OH3: after migration old rules are full of errors (authorization failed, array element type mismatch...)
After migration 2.5.11 --> 3.0 I have a lot of error on my rules and I don’t understand how debug the problems, for example I have error
Script execution of rule with UID ‘system_status-1’ failed: An error occurred during the script execution: array element type mismatch in system_status
in a very old rule copied from a post about RPI3…
rule “CPU Temp Update”
Time cron “0 */1 * * * ?”
var resp = executeCommandLine(“cat /sys/class/thermal/thermal_zone0/temp”, 1000)
var cpu_temp = transform(“JS”, “milli.js”, resp)
postUpdate(CPU_Temp, cpu_temp)
Where is the mismatch?
and another type of error:
Script execution of rule with UID ‘casa-3’ failed: authorization failed in casa
in another rule copied from a post some year ago
rule “Update max and min temperatures”
Item Weather_OWM_TemperatureB changed or
Time cron “0 */30 * * * ?” or
System started
postUpdate(Weather_Temp_Max, Weather_OWM_TemperatureB.maximumSince(now.withHour(0).withMinute(0).withSecond(0)))
postUpdate(Weather_Temp_Min, Weather_OWM_TemperatureB.minimumSince(now.withHour(0).withMinute(0).withSecond(0)))
logInfo(“Weather”, “Temperature evolved of " + Weather_OWM_TemperatureB.deltaSince(now.minusMinutes(30)) + " degrees.”)
I’m going crazy
Can someone give me some indication?
How can I understand my errors?
thanks
Ale
  • Platform information:
    • Hardware: PI4/4G/32G
    • OS: openhabian
    • Java Runtime Environment: _openjdk version “11.0.9” 2020-10-20 LTS
      OpenJDK Runtime Environment Zulu11.43+88-CA (build 11.0.9+11-LTS)
      OpenJDK Client VM Zulu11.43+88-CA (build 11.0.9+11-LTS, mixed mode)
    • openHAB version: 3.0
  • Issue of the topic: please be detailed explaining your issue
    • Items configuration related to the issue
    • Sitemap configuration related to the issue
    • Rules code related to the issue
    • Services configuration related to the issue
  • If logs where generated please post these here using code fences:
The first one is most likely caused by the executeCommandLine which has changed a bit. See the docs for an example:
The second one uses now from the Jodatime library. OH3 no longer uses this library so you’ll need to change that. See the following topic for more information:
