OH2.3 with KNX2 - not connecting to KNX Bus
Hello Udo,
thanks for the suggestion - I had not tried this option, did it now, but with the same result.
I changed my .things file to:
            Type number-control : Heat_OG_Bad_IST_Temp                      "Bad IST Temp"              [ ga="9.001:<4/3/20" ]
            Type switch : Switch_Heat_Bad_Sperre                    "Bad Sperre Stellmotor"     [ ga="1.003:<4/0/0" ]
            Type number-control : Heat_OG_Bad_Stellwert                     "Bad Stellmotor"            [ ga="5.001:<4/3/21" ]
            Type number-control : Heat_OG_Bad_SOLL_Temp                     "Bad SOLL Temp"             [ ga="9.001:4/3/22+<4/3/23" ]
            Type switch : Switch_Heat_Bad_Betriebsart_Komfort       "Bad Betriebsart Komfort"   [ ga="1.003:4/0/4" ]
            Type string : Heat_OG_Bad_Diagnose                      "OG Diagnose Bad"                  [ ga="16.000:<4/0/21" ]
But if I understood the control items right, this would not really be the right way to use a control item - or did I missunderstand the logic?
thanks
Andreas
