /etc/default/locale with this:
LANG=de_DE.UTF-8
LC_MESSAGES=en_US.UTF-8
- Reboot
fixed
and result from console is
user.country=US
user.country.format=DE
user.language=en
user.language.format=de
and btw OH 2.5 snapshot, dunno if that .format thing is in 2.4 as well
Reckon that would work with CA-en and CA-fr
Well spotted. Will implement as well.
well I think this should not depend on system locale but trully only on OH locale, as many of us are using linux machines as en_US preferably, but end-user apps like OH should act as system independed with their own lang settings
just my two cents ;]
Oookay … so you have a fairly technical non-standard requirement ; and you can achieve that with a technical solution.
Doesn’t sound like a reason to mess up other people’s defaults.
that is not requirement, that’s just general suggestion how it might be done.
it might be quite confusing (as was for me) when you configure OH locale properly but nothing really happends …
anyway again, only suggestion to think about eventually, if not no big deal really
I did leap to a conclusion that there was something unusual about your installation. So far as we know, it all works as advertised for other people. Mind you, maybe not many have home automation parameters in the thousands
I recon there is big chunk of people who have PVE on their roofs
Sure, but they might use kW or whatever.
In did this with little effect. Is this supposed to work with 2.4.0?
I dont see the .format properties.
dunno really, Iam running 2.5.1 snapshot and as @rossko57 pointed before it looks like it’s not part of 2.4
So, @kriznik you are not the only one.
I am running OH 2.5.5 in a Docker Container and i dont know how to change the country variable.
i tried the following in my docker-compose.yml
environment:
OPENHAB_HTTP_PORT: "8090"
OPENHAB_HTTPS_PORT: "8453"
EXTRA_JAVA_OPTS: "-Duser.country=DE"
EXTRA_JAVA_OPTS: "-Duser.timezone=Europe/Berlin"
but sadly that doesnt work. The Karaf Console always show “user.country=US”
any advice?
Just in case this is still relevant 2 years after your post: I had the same problem and managed to solve it. See here for a description of what I did.
Thanks for the hint! I actually switched from OH in a Docker Container to a dedicated Linux VM with openhabian because of a few USB-Forwarding problems. But I am sure you will still help people with your linked solution
Just in case you ever (have to / want to) change back: I’m not a pro, but OH can be run by now on docker with two USB devices (Z-Wave- and Wireless M-Bus-stick) pretty smoothly without major problems (but with the expected benefits of being on docker). There’s only one problem (related to a NRJavaSerial-bug) with the Z-Wave stick, which I managed to work around with hints in this thread.
