08:45:18.239 [ERROR] [org.eclipse.smarthome.io.audio ] - Component descriptor entry ‘OSGI-INF/*.xml’ not found
Thanks for reporting, it will be fixed with removed reference to non-existent OSGI-INF by kaikreuzer · Pull Request #1274 · eclipse-archived/smarthome · GitHub.
@Kai This error is back with latest snapshot #1096. Should I open a case?
2017-11-25 06:57:56.445 [ERROR] [org.openhab.binding.network ] - Component descriptor entry ‘OSGI-INF/.xml’ not found
2017-11-25 06:57:56.586 [ERROR] [org.openhab.binding.harmonyhub ] - Component descriptor entry 'OSGI-INF/.xml’ not found
2017-11-25 06:58:06.221 [ERROR] [org.openhab.binding.homematic ] - Component descriptor entry ‘OSGI-INF/*.xml’ not found
Michael
I can confirm this error in my system with snapshot #1096. All homematic items are not working anymore ![]()
Same here. Chromecast binding is broken:
[2017-11-25 09:09:48.188 [ERROR] [org.openhab.binding.chromecast ] - Component descriptor entry 'OSGI-INF/*.xml' not found](http://2017-11-25 09:09:48.188 [ERROR] [org.openhab.binding.chromecast ] - Component descriptor entry 'OSGI-INF/*.xml' not found)
[EDIT]
Issue logged: Component descriptor entry 'OSGI-INF/.xml’ not found · Issue #4627 · eclipse-archived/smarthome · GitHub
Is there any way to downgrade to #1094 via apt-get? I couldn’t find any hint.
Thanks, I am looking at it right now…
I’m having the same issue with the yamahareceiver binding:
10:42:27.198 [ERROR] [org.openhab.binding.yamahareceiver ] - Component descriptor entry 'OSGI-INF/*.xml' not found
See this post.
Thank you very much for the quick help. The next time I will invest more time searching this forum I guess.
Fixed for now. New build is running. Let’s hope it succeeds, then the next distro should work as expected!
rollback to the last snapshot didn’t do for a workaround. Any ideas how to get this running again “now”?
Jens
Not sure whether it helps, but after I ended up with an unresponsive system (after blacklisting some services, OH2 did not log any events or performed any actions, not did it log any errors) when updating to this morning’s snapshot, I was at my wits end after I tried the usual (deleting tmp, cache and some other folders) without making any difference. I removed it completely from my system, reinstalled from scratch and wouldn’t you know, the latest snapshot works like a charm.
i had to downgrade the addons… not the main pakage. Now homematic is back again
@Jensen: Could you help me, which command did you use in order to downgrade the addons?
@Kai Although the homematic things are “online” again they can not be used. I had similar problems with the last builds. Are there known issues with the homematic binding?
i used apt-get install openhab2-addons=2.2.0~20171123180616-1
I upgraded to #1098 and confirm everything is working again. Thanks Kai!
For me as well, thanks a lot!
Thank you very much. Everything up and running.
