After I make the slightest change the openhab items become unavailable for family members. I need to delete them from the family member list and re-add them.
Afterwards voice match needs to be re-installed for those family members.
But this process is very painful as the voice match often doesn’t work when trying to activate after re-adding family members or it breaks the openhab items;again with voice control.
Strange thing is the app shows the items and do allow to control them despite the fact the home mini doesn’t
Does anyone else have this issue as well ? And what is the most efficient procedure to reactivate items for family members?
I guess you use the assistant in another language than english? I now in dutch there are users reporting the same issues. Maybe Google someday will fix this.
@aart Indeed using it in Dutch as well, so you’re saying this is a google issue not an openhab one. That’s good news as I expect google to be quite agile in fixing bugs
Hello all,
Since yesterday I have problem with Google Home synchronization. When I try several times it finally works but the items are not responding. Where can I debug what is wrong? I have the following items:
Dear @aart, @MARZIMA
On October 1 you wrote that “The Humidity is already in a fixed in a pull request.”
Latest updates include this tag? Could you check please?
I have thermostats with humidity values so looking for working TAG…
Maybe a stupid question but if I would run my own personal version of the openhab cloud service can I link that to google home/assistant and how would that work.
If I recall well the activation of openhab in google home was picking it from a long list of services and entering credentials but I don’t recall the option to enter a myopenhab url anywhere.
Yes, when I ask Google Assistant what the humidity in my living or any other room is I get an appropriate answer. As far as I know humidity isn’t shown anywhere on the thermostat graphic in Google Home if that is what you’re after.
Indeed it was I never thought of asking Google, when I couldn´t see the Humidity icon/something.. I simply assumed it wasn´t working. I wonder why there isn´t a humidity icon. Well, I also wondered why Hudimity had to be part of the Thermostat group.
I´ll give it a try (ask) later.. Thanks for letting me know.
Google Assistant stopped working for me I believe two days ago (Nov. 12). I’ve restarted the server a few times, and the openhab log shows no errors and indicates the cloud service is connecting fine. All openhab functions operate normally using the UI (and the event log/device status on myopenhab.org are updated appropriately using the UI). But when using Google Home, it responds with “sorry, I can’t reach openhab right now”.
It’s been working fine since the release of the integration, and I’ve made no openhab configuration changes for months. Any ideas? Thanks.
I have the same problem since monday evening. myopenhab.org shows “online” but I can’t open the sidemap over Remote-Url in Openhab and Openhab Beta Android-App or over the home.myopenhab.org Website. Google Assistant don’t work or switchs one of 5 lamps in a room.
In Lokal Network the Apps and Website works fine.
Is it only a Server Problem or can I do something on my Openhabian Installation?
I have dimmer and switch items and used [ “Lighting” ] for them and was able to say e.g. “turn lights off” and all the lighting items were switched off. Yesterday I changed my settings so that the switch items are [ “Switchable” ] and lights connected to plugs are [ “Outlet” ]. Problem is that saying “turn lights off” now only turns off the remaining [ “Lighting” ] items, not the switch or outlet
I found on Reddit that you can actually rename the items tagged with “switchable” or “outlet” to something like “Kitchen Light” (“Lumière cuisine” in French in my case) in Goggle Assistant and it will now also consider this outlet or switch as a lighting.
I don’t know if this has already been posted here but I just found that super cool
Hello, I m also having a connection issue since 2-3 days between google home and myopenhab ;
Symptom : google home is saying that it can’t contact openhab when I ask for an openhab action
Tests done :
Access myopenhab OK
Restart Openhab OK
Ask google home to synchronize → google home is saying that it can’t contact openhab
Dissociate Openhab from google home
Reassociate Openhab → log to myopenhab → click in allow → error message : impossible to update the parameter, verify your connexion.
