OH-Block-Title - Size
I try to change the Size of a oh-block-title, but with no luck. All my attempts came to nothing.
Any idea ?
Cheers - Peter
Could you please show us the code…
Thx for answering.
It’s just the oh-block Code of an UI-Page.
Here is a part of it
  label: Monitoring & Maintenance
  sidebar: true
  style:
    background: linear-gradient(to top left,#B0E0E6 0%,#FFC0CB 30%,#1E90FF 100%)
blocks:
  - component: oh-block
      title: Thermostate EG
    slots:
      default:
        - component: oh-grid-cells
          config: {}
          slots:
            default:
              - component: widget:HeatingCSS_1.8.1_v3
                  background1: linear-gradient(122deg, rgba(34,193,195,1) 0%, rgba(253,187,45,1)
What I now mean is the part with the
which I want to point out a bit.
In the complete UI-page this “Head-Lines” look a bit “lost”.
If you need further information about UI-Layout or about the widgets pls. give me a short reply
Complete Yaml-Code UI-Page
monitoring.txt (34.9 KB)
How did you try to change the text size ?
Did you add a style to the config ?
I tried a lot of versions also in combination with the style-parameter
e.g.: size: 25px, fontSize: 25px,–f7-block-text-color: 25px ,etc.
But as I’m no programmer I didn’t find a solution.
I think you’re going to need to use the stylesheet method for this. The oh-blocks don’t give you direct access to the block title element configs. Should be pretty easy though, as the block title does have a the distinct block-title class already. So I would guess something like this should work:
  sidebar: true
  style:
  stylesheet: |
    .block-title {
      font-size: 28px
blocks:
thx at all. That’s what I’m looking for, even if I don’t understand anything about “distinct block-title class” :crazy_face:
But it’s always fantastic to get such help from all of you.
Now it looks like I want
