Odd behavior when upgrading Synology DSM running OH
You can try Delay Start [4.0.0.0;5.9.9.9].
Persistence works using an allow list. All Items listed get persisted. There is no way to say “all items but these”. Therefore you’d remove the default * line from the config and list all the items you want to persist. You can use Groups to make it less work. Design Pattern: Group Based Persistence However, given how persistence config works in MainUI in not sure that really does save much work anymore.
