Hello.
After fresh install of openHAB 2.5.12 via Portainer (Docker), I chose not to install any packages via GUI. Instead I would like to install them via addons.cfg file. However I can’t install Paper UI and rest of the addons as well.
Any help is appreciated. Thanks.
2021-05-15 14:24:06.476 [WARN ] [g.eclipse.smarthome.core.net.NetUtil] - Found multiple local interfaces - ignoring 172.17.0.1
2021-05-15 14:24:06.498 [WARN ] [g.eclipse.smarthome.core.net.NetUtil] - Found multiple local interfaces - ignoring 192.168.1.61
2021-05-15 14:24:10.089 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://172.18.0.1:8080
2021-05-15 14:24:10.090 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://172.18.0.1:8443
2021-05-15 14:24:11.072 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2021-05-15 14:27:44.455 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-ui-basic': Error:
Error downloading mvn:org.openhab.ui.bundles/org.openhab.ui.basic/[2.5.0,2.6)
2021-05-15 14:27:47.397 [INFO ] [.dashboard.internal.DashboardService] - Stopped Dashboard
2021-05-15 14:34:00.670 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-mqtt, openhab-ui-basic, openhab-ui-paper': Error:
Error downloading mvn:org.openhab.ui.bundles/org.openhab.ui.paper/[2.5.0,2.6)
2021-05-15 14:34:31.682 [WARN ] [g.eclipse.smarthome.core.net.NetUtil] - Found multiple local interfaces - ignoring 172.17.0.1
2021-05-15 14:34:31.703 [WARN ] [g.eclipse.smarthome.core.net.NetUtil] - Found multiple local interfaces - ignoring 192.168.1.61
2021-05-15 14:34:33.767 [WARN ] [g.eclipse.smarthome.core.net.NetUtil] - Found multiple local interfaces - ignoring 172.17.0.1
2021-05-15 14:34:33.770 [WARN ] [g.eclipse.smarthome.core.net.NetUtil] - Found multiple local interfaces - ignoring 192.168.1.61
2021-05-15 14:34:37.139 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-mqtt, openhab-ui-basic, openhab-ui-paper': Error:
2021-05-15 14:34:39.176 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2021-05-15 14:35:35.456 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-mqtt, openhab-ui-basic, openhab-ui-paper': Error:
2021-05-15 14:36:35.430 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-mqtt, openhab-ui-basic, openhab-ui-paper': Error:
2021-05-15 14:37:35.459 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-mqtt, openhab-ui-basic, openhab-ui-paper': Error:
2021-05-15 14:38:35.432 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-mqtt, openhab-ui-basic, openhab-ui-paper': Error:
