Hi guys, I’ve just noticed these errors in the OH2 console but i can’t see any corresponding errors in the log files.
openhab> /jni/win/x86_64/jd2xx.dll
java.io.IOException: java.util.concurrent.TimeoutException: Idle timeout expired: 30001/30000 ms
at org.eclipse.jetty.util.SharedBlockingCallback$Blocker.block(SharedBlockingCallback.java:213)
at org.eclipse.jetty.server.HttpInputOverHTTP.blockForContent(HttpInputOverHTTP.java:66)
at org.eclipse.jetty.server.HttpInput$1.waitForContent(HttpInput.java:489)
at org.eclipse.jetty.server.HttpInput.read(HttpInput.java:122)
at java.io.InputStream.read(Unknown Source)
at org.jupnp.util.io.IO.copyLarge(IO.java:969)
at org.jupnp.util.io.IO.copy(IO.java:943)
at org.jupnp.util.io.IO.toByteArray(IO.java:391)
at org.jupnp.util.io.IO.readBytes(IO.java:110)
at org.jupnp.transport.impl.ServletUpnpStream.readRequestMessage(ServletUpnpStream.java:137)
at org.jupnp.transport.impl.ServletUpnpStream.run(ServletUpnpStream.java:61)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.util.concurrent.TimeoutException: Idle timeout expired: 30001/30000 ms
at org.eclipse.jetty.io.IdleTimeout.checkIdleTimeout(IdleTimeout.java:161)
at org.eclipse.jetty.io.IdleTimeout$1.run(IdleTimeout.java:50)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
… 3 more
… 3 more
