I recently had a few problems with my openhab installation. So i decided to do a fresh installation and use everything i learned in the last years to make an even better smarthome.
I downloaded the latest openhab version (openHABian v1.7.4b) for raspberry pi, used balena etcher to burn the image on a sd-card and let the raspberry alone with the card and network connected.
after the installation process openhab started on openhabian:8080 but nothing to see on openhabian:9001.
I tried this whole process, download, burn, install with 3 different sd-cards and 3 different raspberry pi in two different network enviroments but always with the same result.
one thing i noticed during the installation process was:
npm WARN config global –global, –localare deprecated. Use–location=global instead
i tried to change the files npm and npm.cmd from “-g” to “–location=global” but it didn´t work.
i also tried to install frontail manualy in openhabian-config.
I also tried hints from the same issue from 2019…
but it didn´t help.
i think i saw that there has been an update to nodejs, maybe this causes the issue?
Can anyone confirm that frontail is broken in openHABian v1.7.4b or what can i do to get this to work?
We recently bumped nodejs from v14 to v16 so you more likely have hit some new issue.
Use debugmode=maximum during installation to get a log to figure out what goes wrong alongside the installation process.
The installation worked well and i get my first login screen on port 8080.
Port 9001 shows:
# Die Website ist nicht erreichbar
**192.168.178.21** hat die Verbindung abgelehnt.
Versuche Folgendes:
* Verbindung prüfen
* [Proxy und Firewall prüfen](chrome-error://chromewebdata/#buttons)
ERR_CONNECTION_REFUSED
when i check the status of frontail by using systemctl status frontail.service i get the following lines:
● frontail.service - Frontail openHAB instance, reachable at http://openhabian:9001
Loaded: loaded (/etc/systemd/system/frontail.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Wed 2022-08-17 23:33:54 CEST; 19min ago
Docs: https://github.com/mthenw/frontail
Process: 1129 ExecStart=/usr/lib/node_modules/frontail/bin/frontail --disable-usage-stats --ui-highlight ->
Main PID: 1129 (code=exited, status=1/FAILURE)
CPU: 1.028s
Aug 17 23:33:54 openhabian systemd[1]: frontail.service: Scheduled restart job, restart counter is at 5.
Aug 17 23:33:54 openhabian systemd[1]: Stopped Frontail openHAB instance, reachable at http://openhabian:9001.
Aug 17 23:33:54 openhabian systemd[1]: frontail.service: Consumed 1.028s CPU time.
Aug 17 23:33:54 openhabian systemd[1]: frontail.service: Start request repeated too quickly.
Aug 17 23:33:54 openhabian systemd[1]: frontail.service: Failed with result 'exit-code'.
Aug 17 23:33:54 openhabian systemd[1]: Failed to start Frontail openHAB instance, reachable at http://openhabi>
lines 1-14/14 (END)
The logfile is to big to post it here so here is a link:
[sudo] password for openhabian:
[19:04:45] root@openhabian:/home/openhabian# cd /opt/frontail/
[19:04:55] root@openhabian:/opt/frontail# npm install cookie
npm WARN old lockfile
npm WARN old lockfile The package-lock.json file was created with an old version of npm,
npm WARN old lockfile so supplemental metadata must be fetched from the registry.
npm WARN old lockfile This is a one-time fix-up, please be patient...
npm WARN deprecated request-promise-native@1.0.5: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
npm WARN deprecated left-pad@1.3.0: use String.prototype.padStart()
npm WARN deprecated uuid@3.3.2: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
npm WARN deprecated har-validator@5.1.5: this library is no longer supported
npm WARN deprecated mkdirp@0.5.1: Legacy versions of mkdirp are no longer supported. Please update to mkdirp 1.x. (Note that the API surface has changed to use Promises in 1.x.)
npm WARN deprecated har-validator@5.1.0: this library is no longer supported
npm WARN deprecated formidable@1.2.1: Please upgrade to latest, formidable@v2 or formidable@v3! Check these notes: https://bit.ly/2ZEqIau
npm WARN deprecated debug@3.2.6: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
npm WARN deprecated request@2.88.0: request has been deprecated, see https://github.com/request/request/issues/3142
npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
npm WARN deprecated superagent@3.8.3: Please upgrade to v7.0.2+ of superagent. We have fixed numerous issues with streams, form-data, attach(), filesystem errors not bubbling up (ENOENT on attach()), and all tests are now passing. See the releases tab for more information at <https://github.com/visionmedia/superagent/releases>.
npm WARN deprecated buster-core@0.6.4: No longer maintained
added 466 packages, and audited 467 packages in 2m
23 packages are looking for funding
run `npm fund` for details
13 vulnerabilities (8 moderate, 2 high, 3 critical)
To address issues that do not require attention, run:
npm audit fix
To address all issues (including breaking changes), run:
npm audit fix --force
Run `npm audit` for details.
then i did teh npm audit
[19:06:57] root@openhabian:/opt/frontail# npm audit
# npm audit report
ajv <6.12.3
Severity: moderate
Prototype Pollution in Ajv - https://github.com/advisories/GHSA-v88g-cgmw-v5xw
fix available via `npm audit fix`
node_modules/ajv
node_modules/request/node_modules/ajv
har-validator 3.3.0 - 5.1.0
Depends on vulnerable versions of ajv
node_modules/request/node_modules/har-validator
ansi-regex 4.0.0 - 4.1.0 || 5.0.0
Severity: high
Inefficient Regular Expression Complexity in chalk/ansi-regex - https://github.com/advisories/GHSA-93q8-gq69-wqmw
node_modules/ansi-regex
node_modules/strip-ansi/node_modules/ansi-regex
engine.io 4.0.0 - 4.1.1
Severity: high
Uncaught Exception in engine.io - https://github.com/advisories/GHSA-273r-mgr4-v34f
node_modules/engine.io
hosted-git-info <2.8.9
Severity: moderate
Regular Expression Denial of Service in hosted-git-info - https://github.com/advisories/GHSA-43f8-2h32-f4cj
node_modules/hosted-git-info
jsdom <=16.4.0
Severity: moderate
Insufficient Granularity of Access Control in JSDom - https://github.com/advisories/GHSA-f4c9-cqv8-9v98
fix available via `npm audit fix --force`
Will install jsdom@20.0.0, which is a breaking change
node_modules/jsdom
json-schema <0.4.0
Severity: critical
json-schema is vulnerable to Prototype Pollution - https://github.com/advisories/GHSA-896r-f27r-55mw
node_modules/json-schema
jsprim 0.3.0 - 1.4.1 || 2.0.0 - 2.0.1
Depends on vulnerable versions of json-schema
node_modules/jsprim
minimist <=1.2.5
Severity: critical
Prototype Pollution in minimist - https://github.com/advisories/GHSA-xvch-5gv4-984h
Prototype Pollution in minimist - https://github.com/advisories/GHSA-vh95-rmgr-6w4m
Will install mocha@10.0.0, which is a breaking change
node_modules/minimist
node_modules/pkg-fetch/node_modules/minimist
node_modules/pkg/node_modules/minimist
mkdirp 0.4.1 - 0.5.1
Depends on vulnerable versions of minimist
node_modules/mkdirp
mocha 1.21.5 - 6.2.2 || 7.0.0-esm1 - 7.1.0
Depends on vulnerable versions of mkdirp
node_modules/mocha
path-parse <1.0.7
Severity: moderate
Regular Expression Denial of Service in path-parse - https://github.com/advisories/GHSA-hj48-42vr-x3v9
node_modules/path-parse
node_modules/resolve/node_modules/path-parse
ws 5.0.0 - 5.2.2 || 7.0.0 - 7.4.5
Severity: moderate
ReDoS in Sec-Websocket-Protocol header - https://github.com/advisories/GHSA-6fc8-4gx4-v693
node_modules/jsdom/node_modules/ws
node_modules/ws
npm audit fix
i think i trie to delete package-lock.json and then install cookie again…
Okay …
I went to the folder opt/frontail, used sudo bash to become supersaiyajin and deleted the files package.json and package-lock.json by typing rm package.json rm package-lock.json.
then i ran npm install cookie again.
After a reboot the folders are there again but still no frontail.
after running sudo journalctl -u frontail again, i get the error
Aug 18 19:20:09 openhabian frontail[742]: Error: Cannot find module 'cookie-parser'
okay, again supersaiyajin sudo bash, go to folder cd opt/frontail and install the missing package npm install cookie-parser.
after a reboot and sudo journalctl -u frontail now i get
Aug 18 19:33:48 openhabian frontail[939]: Error: Cannot find module 'socket.io'
… after socket.io there was untildify missing. after installing untildify and a reboot there was only this:
[21:01:51] root@openhabian:/opt/frontail# sudo journalctl -u frontail
-- Journal begins at Thu 2022-08-18 20:07:10 CEST, ends at Thu 2022-08-18 21:01:55 CEST. --
Aug 18 20:07:37 openhabian systemd[1]: Started Frontail openHAB instance, reachable at http://openhabian:9001.
Aug 18 20:07:42 openhabian systemd[1]: frontail.service: Main process exited, code=exited, status=1/FAILURE
Aug 18 20:07:42 openhabian systemd[1]: frontail.service: Failed with result 'exit-code'.
Aug 18 20:07:42 openhabian systemd[1]: frontail.service: Consumed 2.097s CPU time.
Aug 18 20:07:42 openhabian systemd[1]: frontail.service: Scheduled restart job, restart counter is at 1.
Aug 18 20:07:42 openhabian systemd[1]: Stopped Frontail openHAB instance, reachable at http://openhabian:9001.
Aug 18 20:07:42 openhabian systemd[1]: Started Frontail openHAB instance, reachable at http://openhabian:9001.
Aug 18 20:07:44 openhabian systemd[1]: frontail.service: Main process exited, code=exited, status=1/FAILURE
Aug 18 20:07:44 openhabian systemd[1]: frontail.service: Failed with result 'exit-code'.
Aug 18 20:07:44 openhabian systemd[1]: frontail.service: Consumed 1.807s CPU time.
Aug 18 20:07:44 openhabian systemd[1]: frontail.service: Scheduled restart job, restart counter is at 2.
Aug 18 20:07:44 openhabian systemd[1]: Stopped Frontail openHAB instance, reachable at http://openhabian:9001.
Aug 18 20:07:44 openhabian systemd[1]: Started Frontail openHAB instance, reachable at http://openhabian:9001.
Aug 18 20:07:46 openhabian systemd[1]: frontail.service: Main process exited, code=exited, status=1/FAILURE
Aug 18 20:07:46 openhabian systemd[1]: frontail.service: Failed with result 'exit-code'.
Aug 18 20:07:46 openhabian systemd[1]: frontail.service: Consumed 1.832s CPU time.
Aug 18 20:07:46 openhabian systemd[1]: frontail.service: Scheduled restart job, restart counter is at 3.
Aug 18 20:07:46 openhabian systemd[1]: Stopped Frontail openHAB instance, reachable at http://openhabian:9001.
Aug 18 20:07:46 openhabian systemd[1]: Started Frontail openHAB instance, reachable at http://openhabian:9001.
Aug 18 20:07:48 openhabian systemd[1]: frontail.service: Main process exited, code=exited, status=1/FAILURE
Aug 18 20:07:48 openhabian systemd[1]: frontail.service: Failed with result 'exit-code'.
No. Have a look into the service file to get information about how the command is to be started.
Then execute it in a terminal ( must be something with node … )
okay, lets go on…
i found the service file in /etc/systemd/system/ like mentioned in the log of post no. 17.
i opened the file with nano frontail.service.
the file contains the following text:
node:internal/modules/cjs/loader:959
throw err;
Error: Cannot find module 'fs-tail-stream'
Require stack:
- /opt/frontail/lib/tail.js
- /opt/frontail/index.js
- /opt/frontail/bin/frontail
at Function.Module._resolveFilename (node:internal/modules/cjs/loader:956:15)
at Function.Module._load (node:internal/modules/cjs/loader:804:27)
at Module.require (node:internal/modules/cjs/loader:1028:19)
at require (node:internal/modules/cjs/helpers:102:18)
at Object.<anonymous> (/opt/frontail/lib/tail.js:7:20)
at Module._compile (node:internal/modules/cjs/loader:1126:14)
at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10)
at Module.load (node:internal/modules/cjs/loader:1004:32)
at Function.Module._load (node:internal/modules/cjs/loader:839:12)
at Module.require (node:internal/modules/cjs/loader:1028:19) {
code: 'MODULE_NOT_FOUND',
requireStack: [
'/opt/frontail/lib/tail.js',
'/opt/frontail/index.js',
'/opt/frontail/bin/frontail'
looks like “fs-tail-stream” is missing and i don´t know where i would have to install it.
i think i will wait for an update where this problem is solved.
Thanks to all who tried to help me and i hope what i tried so far will help someone with the same issue.
It’s many modules missing.
I’ve opened Frontail not starting on fresh install · Issue #1711 · openhab/openhabian · GitHub to track this but frankly I have no idea of frontail, it’s some annoying heritage I would not have chosen in the first place and gave up on debugging.
Anyone to read this with more nodejs experience please help.
