[OH 4.2] Fronius inspired energy flow widget [4.2.1; 5.0.0]
This is my interpretation of the Fronius Energy Flow Widget. I made a few changes to the original, which make more sense to me. The DC components are in the top row, the inverter (AC/DC) is in the center and on the bottom are the AC components. I also included a dial for the inverter. It shows the DC to AC power. It does not include any energy flow from solar to battery, which (at least for my system) ist pure DC. There is an extra indicator to visualize the energy flow from grid to load, which bypasses the inverter, depicting the actual physical flow, which bypasses the inverter.
There are no zoom effects, but the battery and inverter icons have a mouseover tooltip.
The code is reasonably well commented, at least as much as YAML would allow. I am pretty sure it could be written better (especially the flow animations, which currently are an unholy mess and repetitive DRY nightmare), but for now this is beyond my capabilities and time frame. If you are into this, please feel free to refactor the code to your liking. The code is about 770 lines, and can be a bit intimidating. The math is not as bad as javascript makes it looks. I tried my best to keep it somewhat grouped by functionality, but there are some severe restrictions on what can be factored out.
Keep in mind that the whole widget relies on oh-context which needs OH 4.2.1 to work properly (OH 4.2.0 has a bug which prevents the code from running outside the development environment).
NOTES:
  • The widget expects the battery state of charge as a dimensionless number between 0 and one. If your setup provides 0 to 100 (%) you may have to change this or modify the formula for the battery icon. See this post on how to do it.
  • There seems to be a weird bug with the forum software, which changes hyphens to underscores in some filenames. This affects the battery icon files. If you have trouble displaying them correctly, please correct the filenames manually by replacing the last underscore before the number part with a hyphen. I tried to upload them anew but it did not change anything.
Changelog
Version 1.0
  • encapsulated the svg in f7-card component for better integration
    • added title configuration parameter for f7-card
    • removed size parameter, as the size is now determined by the placement on the page
  • moved max_grid_power parameter to advanced settings
  • fixed a bug in resize_dot function which prevented it from including grid power flow in the size calculation
  • added max parameter to scale_to_deg function to account for max_grid_power setting
    • changed the function calls accordingly, passing the appropriate max value
  • reduced decimals to one for high yield installations (>= 10 kWp) in switch_magnitude
  • added layout options to f7-block component to adjust padding and content alignment
  • removed superfluous circle element in defs
  • added prefix “few_” (for “fronius energyflow widget”) to all ids to prevent clashes with identical ids from other components
  • increased font-size to 11pt and font-weight to bold for better readability when displayed on small screens
  • moved grid dial back to exponential spacing
  • cleaned up various typos in comments and formatting
Version 0.9
  • initial release
Resources
uid: fronius_energy_flow
tags:
  - energy
  - fronius
  - solar
props:
  parameters:
    - default: Fronius Power Flow
      label: Title
      required: false
      type: TEXT
      groupName: design
    - default: "8000"
      description: Maximum solar/inverter power in Watt.
      label: Maximum solar/inverter power
      required: true
      type: INTEGER
      min: 1
    - default: "10000"
      description: Maximum power to and from grid in Watt. Either use your fuse
        amperage to calculate this value or refer to your energy providers terms
        of use, or just leave the default value.
      label: Maximum grid power
      required: false
      type: INTEGER
      min: 1
      advanced: true
    - context: item
      description: Current solar power in Watts. Typically this would be the
        solar_yield item for a Fronius inverter.
      label: Solar Power
      required: true
      type: TEXT
      groupName: data_sources
    - context: item
      description: Battery level of charge in percent. Typically this would be the
        battery state of charge item of a Fronius inverter.
      label: Battery level
      required: true
      type: TEXT
    - context: item
      description: Battery charge/discharge power. Typically this would be the battery
        charge/discharge item of a Fronius inverter.
      label: Battery charge/discharge power.
      required: true
      type: TEXT
    - context: item
      description: Current inverter power in Watts delivered either to load or grid.
        Typically this would be the inverter_power item for a Fronius inverter.
      label: Inverter power
      required: true
      type: TEXT
    - context: item
      description: Current energy autonomy. Typically the autonomy item for a Fronius
        Smartmeter-
      label: Autonomy
      required: true
      type: TEXT
    - context: item
      description: Power to an from grid in Watts. Typically this would be .
      label: Grid power
      required: true
      type: TEXT
    - context: item
      description: Current consumption of electric energy (load), regardless of its
        source. Typically this would be the Fronius Smartmeter item load.
      label: Load power
      required: true
      type: TEXT
    - default: "0.68"
      description: "Exponent for the scale (default: 0.68; 1=linear, reasonable values
        range from 0.5 to 2)"
      label: Exponent
      required: false
      groupName: design
      advanced: true
  parameterGroups:
    - name: design
      label: Design elements
      description: Group of parameters which determine the visual appearance of the widget.
    - name: data_sources
      label: Data sources
      description: Groups all datasources together.
timestamp: Aug 23, 2024, 9:26:18 AM
component: f7-card
  comment: This component determines the size of the widget.
  outline: true
  title: =props.title
slots:
  default:
    - component: oh-context
        comment: "'arc_flag' determines which arc should be drawn (short or long).
          'resize_dot' adjusts the size of the energy flow dots in relation to
          the highest value in the system. The value correlates to the area of
          the dot, not its radius to give a better visual feedback.
          'scale_to_deg' makes sure the input value does not exceed
          max_solar_power or max_grid_power and scales everything to 270°.
          'switch_color' handles power less than 1 and sets the color dependent
          on the data_source, based on the dictionary in the function.
          'switch_magnitude' switches between W an kW depending on the input
          value. 'to_cartesian' converts degree to cartesian coordinates to be
          used by arc."
        functions:
          arc_flag: "=degree => degree < 180 ? 0 : 1"
          resize_dot: "=value => Math.abs(value) < 10 ? 0 :
            `${Math.pow(Math.max(Math.abs(value) / Math.max(
            (Math.abs(#props.load_power) + (#props.grid_power > 0 ?
            #props.grid_power : 0)), Math.abs(#props.grid_power),
            Math.abs(#props.solar_power), Math.abs(#props.battery_charge)),
            0.05), 0.5) * 5}px`"
          scale_to_deg: =(value, max) => Math.pow(Math.min(Math.abs(value), max) * (270 /
            max), props.exponent) * (270 / Math.pow(270, props.exponent))
          switch_color: '=(value, type) => (Math.abs(value) >= 1) ? {"pv": "#f7c002",
            "grid": "#999999", "inverter": "#e2001a", "load": "#71afcd",
            "battery": "#6cbe58"}[type] : "grey"'
          switch_magnitude: "=value => Math.abs(value) > 999 ? `${(value /
            1000).toFixed(Math.abs(value) > 9999 ? 1 : 2)} kW` :
            `${Math.round(value) | 0} W`"
          to_cartesian: =degree => (50 + Math.sin(degree * Math.PI / 180) * 41) + " " +
            (50 - Math.cos(degree * Math.PI / 180) * 41)
      slots:
        default:
          - component: f7-block
              style:
                display: flex
                height: 100%
                width: 100%
                content-justify: center
                padding: 5%
            slots:
              default:
                - component: svg
                    comment: The component scales freely to the size of its parent.
                    height: 100%
                    viewBox: 0 0 300 300
                    width: 100%
                  slots:
                    default:
                      - component: defs
                        slots:
                          default:
                            - component: symbol
                              slots:
                                default:
                                  - component: line
                                      comment: Separator line for the dial.
                                      style:
                                        stroke: white
                                        stroke-width: 1px
                                      x1: 50px
                                      x2: 50px
                                      y1: 2px
                                      y2: 16px
                            - component: symbol
                                comment: "Draws the background of each dial: Outer ring, scale backdrop, inner
                                  Ring."
                              slots:
                                default:
                                  - component: circle
                                      comment: Outer ring. The stroke color uses the base color with less opacity.
                                      cx: 50px
                                      cy: 50px
                                      fill: white
                                      r: 49.5px
                                      style:
                                        stroke-opacity: 0.4
                                        stroke-width: 1px
                                  - component: circle
                                      comment: Inner ring. The stroke color uses the base color with less opacity.
                                      cx: 50px
                                      cy: 50px
                                      fill: rgba(0, 0, 0, 0)
                                      r: 32.5px
                                      style:
                                        stroke-opacity: 0.4
                                        stroke-width: 1px
                                  - component: path
                                      comment: Background of the dial. The stroke color uses the base color with less
                                        opacity.
                                      cx: 50px
                                      cy: 50px
                                      d: M50 9 A41 41 0 1 1 9 50
                                      r: 41px
                                      style:
                                        stroke-opacity: 0.4
                                        stroke-width: 14px
                            - component: path
                                comment: Path for numerical display of value.
                                d: M9,50 A41 41 0 0 1 50 9
                                stroke-width: 0px
                      - component: g
                          comment: Solarpanel
                        slots:
                          default:
                            - component: g
                                comment: Solar energy flow visualisation
                              slots:
                                default:
                                  - component: path
                                      comment: Energy flow visualization solar.
                                      d: M80 80 L120 120
                                      style:
                                        stroke: "#999999"
                                        stroke_width: 1px
                                  - component: oh-repeater
                                      comment: Sets up the circles, indicating the energy flow.
                                      for: offset
                                      fragment: true
                                      rangeStart: 0
                                      rangeStep: 1
                                      rangeStop: 2
                                      sourceType: range
                                    slots:
                                      default:
                                        - component: circle
                                            fill: "#f7c002"
                                            r: =fn.resize_dot(#props.solar_power)
                                          slots:
                                            default:
                                              - component: animateMotion
                                                  begin: =`${loop.offset}s`
                                                  calcMode: linear
                                                  dur: 3s
                                                  repeatCount: indefinite
                                                slots:
                                                  default:
                                                    - component: mpath
                                                        xlink:href: "#few_solar_path"
                            - component: use
                                comment: PV dial.
                                style:
                                  stroke: =fn.switch_color(#props.solar_power, "pv")
                                x: 0px
                                xlink:href: "#few_rings"
                                y: 0px
                            - component: path
                                comment: Dial, using an exponential scale. If the value exceeds max_solar_power,
                                  the color dial turns red.
                                d: =`M50 9 A41 41 0 ${fn.arc_flag(fn.scale_to_deg(#props.solar_power,
                                  props.max_solar_power))} 1
                                  ${fn.to_cartesian(fn.scale_to_deg(#props.solar_power,
                                  props.max_solar_power))}`
                                style:
                                  stroke: '=(Math.abs(#props.solar_power) < props.max_solar_power) ?
                                    fn.switch_color(#props.solar_power, "pv") :
                                    "#f70202"'
                                  stroke-width: 14px
                            - component: text
                                style:
                                  dominant-baseline: central
                                  fill: rgb(127, 127, 127)
                                  font-family: sans-serif
                                  font-weight: bold
                                  font-size: 11px
                                  letter-spacing: 1px
                                  text-anchor: middle
                                  translate: 0px 0px
                              slots:
                                default:
                                  - component: textPath
                                      content: =fn.switch_magnitude(#props.solar_power)
                                      startOffset: 50%
                                      xlink:href: "#few_text_path"
                            - component: image
                                comment: Solar pv icon.
                                height: 44px
                                width: 44px
                                x: 28px
                                xlink:href: =`/icon/fronius_pv?format=svg&anyFormat=true&iconset=classic`
                                y: 28px
                      - component: g
                          comment: Battery
                        slots:
                          default:
                            - component: g
                                comment: Energy flow visualisation
                              slots:
                                default:
                                  - component: path
                                      comment: Energy flow visualization battery.
                                      d: '=#props.battery_charge >= 0 ? "M220 80 L180 120" : "M180 120 L220 80"'
                                      style:
                                        stroke: "#999999"
                                        stroke_width: 1px
                                      for: offset
                                      fragment: true
                                      rangeStart: 0
                                      rangeStep: 1
                                      rangeStop: 2
                                      sourceType: range
                                    slots:
                                      default:
                                        - component: circle
                                            fill: "#6cbe58"
                                            r: =fn.resize_dot(#props.battery_charge)
                                          slots:
                                            default:
                                                  calcMode: linear
                                                  dur: 3s
                                                slots:
                                                  default:
                                                    - component: mpath
                                                        xlink:href: "#few_battery_path"
                            - component: use
                                comment: Battery dial.
                                style:
                                  stroke: "#6cbe58"
                                x: 200px
                                y: 0px
                            - component: path
                                comment: Dial, using a linear scale.
                                d: =`M50 9 A41 41 0 ${fn.arc_flag(#props.battery_level * 270)} 1
                                  ${fn.to_cartesian(#props.battery_level *
                                  270)}`
                                style:
                                  stroke: "#6cbe58"
                                  stroke-width: 14px
                                  translate: 200px 0px
                            - component: text
                                style:
                                  font-weight: bold
                                  font-size: 11px
                                  letter-spacing: 1px
                                  text-anchor: middle
                              slots:
                                default:
                                      content: =@props.battery_level
                                      startOffset: 50%
                            - component: image
                                comment: Battery icon
                                height: 44px
                                width: 44px
                                x: 228px
                                xlink:href: '=`/icon/fronius_battery${#props.battery_charge < 0 ? "_charging" :
                                  ""}-${25 * Math.round(#props.battery_level *
                                  4)}?format=svg&anyFormat=true&iconset=classic`'
                                y: 28px
                              slots:
                                default:
                                  - component: title
                                      content: '=`${#props.battery_charge > 0 ? "Disc" : "C"}harging with
                                        ${fn.switch_magnitude(Math.abs(#props.battery_charge))}.`'
                      - component: g
                          comment: Grid
                        slots:
                          default:
                            - component: g
                                comment: Grid energy flow visualisation
                              slots:
                                default:
                                  - component: path
                                      comment: PV to grid energy flow visualization.
                                      d: M120 180 L80 220
                                      style:
                                        stroke: "#999999"
                                        stroke_width: 1px
                                      for: offset
                                      fragment: true
                                      rangeStart: 0
                                      rangeStep: 1
                                      rangeStop: 2
                                      sourceType: range
                                    slots:
                                      default:
                                        - component: circle
                                            fill: "#999999"
                                            r: "=fn.resize_dot(#props.grid_power < 0 ? #props.grid_power : 0)"
                                          slots:
                                            default:
                                                  calcMode: linear
                                                  dur: 3s
                                                slots:
                                                  default:
                                                    - component: mpath
                                                        xlink:href: "#few_grid_path"
                            - component: g
                                comment: Grid to load energy flow visualisation.
                              slots:
                                default:
                                  - component: path
                                      comment: Energy flow visualization grid.
                                      d: M90 250 L210 250
                                      style:
                                        stroke: "#999999"
                                        stroke_width: 1px
                                      for: offset
                                      fragment: true
                                      rangeStart: 0
                                      rangeStep: 1
                                      rangeStop: 4
                                      sourceType: range
                                    slots:
                                      default:
                                        - component: circle
                                            fill: "#999999"
                                            r: "=fn.resize_dot(#props.grid_power > 0 ? #props.grid_power : 0)"
                                          slots:
                                            default:
                                                  calcMode: linear
                                                  dur: 5s
                                                slots:
                                                  default:
                                                    - component: mpath
                                                        xlink:href: "#few_grid_load_path"
                            - component: use
                                comment: Grid dial.
                                style:
                                  stroke: "#999999"
                                x: 0px
                                y: 200px
                            - component: path
                                comment: Dial, using a exponential scale.
                                d: =`M50 9 A41 41 0 ${fn.arc_flag(fn.scale_to_deg(#props.grid_power,
                                  props.max_grid_power))} 1
                                  ${fn.to_cartesian(fn.scale_to_deg(#props.grid_power,
                                  props.grid_solar_power))}`
                                style:
                                  stroke: =fn.switch_color(#props.grid_power, "grid")
                                  stroke-width: 14px
                                  translate: 0px 200px
                            - component: text
                                style:
                                  font-weight: bold
                                  font-size: 11px
                                  letter-spacing: 1px
                                  text-anchor: middle
                              slots:
                                default:
                                      content: =fn.switch_magnitude(#props.grid_power)
                                      startOffset: 50%
                            - component: image
                                comment: grid icon
                                height: 44px
                                width: 44px
                                x: 28px
                                xlink:href: /icon/fronius_grid?format=svg&anyFormat=true&iconset=classic
                                y: 228px
                      - component: g
                          comment: Load
                        slots:
                          default:
                            - component: g
                                comment: Load energy flow visualisation
                              slots:
                                default:
                                  - component: path
                                      comment: Energy flow visualization load.
                                      d: M180 180 L220 220
                                      style:
                                        stroke: "#999999"
                                        stroke_width: 1px
                                      for: offset
                                      fragment: true
                                      rangeStart: 0
                                      rangeStep: 1
                                      rangeStop: 2
                                      sourceType: range
                                    slots:
                                      default:
                                        - component: circle
                                            fill: "#71afcd"
                                            r: "=fn.resize_dot(#props.load_power + (#props.grid_power > 0 ?
                                              #props.grid_power : 0))"
                                          slots:
                                            default:
                                                  calcMode: linear
                                                  dur: 3s
                                                slots:
                                                  default:
                                                    - component: mpath
                                                        xlink:href: "#few_load_path"
                            - component: use
                                comment: Load dial
                                style:
                                  stroke: "#71afcd"
                                x: 200px
                                y: 200px
                            - component: path
                                d: =`M50 9 A41 41 0 ${fn.arc_flag(fn.scale_to_deg(#props.load_power,
                                  ${fn.to_cartesian(fn.scale_to_deg(#props.load_power,
                                  props.max_grid_power))}`
                                style:
                                  stroke: =fn.switch_color(#props.load_power, "load")
                                  stroke-width: 14px
                                  translate: 200px 200px
                            - component: text
                                style:
                                  font-size: 11px
                                  font-weight: bold
                                  letter-spacing: 1px
                                  text-anchor: middle
                              slots:
                                default:
                                      content: =fn.switch_magnitude(#props.load_power)
                                      startOffset: 50%
                            - component: image
                                comment: Load icon
                                height: 44px
                                width: 44px
                                x: 228px
                                xlink:href: =`/icon/fronius_consumption?format=svg&anyFormat=true&iconset=classic`
                                y: 228px
                      - component: g
                          comment: Inverter
                        slots:
                          default:
                            - component: use
                                comment: Inverter dial.
                                style:
                                  stroke: =fn.switch_color(#props.inverter_power, "inverter")
                                x: 100px
                                y: 100px
                            - component: path
                                d: =`M50 9 A41 41 0 ${fn.arc_flag(fn.scale_to_deg(#props.inverter_power,
                                  ${fn.to_cartesian(fn.scale_to_deg(#props.inverter_power,
                                style:
                                  stroke: '=(Math.abs(#props.inverter_power) < props.max_solar_power) ?
                                    "inverter") : "#f70202"'
                                  stroke-width: 14px
                                  translate: 100px 100px
                            - component: text
                                style:
                                  font-size: 11px
                                  font-weight: bold
                                  letter-spacing: 1px
                                  text-anchor: middle
                              slots:
                                default:
                                      content: =fn.switch_magnitude(#props.inverter_power)
                                      startOffset: 50%
                            - component: image
                                comment: inverter icon.
                                height: 44px
                                width: 44px
                                x: 128px
                                xlink:href: =`/icon/fronius_gen24?format=svg&anyFormat=true&iconset=classic`
                                y: 128px
                              slots:
                                default:
                                  - component: title
                                      content: "=`Autonomy: ${@props.autonomy || '--'}`"
                          comment: Draws the segments of the dials, using an exponential scale.
                          for: degree
                          fragment: true
                          rangeStart: 0
                          rangeStep: 13.5
                          rangeStop: 270
                          sourceType: range
                        slots:
                          default:
                            - component: use
                                comment: Battery dial segments.
                                style:
                                  transform: =`rotate(${loop.degree}deg)`
                                  transform-origin: 250px 50px
                                x: 200px
                                xlink:href: "#few_segment_line"
                                y: 0px
                            - component: use
                                comment: PV dial segments
                                style:
                                  transform: =`rotate(${(Math.pow(loop.degree, props.exponent) * 270 /
                                    Math.pow(270, props.exponent))}deg)`
                                  transform-origin: 50px 50px
                                x: 0px
                                y: 0px
                            - component: use
                                comment: Inverter dial segments
                                style:
                                  transform-origin: 150px 150px
                                x: 100px
                                y: 100px
                            - component: use
                                comment: Load dial segments
                                style:
                                  transform-origin: 250px 250px
                                x: 200px
                                y: 200px
                            - component: use
                                comment: Grid dial segments
                                style:
                                  transform-origin: 50px 250px
                                x: 0px
                                y: 200px
fronius_battery_charging-0
fronius_battery_charging-25
fronius_battery_charging-50
fronius_battery_charging-75
fronius_battery_charging-100
fronius_battery-0
fronius_battery-25
fronius_battery-50
fronius_battery-75
fronius_battery-100
fronius_battery
consumption
inverter_gen24
fronius_grid
pv
Thanks for sharing the Fronius widget! Good work!
I have problems with the battery icon. I can’t see it. Is there anything wrong with the names?
Thank you!
THx Chris
Hello Christian!
There seems to be an underscore _ where there should be a hyphen - in front of the values in the battery icons. I don’t know why this has changed during the upload process. I will fix it in the original post. You can either reinstall or fix the filenames in /etc/openhab/icons/classic manually.
Edit: I tried to fix the filenames in the original post. It does not work. For some reason the forum software keeps changing the hyphen to an underscore on upload for some of the files. Maybe a caching issue? For now there is only a workaround by fixing the filenames manually.
Sorry for the inconvenience.
Best regards
Peter
Hello Peter,
Thank for your answer.
You mean changing names like this?
grafik
I tried, but battery symbol is still missing. I clean the cache, tried different browsers.
Do have any idea?
Best regards,
Christian
Hello Chris!
Yes, the filenames should be exactly like this. Your battery charge state item seems to work as the percentage text is displayed correctly.
Can you try right clicking on the missing icon and Open in a new tab to see what filename your browser uses?
Greetings
Peter
Thats the filename:
/icon/fronius_battery_charging-9275?format=svg&anyFormat=true&iconset=classic
Battery says: 92.7%
Greetings
Christian
Hello Chris!
The filename issue is resolved. The problem seems to be something different.
My item has values from 0 to 1, corresponding to 0% to 100%. It seems your item returns not percentages but values from 0 to 100. The formula trying to figure out which icon to pick gets confused by this.
This is my channel configuration for the item:
I could use additional logic for values greater than 1, but this would still leave an ambiguous region from 0 to 1 with potential issues.
Alternatively you can change this line
""}-${25 * Math.round(#props.battery_level * 4)}?format=svg&anyFormat=true&iconset=classic`'
to this
""}-${25 * Math.round(#props.battery_level * 0.04)}?format=svg&anyFormat=true&iconset=classic`'
Notice the change of the factor from 4 to 0.04.
Regards
Peter
Hello Peter,
Great! Thank you, now it works!
I had to change the code because, after changing the item, the HabPanel shows the wrong battery parameter.
My Dashboard is made in HabPanel, i now try to switch all my Dashboard functions to Pages Widget.
So once again, thank you for your help,
Greetings Christian
Hey Peter! Nice One :wink:
I’m trying to adapt this widget to my solax pv setup.
Only thing im not getting setup right is the flow between battery and the inverter. It is actually inverted - so the dots flow to the battery when the battery is used for load and the other way around when the battery is charged, the dots flow from battery to the inverter icon.
Ive tried to fiddle around with the code but ended up making it worse :wink:
And is there a way to display not only the charge level of the battery but also the power in w?
My battery power item is negative (i.e -212W) when is discharging and positive when charging.
Maybe you or someone else could give me a hint on how to get this done :wink:
Hello Andre!
I am glad you do like my widget!
Reversing the flow visulization should be a simple matter of changing the “greater or equal than” to “less than” in the path component like this:
  d: '=#props.battery_charge < 0 ? "M220 80 L180 120" : "M180 120 L220 80"'
It should be around line 335 (this my vary, depending on your changes to the code).
In general I’ve set up my system so that negative values indicate an energy sink, as positive values indicate an energy source. Load is always negative, solar cells are always positive, grid is negative if energy is drawn and positive otherwise, battery charging is negative otherwise positive. This feels more intuitive for me, but in the end it’s just a matter of preference and consistency.
As to your second request: Yes there is. You can hover the mouspointer over the battery icon and it should display a tooltip with the current power draw/input in W.
Best regards
Peter
Thank you very much!
Well, that worked :slight_smile:
I do use the mobile openHAB app exclusively, so mouse over isn’t an option :slight_smile: I will try to display it somehow near the battery icon.
Thanks again!
Nice widget..
I just had it up running. But had another issue with the svg´s, as it seem if I just download them directly from the browser with the default naming, they are not all named with “fronius_xxxx”
Infact the inverter icon is just named “inverter_gen24.svg”. I had to rename it to fronius_gen24.svg to get it to work.
Beside that, great job!
Thank you for this great Widget,
it works fine, with one issue. The Battery loading ring
is not correct. See the pictures.
I couldn t find why?
Thanks again
I agree, the widget is great.
In my case the grid dial always shows 0. E.g. the screenshot in post #2 from Christian_Slamanig shows that the grid power is -6.68 kW but the grid dial shows 0. The same in post 13 above. :slightly_smiling_face:
I made a small change in the grid scale calculation which seems to solve the problem:
                            - component: path
changed “props.grid_solar_power” to “props.max_grid_power”:
                            - component: path
Hello Erich,
you are correct, this is a bug in the script. I tried to fix it in the original post, but it’s fixed already. :thinking:
Thanks for the report anyway.
Hello Biesta,
this is a very strange behavior.
Please have a look at your code around line 385. The “translate” part could be the culprit.
- component: path
      270)}`
    style:
      stroke: "#6cbe58"
      stroke-width: 14px
Regards
Peter
Hello Peter
Great that you fixed it already.
Thanks for the fast response.
Erich
Hello Peter,
thanks for your Answer, i tried some changes in translate, but it seems to depend on the loadlevel from the battery.
Thanks Hans
Hello Biesta!
I think I know what is happening. Could you please post the raw load level of your battery? It seems the last parameter for the SVG arc instruction get confused by it.
Regards
Peter
Hallo Peter,
unfortunately, I am not a professional when it comes to solar technology. What is meant by raw load level from the battery?
Regards
Hans
