Since the following conversation was closed on a few days ago, I am opening a new one.
I am on OH 3.1 with the latest updates. I updated yesterday. I am seeing this same error.
2021-11-08 14:17:25.725 [INFO ] [control.internal.WebSocketConnection] - Web Socket close 1005. Reason: null
2021-11-08 14:19:13.458 [INFO ] [control.internal.WebSocketConnection] - Web Socket close 1005. Reason: null
2021-11-08 14:21:07.713 [INFO ] [control.internal.WebSocketConnection] - Web Socket close 1005. Reason: null
2021-11-08 14:23:00.794 [INFO ] [control.internal.WebSocketConnection] - Web Socket error
javax.net.ssl.SSLHandshakeException: Abruptly closed by peer
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.fill(SslConnection.java:752) ~[?:?]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.process(HttpReceiverOverHTTP.java:164) ~[?:?]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.receive(HttpReceiverOverHTTP.java:79) ~[?:?]
at org.eclipse.jetty.client.http.HttpChannelOverHTTP.receive(HttpChannelOverHTTP.java:131) ~[?:?]
at org.eclipse.jetty.client.http.HttpConnectionOverHTTP.onFillable(HttpConnectionOverHTTP.java:169) ~[?:?]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) ~[?:?]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.onFillable(SslConnection.java:540) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:395) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection$2.succeeded(SslConnection.java:161) ~[?:?]
at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104) ~[?:?]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:882) [bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1036) [bundleFile:9.4.40.v20210413]
Suppressed: javax.net.ssl.SSLException: closing inbound before receiving peer’s close_notify
at sun.security.ssl.Alert.createSSLException(Alert.java:133) ~[?:?]
at sun.security.ssl.Alert.createSSLException(Alert.java:117) ~[?:?]
at sun.security.ssl.TransportContext.fatal(TransportContext.java:336) ~[?:?]
at sun.security.ssl.TransportContext.fatal(TransportContext.java:292) ~[?:?]
at sun.security.ssl.TransportContext.fatal(TransportContext.java:283) ~[?:?]
at sun.security.ssl.SSLEngineImpl.closeInbound(SSLEngineImpl.java:733) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.closeInbound(SslConnection.java:965) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.fill(SslConnection.java:749) ~[?:?]
Suppressed: org.eclipse.jetty.io.EofException
at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:279) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection.networkFlush(SslConnection.java:474) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.flush(SslConnection.java:1080) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.doShutdownOutput(SslConnection.java:1292) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.doClose(SslConnection.java:1374) ~[?:?]
at org.eclipse.jetty.io.AbstractEndPoint.doOnClose(AbstractEndPoint.java:220) ~[?:?]
at org.eclipse.jetty.io.AbstractEndPoint.close(AbstractEndPoint.java:192) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.fill(SslConnection.java:828) ~[?:?]
Caused by: java.io.IOException: Broken pipe
at sun.nio.ch.FileDispatcherImpl.writev0(Native Method) ~[?:?]
at sun.nio.ch.SocketDispatcher.writev(SocketDispatcher.java:51) ~[?:?]
at sun.nio.ch.IOUtil.write(IOUtil.java:182) ~[?:?]
at sun.nio.ch.IOUtil.write(IOUtil.java:130) ~[?:?]
at sun.nio.ch.SocketChannelImpl.write(SocketChannelImpl.java:493) ~[?:?]
at java.nio.channels.SocketChannel.write(SocketChannel.java:507) ~[?:?]
at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:273) ~[?:?]
… 21 more
2021-11-08 14:24:51.446 [INFO ] [control.internal.WebSocketConnection] - Web Socket close 1005. Reason: null
Any ideas of what I need to do to fix this issue.
