Hello Dim,
so after the weekend I now tried your advise - but unfortunately I do not get many entries in the log.
I did in Karaf:
Log:set TRACE org.openhab.binding.knx
Log:set TRACE calimero
And here’s the Screenshot of the Log and the ETS5 Side-by-side. You can see the values that are being written by the bus, and you see in the log the entries that these had been received - but nothing appears in the visu.
Also - wouldn’t I typically see the Status of each GA also in the log in cleartext (e.g. 18°C) - instead of the tpdu 00 80 00 or so..?
Here’s also a subset of readable Log file text and the corresponding ETS5 Text:
Logfile:
20:34:14.475 [INFO ] [smarthome.event.ItemStateChangedEvent] - ntp_ntp_local_dateTime changed from 2018-07-16T20:33:14.465+0200 to 2018-07-16T20:34:14.466+0200
20:34:14.478 [INFO ] [smarthome.event.ItemStateChangedEvent] - ntp_ntp_local_string changed from 2018-07-16 20:33:14 CEST to 2018-07-16 20:34:14 CEST
20:34:15.286 [INFO ] [smarthome.event.ItemStateChangedEvent] - Heizung_Aussen_Temperature changed from 19.699999999999999289457264239899814128875732421875 to 19.5
20:34:16.705 [DEBUG] [calimero.link.224.0.23.12:3671 ] - indication 1.0.5->6/1/0 L_Data.ind, low priority hop count 5, tpdu 00 80 34 22 0f
20:34:16.705 [TRACE] [knx.internal.client.AbstractKNXClient] - Received a Group Write telegram from '1.0.5' to '6/1/0'
20:34:16.905 [DEBUG] [calimero.link.224.0.23.12:3671 ] - indication 1.0.5->6/1/1 L_Data.ind, low priority hop count 5, tpdu 00 80 10 07 12
20:34:16.905 [TRACE] [knx.internal.client.AbstractKNXClient] - Received a Group Write telegram from '1.0.5' to '6/1/1'
20:34:17.105 [DEBUG] [calimero.link.224.0.23.12:3671 ] - indication 1.0.5->6/1/2 L_Data.ind, low priority hop count 5, tpdu 00 80 76 07 10 34 22 0f 40 80
20:34:17.105 [TRACE] [knx.internal.client.AbstractKNXClient] - Received a Group Write telegram from '1.0.5' to '6/1/2'
20:34:18.918 [DEBUG] [calimero.link.224.0.23.12:3671 ] - indication 1.0.98->6/5/54 L_Data.ind, low priority hop count 5, tpdu 00 80 00 27
20:34:18.918 [TRACE] [knx.internal.client.AbstractKNXClient] - Received a Group Write telegram from '1.0.98' to '6/5/54'
20:34:24.918 [DEBUG] [calimero.link.224.0.23.12:3671 ] - indication 1.0.98->6/5/34 L_Data.ind, low priority hop count 5, tpdu 00 80 57 04
20:34:24.918 [TRACE] [knx.internal.client.AbstractKNXClient] - Received a Group Write telegram from '1.0.98' to '6/5/34'
20:34:35.948 [DEBUG] [calimero.link.224.0.23.12:3671 ] - indication 1.0.12->4/2/51 L_Data.ind, low priority hop count 5, tpdu 00 80 00
20:34:35.948 [TRACE] [knx.internal.client.AbstractKNXClient] - Received a Group Write telegram from '1.0.12' to '4/2/51'
20:34:36.950 [DEBUG] [calimero.link.224.0.23.12:3671 ] - indication 1.0.12->4/2/23 L_Data.ind, low priority hop count 5, tpdu 00 80 05 dc
20:34:36.950 [TRACE] [knx.internal.client.AbstractKNXClient] - Received a Group Write telegram from '1.0.12' to '4/2/23'
20:34:36.988 [DEBUG] [calimero.link.224.0.23.12:3671 ] - indication 1.0.12->4/2/21 L_Data.ind, low priority hop count 5, tpdu 00 80 00
20:34:36.988 [TRACE] [knx.internal.client.AbstractKNXClient] - Received a Group Write telegram from '1.0.12' to '4/2/21'
20:34:37.950 [DEBUG] [calimero.link.224.0.23.12:3671 ] - indication 1.0.12->4/2/3 L_Data.ind, low priority hop count 5, tpdu 00 80 05 78
20:34:37.950 [TRACE] [knx.internal.client.AbstractKNXClient] - Received a Group Write telegram from '1.0.12' to '4/2/3'
20:34:37.987 [DEBUG] [calimero.link.224.0.23.12:3671 ] - indication 1.0.12->4/2/1 L_Data.ind, low priority hop count 5, tpdu 00 80 00
20:34:37.988 [TRACE] [knx.internal.client.AbstractKNXClient] - Received a Group Write telegram from '1.0.12' to '4/2/1'
20:34:38.947 [DEBUG] [calimero.link.224.0.23.12:3671 ] - indication 1.0.12->4/2/41 L_Data.ind, low priority hop count 5, tpdu 00 80 00
20:34:38.947 [TRACE] [knx.internal.client.AbstractKNXClient] - Received a Group Write telegram from '1.0.12' to '4/2/41'
20:34:38.982 [DEBUG] [calimero.link.224.0.23.12:3671 ] - indication 1.0.12->4/2/11 L_Data.ind, low priority hop count 5, tpdu 00 80 00
20:34:38.982 [TRACE] [knx.internal.client.AbstractKNXClient] - Received a Group Write telegram from '1.0.12' to '4/2/11'
20:34:44.630 [DEBUG] [calimero.link.224.0.23.12:3671 ] - indication 1.0.13->4/3/11 L_Data.ind, low priority hop count 5, tpdu 00 80 00
20:34:44.630 [TRACE] [knx.internal.client.AbstractKNXClient] - Received a Group Write telegram from '1.0.13' to '4/3/11'
20:34:44.665 [DEBUG] [calimero.link.224.0.23.12:3671 ] - indication 1.0.13->4/3/41 L_Data.ind, low priority hop count 5, tpdu 00 80 00
20:34:44.665 [TRACE] [knx.internal.client.AbstractKNXClient] - Received a Group Write telegram from '1.0.13' to '4/3/41'
20:34:45.633 [DEBUG] [calimero.link.224.0.23.12:3671 ] - indication 1.0.13->4/3/33 L_Data.ind, low priority hop count 5, tpdu 00 80 07 08
20:34:45.633 [TRACE] [knx.internal.client.AbstractKNXClient] - Received a Group Write telegram from '1.0.13' to '4/3/33'
20:34:45.667 [DEBUG] [calimero.link.224.0.23.12:3671 ] - indication 1.0.13->4/3/1 L_Data.ind, low priority hop count 5, tpdu 00 80 00
20:34:45.668 [TRACE] [knx.internal.client.AbstractKNXClient] - Received a Group Write telegram from '1.0.13' to '4/3/1'
20:34:45.703 [TRACE] [knx.internal.client.AbstractKNXClient] - Received a Group Write telegram from '1.0.13' to '4/3/31'
20:34:45.704 [DEBUG] [calimero.link.224.0.23.12:3671 ] - indication 1.0.13->4/3/31 L_Data.ind, low priority hop count 5, tpdu 00 80 00
20:34:46.634 [DEBUG] [calimero.link.224.0.23.12:3671 ] - indication 1.0.13->4/3/33 L_Data.ind, low priority hop count 5, tpdu 00 80 07 08
20:34:46.634 [TRACE] [knx.internal.client.AbstractKNXClient] - Received a Group Write telegram from '1.0.13' to '4/3/33'
20:34:46.668 [DEBUG] [calimero.link.224.0.23.12:3671 ] - indication 1.0.13->4/3/51 L_Data.ind, low priority hop count 5, tpdu 00 80 00
20:34:46.669 [TRACE] [knx.internal.client.AbstractKNXClient] - Received a Group Write telegram from '1.0.13' to '4/3/51'
20:34:46.703 [DEBUG] [calimero.link.224.0.23.12:3671 ] - indication 1.0.13->4/3/71 L_Data.ind, low priority hop count 5, tpdu 00 80 00
20:34:46.703 [TRACE] [knx.internal.client.AbstractKNXClient] - Received a Group Write telegram from '1.0.13' to '4/3/71'
20:34:46.907 [DEBUG] [calimero.link.224.0.23.12:3671 ] - indication 1.0.98->6/5/55 L_Data.ind, low priority hop count 5, tpdu 00 80 0c 65
20:34:46.907 [TRACE] [knx.internal.client.AbstractKNXClient] - Received a Group Write telegram from '1.0.98' to '6/5/55'
20:34:47.630 [DEBUG] [calimero.link.224.0.23.12:3671 ] - indication 1.0.13->4/3/61 L_Data.ind, low priority hop count 5, tpdu 00 80 00
20:34:47.630 [TRACE] [knx.internal.client.AbstractKNXClient] - Received a Group Write telegram from '1.0.13' to '4/3/61'
20:34:53.786 [DEBUG] [calimero.link.224.0.23.12:3671 ] - indication 1.0.27->4/2/50 L_Data.ind, low priority hop count 5, tpdu 00 80 0c 8d
20:34:53.786 [TRACE] [knx.internal.client.AbstractKNXClient] - Received a Group Write telegram from '1.0.27' to '4/2/50'
20:35:00.913 [DEBUG] [calimero.link.224.0.23.12:3671 ] - indication 1.0.98->6/5/0 L_Data.ind, low priority hop count 5, tpdu 00 80 4e 49
20:35:00.913 [TRACE] [knx.internal.client.AbstractKNXClient] - Received a Group Write telegram from '1.0.98' to '6/5/0'
20:35:02.673 [DEBUG] [calimero.link.224.0.23.12:3671 ] - indication 1.0.21->4/2/0 L_Data.ind, low priority hop count 5, tpdu 00 80 0c e7
20:35:02.673 [TRACE] [knx.internal.client.AbstractKNXClient] - Received a Group Write telegram from '1.0.21' to '4/2/0'
20:35:02.913 [DEBUG] [calimero.link.224.0.23.12:3671 ] - indication 1.0.98->6/5/17 L_Data.ind, low priority hop count 5, tpdu 00 80 4e 49
20:35:02.913 [TRACE] [knx.internal.client.AbstractKNXClient] - Received a Group Write telegram from '1.0.98' to '6/5/17'
20:35:08.912 [DEBUG] [calimero.link.224.0.23.12:3671 ] - indication 1.0.98->6/5/54 L_Data.ind, low priority hop count 5, tpdu 00 80 00 23
20:35:08.912 [TRACE] [knx.internal.client.AbstractKNXClient] - Received a Group Write telegram from '1.0.98' to '6/5/54'
20:35:14.474 [INFO ] [smarthome.event.ItemStateChangedEvent] - ntp_ntp_local_dateTime changed from 2018-07-16T20:34:14.466+0200 to 2018-07-16T20:35:14.468+0200
20:35:14.476 [INFO ] [smarthome.event.ItemStateChangedEvent] - ntp_ntp_local_string changed from 2018-07-16 20:34:14 CEST to 2018-07-16 20:35:14 CEST
And the ETS5:
|#|Zeit|Dienst|Flags |Prio|Quelladresse|Quellname|Zieladresse|Zielname|Rout|Typ|DPT|Info|
|310|16.07.2018 20:34:11,402|vom Bus||Niedrig|1.0.5|SCN-IP100.02 IP Router mit Email Funktion|6/1/0|Uhrzeit|6|GroupValueWrite| 10.001 Tageszeit|34 22 0F | Montag, 20:34:15|
|311|16.07.2018 20:34:11,602|vom Bus||Niedrig|1.0.5|SCN-IP100.02 IP Router mit Email Funktion|6/1/1|Datum|6|GroupValueWrite| 11.001 Datum|10 07 12 | 16.07.2018|
|312|16.07.2018 20:34:11,803|vom Bus||Niedrig|1.0.5|SCN-IP100.02 IP Router mit Email Funktion|6/1/2|Datum/Uhrzeit|6|GroupValueWrite| 19.001 Datum/Zeit|76 07 10 34 22 0F 40 80 | Montag, 16.07.2018, 20:34:15 (-W------Q) = (Fault: Normal (no fault), Working Day: Working day, No WD: WD field valid, No Year: Year field valid, No Date: Month and Day of Month fields valid, No Day of Week: Day of week field valid, No Time: Hour of day, Minutes and Seconds field valid, Standard Summer Time: Time = UT+X, Qualitiy of clock: clock with ext. sync signal)|
|313|16.07.2018 20:34:13,616|vom Bus||Niedrig|1.0.98|Wetterstation|6/5/54|Wind Gesschwindigkeit|6|GroupValueWrite| 9.005 Geschwindigkeit (m/s)|00 27 | 0,39 m/s|
|314|16.07.2018 20:34:19,616|vom Bus||Niedrig|1.0.98|Wetterstation|6/5/34|Helligkeit West Messert|6|GroupValueWrite| 9.004 Lux (Lux)|57 04 | 18391,04 Lux|
|315|16.07.2018 20:34:30,645|vom Bus||Niedrig|1.0.12|Heizungsaktor EG|4/2/51|2.6-2-Erdgeschoss.Wohnzimmer/Eszimmer/Küche-Heizung.HMDT-Heizen-MDT-Status Stellwert|6|GroupValueWrite| 5.001 Prozent (0..100%)|$00 | 0 %|
|316|16.07.2018 20:34:31,647|vom Bus||Niedrig|1.0.12|Heizungsaktor EG|4/2/23|2.3-2-Erdgeschoss.HWR-Heizung.HMDT-Heizen-MDT-Aktueller Sollwert|6|GroupValueWrite| 9.001 Temperatur (°C)|05 DC | 15 °C|
|317|16.07.2018 20:34:31,685|vom Bus||Niedrig|1.0.12|Heizungsaktor EG|4/2/21|2.3-2-Erdgeschoss.HWR-Heizung.HMDT-Heizen-MDT-Status Stellwert|6|GroupValueWrite| 5.001 Prozent (0..100%)|$00 | 0 %|
|318|16.07.2018 20:34:32,647|vom Bus||Niedrig|1.0.12|Heizungsaktor EG|4/2/3|2.1-2-Erdgeschoss.Windfang-Heizung.HMDT-Heizen-MDT-Aktueller Sollwert|6|GroupValueWrite| 9.001 Temperatur (°C)|05 78 | 14 °C|
|319|16.07.2018 20:34:32,686|vom Bus||Niedrig|1.0.12|Heizungsaktor EG|4/2/1|2.1-2-Erdgeschoss.Windfang-Heizung.HMDT-Heizen-MDT-Status Stellwert|6|GroupValueWrite| 5.001 Prozent (0..100%)|$00 | 0 %|
|320|16.07.2018 20:34:33,644|vom Bus||Niedrig|1.0.12|Heizungsaktor EG|4/2/41|2.5-2-Erdgeschoss.Gästezimmer-Heizung.HMDT-Heizen-MDT-Status Stellwert|6|GroupValueWrite| 5.001 Prozent (0..100%)|$00 | 0 %|
|321|16.07.2018 20:34:33,679|vom Bus||Niedrig|1.0.12|Heizungsaktor EG|4/2/11|2.2-2-Erdgeschoss.Flur-Heizung.HMDT-Heizen-MDT-Status Stellwert|6|GroupValueWrite| 5.001 Prozent (0..100%)|$00 | 0 %|
|322|16.07.2018 20:34:39,329|vom Bus||Niedrig|1.0.13|Heizungsaktor OG|4/3/11|3.2-3-Obergeschoss.WC-OG-Heizung.HMDT-Heizen-MDT-Status Stellwert|6|GroupValueWrite| 5.001 Prozent (0..100%)|$00 | 0 %|
|323|16.07.2018 20:34:39,363|vom Bus||Niedrig|1.0.13|Heizungsaktor OG|4/3/41|3.5-3-Obergeschoss.Büro-Heizung.HMDT-Heizen-MDT-Status Stellwert|6|GroupValueWrite| 5.001 Prozent (0..100%)|$00 | 0 %|
|324|16.07.2018 20:34:40,330|vom Bus||Niedrig|1.0.13|Heizungsaktor OG|4/3/33|3.4-3-Obergeschoss.Schlafzimmer-Heizung.HMDT-Heizen-MDT-Aktueller Sollwert|6|GroupValueWrite| 9.001 Temperatur (°C)|07 08 | 18 °C|
|325|16.07.2018 20:34:40,365|vom Bus||Niedrig|1.0.13|Heizungsaktor OG|4/3/1|3.1-3-Obergeschoss.Flur-Heizung.HMDT-Heizen-MDT-Status Stellwert|6|GroupValueWrite| 5.001 Prozent (0..100%)|$00 | 0 %|
|326|16.07.2018 20:34:40,401|vom Bus||Niedrig|1.0.13|Heizungsaktor OG|4/3/31|3.4-3-Obergeschoss.Schlafzimmer-Heizung.HMDT-Heizen-MDT-Status Stellwert|6|GroupValueWrite| 5.001 Prozent (0..100%)|$00 | 0 %|
|327|16.07.2018 20:34:41,330|vom Bus||Niedrig|1.0.13|Heizungsaktor OG|4/3/33|3.4-3-Obergeschoss.Schlafzimmer-Heizung.HMDT-Heizen-MDT-Aktueller Sollwert|6|GroupValueWrite| 9.001 Temperatur (°C)|07 08 | 18 °C|
|328|16.07.2018 20:34:41,365|vom Bus||Niedrig|1.0.13|Heizungsaktor OG|4/3/51|3.6-3-Obergeschoss.lll-Heizung.HMDT-Heizen-MDT-Status Stellwert|6|GroupValueWrite| 5.001 Prozent (0..100%)|$00 | 0 %|
|329|16.07.2018 20:34:41,400|vom Bus||Niedrig|1.0.13|Heizungsaktor OG|4/3/71|3.4-3-Obergeschoss.Ankleide-Heizung.HMDT-Heizen-MDT-Status Stellwert|6|GroupValueWrite| 5.001 Prozent (0..100%)|$00 | 0 %|
|330|16.07.2018 20:34:41,604|vom Bus||Niedrig|1.0.98|Wetterstation|6/5/55|Außentemperatur|6|GroupValueWrite| 9.001 Temperatur (°C)|0C 65 | 22,5 °C|
|331|16.07.2018 20:34:42,328|vom Bus||Niedrig|1.0.13|Heizungsaktor OG|4/3/61|3.7-3-Obergeschoss.mmmmmm-Heizung.HMDT-Heizen-MDT-Status Stellwert|6|GroupValueWrite| 5.001 Prozent (0..100%)|$00 | 0 %|
|332|16.07.2018 20:34:48,483|vom Bus||Niedrig|1.0.27|Wohnzimmer Glastaster|4/2/50|2.6-2-Erdgeschoss.Wohnzimmer/Eszimmer/Küche-Heizung.HMDT-Heizen-MDT-Temperaturmesswert|6|GroupValueWrite| 9.001 Temperatur (°C)|0C 8D | 23,3 °C|
|333|16.07.2018 20:34:55,610|vom Bus||Niedrig|1.0.98|Wetterstation|6/5/0|Helligkeit Ost Messert|6|GroupValueWrite| 9.004 Lux (Lux)|4E 49 | 8238,08 Lux|
|334|16.07.2018 20:34:57,370|vom Bus||Niedrig|1.0.21|Windfang Glastaster|4/2/0|2.1-2-Erdgeschoss.Windfang-Heizung.HMDT-Heizen-MDT-Temperaturmesswert|6|GroupValueWrite| 9.001 Temperatur (°C)|0C E7 | 25,1 °C|
|335|16.07.2018 20:34:57,610|vom Bus||Niedrig|1.0.98|Wetterstation|6/5/17|Helligkeit Süd Messert|6|GroupValueWrite| 9.004 Lux (Lux)|4E 49 | 8238,08 Lux|
|336|16.07.2018 20:35:03,609|vom Bus||Niedrig|1.0.98|Wetterstation|6/5/54|Wind Gesschwindigkeit|6|GroupValueWrite| 9.005 Geschwindigkeit (m/s)|00 23 | 0,35 m/s|
I am really struggeling - what do you think, could this be tied to a bad config? Or would you think I should open a new topic for this?
thanks
Andreas
