- Platform information:
- Hardware: Rapberry Pi 4B 4 GB memory
- OS: openhabian 6.1.21-v8
- Java Runtime Environment:
- openjdk version “17.0.9” 2023-10-17
- OpenJDK Runtime Environment (build 17.0.9+9-Raspbian-1deb11u1rpt1)
- OpenJDK Client VM (build 17.0.9+9-Raspbian-1deb11u1rpt1, mixed mode, emulated-client)
- openHAB version: 4.04
Since several months (even with 4.0.3 before) I face the issue that several Bindings stop working after a few days. I recognize this situation, when may regular notfication are not sent anymore.
I started debugging with setting the root log to DEBUG and found, that many eceptions “org.eclipse.jetty.io.IdleTimeout” appear in the openhab.log. They are mostly related to a sitemap named “zuhause” (means “Home” in English). This is a sample log entry:
2024-01-14 19:53:46.590 [DEBUG] [org.eclipse.jetty.io.FillInterest ] - onFail FillInterest@13d1c4e{null}
java.util.concurrent.TimeoutException: Idle timeout expired: 30000/30000 ms
at org.eclipse.jetty.io.IdleTimeout.checkIdleTimeout(IdleTimeout.java:171) ~[?:?]
at org.eclipse.jetty.io.IdleTimeout.idleCheck(IdleTimeout.java:113) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635) ~[?:?]
at java.lang.Thread.run(Thread.java:840) ~[?:?]
My first change was to make the sitemap somewhat smaller and to remove several entries from the sitemap to see if that would influence th situation. But this did not lead to success.
Today I tried to rename and to deactivate the sitemap, but the same errors appeared again:
2024-01-14 20:17:24.233 [DEBUG] [rg.eclipse.jetty.io.AbstractEndPoint] - Ignored idle endpoint SocketChannelEndPoint@1e2d0c{l=/192.168.0.49:8080,r=/192.168.0.60:63553,OPEN,fill=-,flush=-,to=30005/30000}{io=0/0,kio=0,kro=1}->HttpConnection@f293bc[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@163d2d3{s=START}]=>HttpChannelOverHttp@12b990e{s=HttpChannelState@6d2789{s=WAITING rs=ASYNC os=OPEN is=IDLE awp=false se=false i=false al=2},r=40,c=false/false,a=WAITING,uri=//openhabian:8080/rest/sitemaps/events/11b820fe-d1f8-4507-af81-a672f2f8b239?sitemap=zuhause&pageid=zuhause,age=169681984}
2024-01-14 20:17:35.518 [DEBUG] [io.methvin.watcher.DirectoryWatcher ] - ENTRY_DELETE [/etc/openhab/sitemaps/zuhause_renamed.sitemap]
2024-01-14 20:17:35.519 [DEBUG] [io.methvin.watcher.DirectoryWatcher ] - -> DELETE [/etc/openhab/sitemaps/zuhause_renamed.sitemap] (isDirectory: false)
2024-01-14 20:17:35.520 [DEBUG] [io.methvin.watcher.DirectoryWatcher ] - ENTRY_CREATE [/etc/openhab/sitemaps/zuhause_renamed.inact]
2024-01-14 20:17:35.522 [DEBUG] [io.methvin.watcher.DirectoryWatcher ] - -> CREATE [/etc/openhab/sitemaps/zuhause_renamed.inact] (isDirectory: false)
2024-01-14 20:17:35.525 [DEBUG] [io.methvin.watcher.DirectoryWatcher ] - ENTRY_MODIFY [/etc/openhab/sitemaps/zuhause_renamed.inact]
2024-01-14 20:17:35.562 [DEBUG] [io.methvin.watcher.DirectoryWatcher ] - ENTRY_MODIFY [/etc/openhab/sitemaps/zuhause_renamed.inact]
2024-01-14 20:17:41.160 [INFO ] [enhab.core.model.script.energy.rules] - Energieverbrauch Zuhause: 131,32 kWh
2024-01-14 20:17:46.967 [DEBUG] [org.eclipse.jetty.io.IdleTimeout ] - SocketChannelEndPoint@1a50cbb{l=/192.168.0.49:8080,r=/192.168.0.36:57992,OPEN,fill=-,flush=-,to=30000/30000}{io=0/0,kio=0,kro=1}->HttpConnection@1724e6b[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@da7316{s=START}]=>HttpChannelOverHttp@18b9af3{s=HttpChannelState@d919a8{s=WAITING rs=ASYNC os=OPEN is=IDLE awp=false se=false i=false al=2},r=4,c=false/false,a=WAITING,uri=//192.168.0.49:8080/rest/sitemaps/events/ce3e2cb4-4ac1-449f-a171-565b6d1113df?sitemap=zuhause&pageid=zuhause,age=30240739} idle timeout check, elapsed: 30000 ms, remaining: 0 ms
2024-01-14 20:17:46.968 [DEBUG] [org.eclipse.jetty.io.IdleTimeout ] - SocketChannelEndPoint@1a50cbb{l=/192.168.0.49:8080,r=/192.168.0.36:57992,OPEN,fill=-,flush=-,to=30001/30000}{io=0/0,kio=0,kro=1}->HttpConnection@1724e6b[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@da7316{s=START}]=>HttpChannelOverHttp@18b9af3{s=HttpChannelState@d919a8{s=WAITING rs=ASYNC os=OPEN is=IDLE awp=false se=false i=false al=2},r=4,c=false/false,a=WAITING,uri=//192.168.0.49:8080/rest/sitemaps/events/ce3e2cb4-4ac1-449f-a171-565b6d1113df?sitemap=zuhause&pageid=zuhause,age=30240740} idle timeout expired
2024-01-14 20:17:46.973 [DEBUG] [rg.eclipse.jetty.io.AbstractEndPoint] - Ignored idle endpoint SocketChannelEndPoint@1a50cbb{l=/192.168.0.49:8080,r=/192.168.0.36:57992,OPEN,fill=-,flush=-,to=30005/30000}{io=0/0,kio=0,kro=1}->HttpConnection@1724e6b[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@da7316{s=START}]=>HttpChannelOverHttp@18b9af3{s=HttpChannelState@d919a8{s=WAITING rs=ASYNC os=OPEN is=IDLE awp=false se=false i=false al=2},r=4,c=false/false,a=WAITING,uri=//192.168.0.49:8080/rest/sitemaps/events/ce3e2cb4-4ac1-449f-a171-565b6d1113df?sitemap=zuhause&pageid=zuhause,age=30240744}
2024-01-14 20:17:52.163 [DEBUG] [org.eclipse.jetty.io.IdleTimeout ] - SocketChannelEndPoint@5456eb{l=/192.168.0.49:8080,r=/192.168.0.60:61790,OPEN,fill=-,flush=-,to=30000/30000}{io=0/0,kio=0,kro=1}->HttpConnection@15ff495[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@1106f65{s=START}]=>HttpChannelOverHttp@da47db{s=HttpChannelState@2280d3{s=WAITING rs=ASYNC os=OPEN is=IDLE awp=false se=false i=false al=2},r=8,c=false/false,a=WAITING,uri=//openhabian:8080/rest/sitemaps/events/f7262112-c26d-4048-82f2-09d298579a97?sitemap=zuhause&pageid=zuhause,age=172622170} idle timeout check, elapsed: 30000 ms, remaining: 0 ms
2024-01-14 20:17:52.164 [DEBUG] [org.eclipse.jetty.io.IdleTimeout ] - SocketChannelEndPoint@5456eb{l=/192.168.0.49:8080,r=/192.168.0.60:61790,OPEN,fill=-,flush=-,to=30001/30000}{io=0/0,kio=0,kro=1}->HttpConnection@15ff495[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@1106f65{s=START}]=>HttpChannelOverHttp@da47db{s=HttpChannelState@2280d3{s=WAITING rs=ASYNC os=OPEN is=IDLE awp=false se=false i=false al=2},r=8,c=false/false,a=WAITING,uri=//openhabian:8080/rest/sitemaps/events/f7262112-c26d-4048-82f2-09d298579a97?sitemap=zuhause&pageid=zuhause,age=172622171} idle timeout expired
2024-01-14 20:17:52.168 [DEBUG] [rg.eclipse.jetty.io.AbstractEndPoint] - Ignored idle endpoint SocketChannelEndPoint@5456eb{l=/192.168.0.49:8080,r=/192.168.0.60:61790,OPEN,fill=-,flush=-,to=30005/30000}{io=0/0,kio=0,kro=1}->HttpConnection@15ff495[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@1106f65{s=START}]=>HttpChannelOverHttp@da47db{s=HttpChannelState@2280d3{s=WAITING rs=ASYNC os=OPEN is=IDLE awp=false se=false i=false al=2},r=8,c=false/false,a=WAITING,uri=//openhabian:8080/rest/sitemaps/events/f7262112-c26d-4048-82f2-09d298579a97?sitemap=zuhause&pageid=zuhause,age=172622176}
2024-01-14 20:17:54.235 [DEBUG] [org.eclipse.jetty.io.IdleTimeout ] - SocketChannelEndPoint@1e2d0c{l=/192.168.0.49:8080,r=/192.168.0.60:63553,OPEN,fill=-,flush=-,to=30000/30000}{io=0/0,kio=0,kro=1}->HttpConnection@f293bc[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@163d2d3{s=START}]=>HttpChannelOverHttp@12b990e{s=HttpChannelState@6d2789{s=WAITING rs=ASYNC os=OPEN is=IDLE awp=false se=false i=false al=2},r=40,c=false/false,a=WAITING,uri=//openhabian:8080/rest/sitemaps/events/11b820fe-d1f8-4507-af81-a672f2f8b239?sitemap=zuhause&pageid=zuhause,age=169711985} idle timeout check, elapsed: 30000 ms, remaining: 0 ms
2024-01-14 20:17:54.236 [DEBUG] [org.eclipse.jetty.io.IdleTimeout ] - SocketChannelEndPoint@1e2d0c{l=/192.168.0.49:8080,r=/192.168.0.60:63553,OPEN,fill=-,flush=-,to=30001/30000}{io=0/0,kio=0,kro=1}->HttpConnection@f293bc[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@163d2d3{s=START}]=>HttpChannelOverHttp@12b990e{s=HttpChannelState@6d2789{s=WAITING rs=ASYNC os=OPEN is=IDLE awp=false se=false i=false al=2},r=40,c=false/false,a=WAITING,uri=//openhabian:8080/rest/sitemaps/events/11b820fe-d1f8-4507-af81-a672f2f8b239?sitemap=zuhause&pageid=zuhause,age=169711987} idle timeout expired
2024-01-14 20:17:54.243 [DEBUG] [rg.eclipse.jetty.io.AbstractEndPoint] - Ignored idle endpoint SocketChannelEndPoint@1e2d0c{l=/192.168.0.49:8080,r=/192.168.0.60:63553,OPEN,fill=-,flush=-,to=30008/30000}{io=0/0,kio=0,kro=1}->HttpConnection@f293bc[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@163d2d3{s=START}]=>HttpChannelOverHttp@12b990e{s=HttpChannelState@6d2789{s=WAITING rs=ASYNC os=OPEN is=IDLE awp=false se=false i=false al=2},r=40,c=false/false,a=WAITING,uri=//openhabian:8080/rest/sitemaps/events/11b820fe-d1f8-4507-af81-a672f2f8b239?sitemap=zuhause&pageid=zuhause,age=169711994}
Then I checked the IP addresses and it looks, that jetty tried to communicate with a computer that is in sleep mode or even shutted down like my notebook with address yaml 192.168.0.60
… and jetty used the no longer existing sitemap:
2024-01-14 20:39:22.452 [DEBUG] [org.eclipse.jetty.io.IdleTimeout ] - SocketChannelEndPoint@5456eb{l=/192.168.0.49:8080,r=/192.168.0.60:61790,OPEN,fill=-,flush=-,to=30001/30000}{io=0/0,kio=0,kro=1}->HttpConnection@15ff495[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@1106f65{s=START}]=>HttpChannelOverHttp@da47db{s=HttpChannelState@2280d3{s=WAITING rs=ASYNC os=OPEN is=IDLE awp=false se=false i=false al=2},r=8,c=false/false,a=WAITING,uri=//openhabian:8080/rest/sitemaps/events/f7262112-c26d-4048-82f2-09d298579a97?sitemap=zuhause&pageid=zuhause,age=173912460} idle timeout expired
2024-01-14 20:39:22.456 [DEBUG] [rg.eclipse.jetty.io.AbstractEndPoint] - Ignored idle endpoint SocketChannelEndPoint@5456eb{l=/192.168.0.49:8080,r=/192.168.0.60:61790,OPEN,fill=-,flush=-,to=30005/30000}{io=0/0,kio=0,kro=1}->HttpConnection@15ff495[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@1106f65{s=START}]=>HttpChannelOverHttp@da47db{s=HttpChannelState@2280d3{s=WAITING rs=ASYNC os=OPEN is=IDLE awp=false se=false i=false al=2},r=8,c=false/false,a=WAITING,uri=//openhabian:8080/rest/sitemaps/events/f7262112-c26d-4048-82f2-09d298579a97?sitemap=zuhause&pageid=zuhause,age=173912464}
2024-01-14 20:39:24.550 [DEBUG] [org.eclipse.jetty.io.IdleTimeout ] - SocketChannelEndPoint@1e2d0c{l=/192.168.0.49:8080,r=/192.168.0.60:63553,OPEN,fill=-,flush=-,to=30000/30000}{io=0/0,kio=0,kro=1}->HttpConnection@f293bc[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@163d2d3{s=START}]=>HttpChannelOverHttp@12b990e{s=HttpChannelState@6d2789{s=WAITING rs=ASYNC os=OPEN is=IDLE awp=false se=false i=false al=2},r=40,c=false/false,a=WAITING,uri=//openhabian:8080/rest/sitemaps/events/11b820fe-d1f8-4507-af81-a672f2f8b239?sitemap=zuhause&pageid=zuhause,age=171002301} idle timeout check, elapsed: 30000 ms, remaining: 0 ms
2024-01-14 20:39:24.551 [DEBUG] [org.eclipse.jetty.io.IdleTimeout ] - SocketChannelEndPoint@1e2d0c{l=/192.168.0.49:8080,r=/192.168.0.60:63553,OPEN,fill=-,flush=-,to=30001/30000}{io=0/0,kio=0,kro=1}->HttpConnection@f293bc[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@163d2d3{s=START}]=>HttpChannelOverHttp@12b990e{s=HttpChannelState@6d2789{s=WAITING rs=ASYNC os=OPEN is=IDLE awp=false se=false i=false al=2},r=40,c=false/false,a=WAITING,uri=//openhabian:8080/rest/sitemaps/events/11b820fe-d1f8-4507-af81-a672f2f8b239?sitemap=zuhause&pageid=zuhause,age=171002301} idle timeout expired
2024-01-14 20:39:24.554 [DEBUG] [rg.eclipse.jetty.io.AbstractEndPoint] - Ignored idle endpoint SocketChannelEndPoint@1e2d0c{l=/192.168.0.49:8080,r=/192.168.0.60:63553,OPEN,fill=-,flush=-,to=30004/30000}{io=0/0,kio=0,kro=1}->HttpConnection@f293bc[p=HttpParser{s=CONTENT,0 of -1},g=HttpGenerator@163d2d3{s=START}]=>HttpChannelOverHttp@12b990e{s=HttpChannelState@6d2789{s=WAITING rs=ASYNC os=OPEN is=IDLE awp=false se=false i=false al=2},r=40,c=false/false,a=WAITING,uri=//openhabian:8080/rest/sitemaps/events/11b820fe-d1f8-4507-af81-a672f2f8b239?sitemap=zuhause&pageid=zuhause,age=171002305}
- Please post configurations (if applicable):
- Sitemap configuration related to the issue
sitemap zuhause label="Zuhause" {
Frame label="‼Aktuelles!!" {
Group item=Sensors_BatteryLevel label="Sensorbatt. schwach? [%.0f %unit%]" visibility=[Sensors_BatteryLevel < 80] valuecolor=[>80="green", <=60="orange", <30="red"]
Group item=monitor_mySystems label="IT-Systeme [%s]" visibility=[monitor_mySystems != ON] valuecolor=[==ON="green", ==NULL="orange", ==OFF="red"]
Group item=WindowDoor_contact_group label="Fenster/Türen [%s]" visibility=[WindowDoor_contact_group != CLOSED] valuecolor=[==CLOSED="green", ==NULL="orange", ==OPEN="red"]
Default item=Wassermelder_TurFensterZustand label="Keller [%s]" visibility=[Wassermelder_TurFensterZustand != CLOSED] valuecolor=[CLOSED="green", NULL="orange", OPEN="red"]
//Switch item=DUEWI label="Fensterlampe" icon="light" visibility=[DUEWI != OFF]
//Switch item=COMAG_1 label="Keiler-Lampe" icon="light" visibility=[COMAG_1 != OFF]
//Switch item=COMAG_2 label="Tannenbaum 🎄" icon="light" visibility=[COMAG_2 != OFF]
Group item=WZ_lights label="Wohnz. Lampen [%s]" icon="light" visibility=[WZ_lights != OFF] valuecolor=[OFF="green", NULL="orange", ON="red"]
Frame label="Müllabfuhr" {
Default item=ahaAbfuhrkalender_AbholtagRestabfall icon=aha_logo label="Restabfall [%1$td.%1$tm.%1$tY]"
Default item=ahaAbfuhrkalender_AbholtagPapier icon=aha_logo label="Papier [%1$td.%1$tm.%1$tY]"
Default item=ahaAbfuhrkalender_AbholtagLeichtverpackungen icon=rmg_logo label="Gelber Sack [%1$td.%1$tm.%1$tY]"
Frame label="Stromverbrauch" {
Default item=NM_PVA_Prod_live label="Live Produktion [%.3f kW]"
//Default item=SolarEdgeSE5KRWS48BNN4_DCPowerValue label="DC Power Value [%.3f kW]"
Default item=SolarEdgeSE5KRWS48BNN4_ACPowerValue icon=energy label="Leistung Wechselstrom [%.3f kW]"
//Default item=SolarEdgeSEMTR3Y400VA_TotalRealPowerValue icon=returnpipe label="Einspeisung [%.3f kW]" visibility=[SolarEdgeSEMTR3Y400VA_TotalRealPowerValue > 0]
//Default item=SolarEdgeSEMTR3Y400VA_TotalRealPowerValue icon=flowpipe label="Bezug [%.3f kW]" visibility=[SolarEdgeSEMTR3Y400VA_TotalRealPowerValue < 0]
Default item=SolarEdgeSEMTR3Y400VA_TotalRealPowerValue icon=flowpipe label="Einspeisung/Bezug [%.3f kW]"
Default item=SolarEdge_ModBus_BattPower icon=battery label="Batterieleistung [%.3f kW]" visibility=[SolarEdge_ModBus_BattPower != 0]
Default item=SolarEdge_ModBus_BattLevel label="Batterieladung [%.0f %%]"
//Default item=SolarEdge_ModBus_BattStatus icon=text label="Batteriestatus [MAP(solaredge_modbus.map):%s]"
Default item=SolarEdge_ModBus_TotalPowerConsumption icon=house label="Gesamtverbrauch [%.3f kW]"
//Chart item=SolarEdge_ModBus_TotalPowerConsumption period=D refresh=60000
//Default item=SolarEdge_ModBus_PowerSelfConsumption icon=house label="Eigenverbrauch [%.3f kW]"
//Default item=SolarEdgePVA_Import
//Chart item=SensorsPower period=12h refresh=180000
Group item=SensorsPower visibility=[SensorsPower > 0] label="Stromverbraucher [%.2f %unit%]" icon=energy
Text item=HZ_Brenner_onOff visibility=[HZ_Brenner_onOff == ON] label="Brenner läuft!" icon=fire
Text item=KitchenRadio_Power visibility=[KitchenRadio_Power == ON] label="Küchenradio ist an!" icon=receiver
Text item=Philips_TV_NetOnline visibility=[Philips_TV_NetOnline == ON] label="Philips TV ist an!" icon=screen
Text item=BlueRay_Player_online visibility=[BlueRay_Player_online == ON] label="BlueRay Player ist an!"
//Default item=PO_ShellyPlug_1_power visibility=[PO_ShellyPlug_1_outlet==ON] label="Multimedia Wohnzimmer [%.3f %unit%]"
Frame label="Gasverbrauch" {
Default item=Gas_Energie_Tag
Chart item=Gas_Energie_Tag period=W refresh=3600000
Default item=Gas_Energie_Heute
//Chart item=Gas_Energie_Heute period=D refresh=180000
Default item=Home_TotalEnergyConsumption_day
Frame label="Außenklima" {
Default item=Ga_temp icon=temperature
Chart item=Ga_temp period=D refresh=180000
Default item=GA_hum
//Chart item=GA_hum period=D refresh=180000
Frame label="Zimmerklima" {
Group item=Zimmer_temp label="Zimmer Temp. [%.1f %unit%]"
Chart item=Zimmer_temp period=D refresh=180000
Group item=Zimmer_hygro label="Zimmer Hygro. [%.1f %%]"
//Chart item=Zimmer_hygro period=D refresh=180000
Frame label="Wohnzimmer" {
Group item=WZ_temp label="Wohnzimmer Temp. [%.1f %unit%]"
Group item=WZ_hygro label="Wohnzimmer Hygro. [%.0f %unit%]"
Text item=KlimaloggPro30984_batteryOK visibility=[KlimaloggPro30984_batteryOK != OFF] valuecolor=[OFF="green", ON="red"]
Text item=KlimaloggPro31081_batteryLow visibility=[KlimaloggPro31081_batteryLow != OFF] valuecolor=[OFF="green", ON="red"]
Frame label="Küche" {
Switch item=KitchenRadio_Power label="Küchenradio" icon="receiver"
Switch item=KitchenRadio_Mute visibility=[KitchenRadio_Power==ON]
Default item=KitchenRadio_Volumepercent visibility=[KitchenRadio_Power==ON]
Selection item=KitchenRadio_Mode mappings=[0="Internet Radio", 1="Spotify", 3="Musik Player", 4="DAB", 5="UKW", 6="AUX In"] visibility=[KitchenRadio_Power==ON]
Selection item=KitchenRadio_Preset mappings=[0="DLF Kultur", 1="NDR 2", 2="Radio Hannover", 3="Radio 21"] visibility=[KitchenRadio_Power==ON]
Text item=KitchenRadio_CurrentTitle visibility=[KitchenRadio_Power==ON]
Text item=KitchenRadio_InfoText visibility=[KitchenRadio_Power==ON]
Frame label="Multimedia" {
Text item=BlueRay_Player_online label="Blue Ray Player [%s]" visibility=[BlueRay_Player_online==ON] valuecolor=[ON="green", OFF="red"]
Text item=Philips_TV_NetOnline label="Philips TV (Ping) [MAP(online_offline.map):%s]" visibility=[Philips_TV_NetOnline==ON] valuecolor=[ON="green", OFF="red"] icon=screen
Text item=PO_Fritz_Dect200_1_outlet label="Fritz DECT [%s]" visibility=[PO_Fritz_Dect200_1_outlet==ON] valuecolor=[ON="green", OFF="red"]
Text item=DIGIBIT_SATIP_online label="SAT>IP [MAP(online_offline.map):%s]" visibility=[DIGIBIT_SATIP_online==ON] valuecolor=[ON="green", OFF="red"] icon=satip
Text item=MM_VDR_online label="Linux VDR [MAP(online_offline.map):%s]" visibility=[MM_VDR_online==ON] valuecolor=[ON="green", OFF="red"] icon=vdr
Text item=MM_VDR_recording visibility=[MM_VDR_recording==ON] valuecolor=[ON="green", OFF="red"] icon=vdr
Default item=MM_VDR_nextRec_timer visibility=[MM_VDR_nextRec_timer!="NULL"]
Group item=MM_VDR label="VDR (Equipment)" icon=vdr
Frame label="Arbeitszimmer" {
//Default item=dcp375cw_msg1 label="Druckermeldung 1 [%s]" icon=brother
//Default item=dcp375cw_msg2 label="Druckerstatus [%s]"
Default item=openhabian_SNMP_CPU_temp valuecolor=[< 65000="green", < 80000="orange", > 79999 ="red"]
Default item=Openhabian_Mem_Used_Percent label="Openhabian Memory used [%.0f %%]" valuecolor=[< 80="green", < 90="orange", > 89 ="red"] icon=raspberry
Default item=Openhabian_Storage_Used_Percent label="Openhabian Storage used [%.0f %%]" valuecolor=[< 80="green", < 90="orange", > 89 ="red"] icon=raspberry
Group item=gOpenhabian
Default item=Synology_System_Temperature label="NAS System Temp. [%.1f °C]" valuecolor=[< 65="green", < 80="orange", > 79 ="red"]
Default item=Synology_CPU_MemRealUsedPercent label="NAS Memory used [%.1f %%]" valuecolor=[< 80="green", < 90="orange", > 89 ="red"] icon=synology
Default item=Synology_RAID_RaidUsedPercent label="NAS Storage used [%.1f %%]" valuecolor=[< 80="green", < 90="orange", > 89 ="red"] icon=synology
//Group item=gSynology
Group item=nxpanel_group label="NXPanel"
Frame label="Badezimmer" {
//Default item=Waschmaschine_current
//Chart item=Waschmaschine_current period=D refresh=60000
//Default item=Waschmaschine_power
Group item=Waschmaschine
Frame label="Schlafzimmer" {
Text item=AqaraFensterkontaktSchlafzimmer_contact label="Fenster [%s]" visibility=[AqaraFensterkontaktSchlafzimmer_contact!=CLOSED] icon="window" valuecolor=[==CLOSED="green", ==NULL="orange", ==OPEN="red"]
Default item=Schlafzimmerfenster_openTimeRemaining visibility=[Schlafzimmerfenster_openTimeRemaining!=0]
Frame label="Neu Mexiko" {
Text item=NeuMexiko_Turkontakt_contact label="Gartentür (Aqara)[%s]" visibility=[NeuMexiko_Turkontakt_contact!=CLOSED] valuecolor=[==CLOSED="green", ==NULL="orange", ==OPEN="red"]
Switch item=NM_Lampe_Kuechenzeile
Default item=shelly11192168026_Betrieb label="Licht an?" icon="light" valuecolor=[==OFF="green", ==NULL="orange", ==ON="red"]
Default item=AqaraMultiSensor_temp label="Temperatur Multi [%.1f °C]"
Default item=AqaraMultiSensor_hygro label="Hygro Multi [%.1f %%]"
//Text item=Fritz7362SL_Online label="FRITZ!Box 7362SL [MAP(online_offline.map):%s]" icon="fbox7362" valuecolor=[ON="green", OFF="red"]
Frame label="Dachboden" {
Text item=DIGIBIT_SATIP_online label="DIGIBIT SAT>IP [%s]" visibility=[DIGIBIT_SATIP_online == ON] valuecolor=[ON="green", OFF="red"]
Default item=PO_Fritz_Dect200_1_Power label="DIGIBIT Stromverbrauch" visibility=[DIGIBIT_SATIP_online == ON] valuecolor=[ON="green", OFF="red"]
Default item=DIGIBIT_SATIP_lastseen label="DIGIBIT Last seen [%1$td.%1$tm.%1$tY %1$tH:%1$tM:%1$tS]"
Default item=PO_Fritz_Dect200_1_Temp label="Temperatur [%.1f °C]"
Frame label="Keller" {
Default item=Wassermelder_TurFensterZustand icon="water" valuecolor=[CLOSED="green", NULL="orange", OPEN="red"]
Default item=Keller_Lenzpumpe_Betrieb
Default item=Keller_Lenzpumpe_onTimeRemaining
Default item=Keller_TempHygroSensor_temp
Default item=KlimaloggPro30507_temp label="Temp. [%.1f %unit%]"
Default item=Keller_TempHygroSensor_hygro
Default item=KlimaloggPro30507_hum label="Hygro. [%.1f %%]"
Group item=Keller_TempHygroSensor
Text item=Heizung_vcontrold_Online label="Heizung vcontrold online? [MAP(online_offline.map):%s]" valuecolor=[==ON="green", ==NULL="orange", ==OFF="red"]
Default item=Atlantis_SNMP_CPU_temp valuecolor=[< 65000="green", < 80000="orange", > 79999 ="red"]
//Default item=Atlantis_CPULoad5 icon=raspberry
//Default item=Atlantis_Mem_Used_Percent label="Atlantis Memory used [%.0f %%]" valuecolor=[< 80="green", < 90="orange", > 89 ="red"] icon=raspberry
Default item=Atlantis_Storage_Used_Percent label="Atlantis Storage used [%.0f %%]" valuecolor=[< 80="green", < 90="orange", > 89 ="red"] icon=raspberry
Group item=gAtlantis icon=raspberry
Frame label="PVA SolarEdge" {
Text item=SolarEdge_Online label="SolarEdge Ping online? [MAP(online_offline.map):%s]" valuecolor=[UNDEF="orange", ON="green", OFF="red"]
Default item=SolarEdge_lastSeen label="SolarEdge lastseen [%1$td.%1$tm.%1$tY %1$tH:%1$tM:%1$tS]" visibility=[SolarEdge_Online != ON]
//Text item=SolarEdge_ModBus_online label="SolarEdge MODBUS online? [MAP(online_offline.map):%s]" valuecolor=[UNDEF="orange", ON="green", OFF="red"]
//Default item=SolarEdge_ModBus_lastseen label="SolarEdge MODBUS lastseen [%1$td.%1$tm.%1$tY %1$tH:%1$tM:%1$tS]" visibility=[SolarEdge_ModBus_online != ON]
Text item=NM_PVA_Prod_liveStatus icon="solarplant"
//Default item=NM_PVA_Prod_liveImport icon=flowpipe visibility=[NM_PVA_Prod_liveImport > 0]
//Default item=SolarEdgePVA_Export icon=returnpipe visibility=[SolarEdgePVA_Export > 0]
Default item=NM_PVA_Prod_liveBattChargeDischarge
Default item=NM_PVA_Prod_liveBattLevel
Default item=Solar_Forecast
Default item=NM_PVA_Prod_Day
Default item=NM_PVA_Prod_Month
Default item=NM_PVA_Prod_Year
Frame label="Diverses" {
//Group item=Astro
Group item=Tankerkoenig
Group item=gSensors icon="temperature" label="Sensoren"
Group item=PowerOutlets icon="poweroutlet"
Group item=Shelly icon="shelly"
//Group item=Aqara_group
//Group item=Blitzwolf_group
//Group item=Nous_group
//Group item=Luminea_sensors_group icon="sensors"
//Group item=Zigbee_Switch_Module
Is this a known and wanted mechanism? Might this be a reason for my issue?
Any hints are appreciated!
Regards, Christoph
