OH2 Z-Wave refactoring and testing... and SECURITY
I’ve created a test version of the binding here.
You should uninstall the existing Z-Wave binding and manually install this file into the addons folder. It seems that OH comes with the serial bundle installed now so hopefully you shouldn’t need to manage that…
Points to note -:
  • Firstly - use at own risk :wink:
  • You MUST delete your existing things and add them back. Current definitions are not compatible due to a number of breaking changes. You don’t need to re-initialise the network or re-include devices - just delete the things and add back again.
  • If you have included secure devices you need to copy the network key over to the controller (don’t loose the key like I did tonight in all my messing around with deleting things to test the new version - tomorrows job will be to re-include my door lock!).
Any problems, please report here or raise an issue. Database definitions will need to be updated for locks to work as the additional classes will need to be added. My lock is here so you can see the door_lock channel. This will likely need to be added to other locks.
Happy testing ;).
