I already use an own openhab cloud, but I don’t know how to connect it with google home without to register to google cloud. In the google home app, the openhab action always link to myopenhab.org, not to my own cloud domain.
Sorry I didn’t understand that you use something different from myopenhab!
I red a post about using a different cloud but the final conclusion was that is extremly complex, unfeaseable for the average user
Quick question: does current code include humidity value (thermostatHumidityAmbient ( Float 0-100) TAG )?
Dear Everyone!
Has someone encountered an error like this before?
I have added new lights to OH and I have unlinked OH from Google Home so that I can assign rooms to the new lights (I couldn’t find any other methods, because saying ‘sync openhab’ doesn’t add the lights in the app). Now I have all the lights in the app, assigned to rooms, but when I say to turn all all lights it says that it will turn on 2 lights (these 2 lights was exposed to Google Home before) and it says that ‘looks like the table light isn’t available right now’. However I didn’t have any lights which is named like this or something similar
Hi, I am unsucessfuly trying to connect add myOpenHab account to Google Home. When I try to do so, Google is authorized to myOpenHab account but in the Google Home app is I receive account not linked notification. I added supported tags to items exposed to myOpenHab cloud. Do I need to add the tag all items regardless the exposure to the myOpenHab?
Edit: I added Switchable or Lighting tag to all my items. Still not working.
This problem I had them my hue lights where reported as unavailable, in the hue app.
How this helps
Important note: If you are not able to link your myOpenHab account, make sure you have set openHab Cloude service in your configuration to remote access!
Hi all and thanks for the great job. I have a problem with a philips hue item. I’ve a lamp that I can turn on/off, dimmer and set color and a switch and two slides related to this lamp each one tagged as [“Lighting”]. The problem is that when I say: “Ok Google, turn on Lamp-name”, google assistant answers saying: “Ok, I will turn on 3 smart lights”. It seems that the switch and the two slides are recognized as 3 different smart lights. I have the items defined as follows:
Any suggest? Thanks.
Is it possible to disable the Google Home voice feedback? In my opinion it’s kind of annoying to hear it every time you’re interacting with OpenHAB via voice command.
For example if I turn on a light I only want the light to be turned on without my Google Home saying ‘OK, you’re light xy is now turned on’.
I have the same problem. Simpel Hue bulbs Number 100 can control in brightness (channel= brightness). The colorbulb 210 in brightness and color (channel= color) with [ “Lighting” ].
//Wohnzimmer Farblampe Ikea
Switch FF_LivingRoom_Light1_Toggle "Wohnzimmer Farblampe" <light> (FF_LivingRoom, FF_LivingRoom_AllLights, FF_LivingRoom_Decke_Lights, FF_AllLights, FF, Home, gLight) {channel="hue:0210:001788:2:color"}
Dimmer FF_LivingRoom_Light1_Dimmer "Wohnzimmer Farblampe Helligkeit" <light> (FF_LivingRoom, FF_LivingRoom_AllLights_dim, gLight) {channel="hue:0210:001788:2:color"}
Color FF_LivingRoom_Light1_Color "Wohnzimmer Farblampe" <light> (FF_LivingRoom, gLight) [ "Lighting" ] {channel="hue:0210:001788:2:color"}
Dimmer FF_LivingRoom_Light1_ColorTemp "Wohnzimmer Farblampe Farbtemperatur" <light> (FF_LivingRoom, gLight) {channel="hue:0210:001788:2:color_temperature"}
//Wohnzimmer einfache Lampe Ikea
Switch FF_LivingRoom_Light3_Toggle "Wohnzimmer 3" <light> (FF_LivingRoom, FF_LivingRoom_AllLights, FF_LivingRoom_Decke_Lights, FF_AllLights, FF, Home, gLight) {channel="hue:0100:001788:26:brightness"}
Dimmer FF_LivingRoom_Light3_Dimmer "Wohnzimmer 3" <light> (FF_LivingRoom, FF_LivingRoom_AllLights_dim, gLight) [ "Lighting" ] {channel="hue:0100:001788:26:brightness"}
But I can’t find any solution to control the Hue 220 color temperature bulbs in brightness and color temperature at once without creating 2 seperat Bulbs in Google Home.
Did anyone have a solution?
Is the openHab Google Home connection still beeing developed?
I as well as others seem to run into problems where Google home returns with an error when trying to sync the devices.
I ran into this problem a coupple of weeks ago, after I have changed some items.
I have been struggling ever since getting Google Home to sync again since, without success.
Last night I removed everything. All tags, removed the connection to openhab in Google Home app, as well as removed the Google application within myopenhab cloud. I rebooted my Rpi and tried to re-add the connection again. But now Google home wont connect to openhab cloud anymore.
Openhab cloud seem to add the connection, but Google Home comes up with an error and does not add the connection. (It tells me to check the connection, which hardly can be the problem, since I can enter openhab cloud just fine).
At this point I see no way to investigate the problem. I really could need some advice on how to troubble shoot this.
I´m using openhabian hasslefree openhab 2.3.0 stable on a Rpi.
Check the list of things that can cause issues in this post linked below. I also had problems start a few weeks ago when I removed the ooenhab device link in the app and now I can not link or sync if I have more than 5 tagged devices. It is like my firewall or the server fails to send/recieve more than 1 packet.
Thanks Matt. But I removed every single tags from my items. And still Google Home wont connect.
The link post, you mention something about a corrupted JSON database… That may be the problem. But, how to know, and better yet, how to fix?
One of the things mentioned in Skinah’s post is you must have at least one Item tagged or else Google Home won’t connect.
Ahh, I see number 5… Thanks Rich!
Will give it another try tonight.
Just tried again, adding a coupple of tags. Still the same problem.
Tried reboot Rpi as well as restart Google Home, still no luck.
If not using openhabian replace with the IP or host name of your server…
http://openHABianPi:8080/rest/items/
The cloud connector uses that link to fetch all your items from, so if the link does not work or comes back with rubbish output for an item it will need to be looked at. The cloud connector then passes the output onto the myopenhab.org server and then on to google.
If you still have problems, start your own thread.
Well…
I´m not really sure how to explain this, but it´s working again this morning.
Last night:
I´d split up my item file into several files.
I made 100% sure I only got one tag and it was 100% perfect.
I cleared cache and tmp.
I cleared all items using karaf console.
I rebooted several times.
I did NOT managed to get Google Home to connect even after several tries.
I then had an idea of installing the Homekit addon insted, since it uses the same tagging, (I have an iphone as well as android phone).
Homekit worked in first go, found openhab, connected and found this single items which had the [“Lighting”] tag. And it worked like a charm.
Then I added a tagging to a different item. But I couldn´t get Homekit to update. (I honestly don´t know how to, as I just use my iPhone for work, and nothing else. So I might have missed some options or something).
All of a sudden Homekit wouldn´t work any more. I tried remove it and add it again several times, but it just wouldn´t work.
I gave up.
Made a last reboot, and got off to bed.
When I got up this morning I thought I would give Google Home just a last try. And all of a sudden, Google Home connected and found two items without any problems.
And trust me, I have not changed anything while a sleep.
To be honeste, I think there is a need for this to be looked at in some way. This seems like it´s a kinda lottery with a random success, but mostly fails. And it´s way to difficult to dig into in case it´s not working.
Sorry i also get this cant update/connect
I use tagging on my Amazon echoes and then this should also be supported ?
