I wanted to test the Fronius binding under OH3.
Unfortunately, the Fronius Bridge does not have an input field for the host name (IP).
The bridge does not initialize. Did I miss something?
Thanks for fixing the bug
I’m a beginner, working on OH3 on a Raspi 400 testing the Fronius binding 3.0.0.
I could use the binding to get a Fronius Bridge thing, set the IP and got a Fronius Symo inverter thing, both are online. I can read values like Day energy, Load Power … in the channels of the inverter.
I do have a datalogger down in the cellar, datalogger ID 240.318172 (Solarmeter 63A).
But in the binding no meter shows up to get a thing.
Things - blue + button - shows Fronius Bridge and Fronius Symo Inverter, but no Meter as suggested in the documentation.
What am I missing?
Do I have to add some other binding or add-on?
Is the Smartmeter possibly malconfigured in the Fronius setup?
I configured the smart meter as in the pictures and it worked immediately.
The binding offers the following devices:
bridge
Inverter
Smart meter
That did the job!
I forgot to set the Fronius bridge.
When creating the inverter this was done automagically, but obviously not in Meter!
I am now using the 3.1.0 version of
JimT
Quite often (about 30 times per hour) I get remarks in events.log:
2021-04-07 11:31:49.457 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'fronius:bridge:keller' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): hostname or ip is not reachable
2021-04-07 11:32:09.475 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'fronius:bridge:keller' changed from OFFLINE (COMMUNICATION_ERROR): hostname or ip is not reachable to ONLINE
The inverter is connected by ethernet cable (fritz.box → small switch → Fronius).
The powerwall, which is connected to the same switch, does not show similar errors.
The error occurs regardless of the type of connection of the raspi (cable or WIFi) .
Therefor I cannot use the data of the invertor in my charging scripts.
Hello!
Where can i download the add on?
I am using 3.1 M3 atm and it is not listed.
I wanted to give it a try but i cannot find the addon .jar.
Thank you
I would like to ask if there is a possibility to change the refreshInterval to fixed query times like:
every 5 minutes (12:00, 12:05, 12:10,…) to be able to have the data synchronized for example with a smart meter…
Any ideas on that :)?
Thank you
Yes, but that is not fixed to a certain time like described. If you set the refreshInterval 300 the data is not sent at specific times (not like 12:00, 12:05 - it could be 12:03, 12:08,…).
Ah I understand!
I don’t know how the synchronization with the SmartMeter looks like, but I would then e.g. query every minute and copy the value into a proxy item in a rule that runs exactly on your schedule.
With this one could then synchronize the data.
@Jonas88:
In 3.0.1 it shows up in the list you get under things - Install more bindings.
I did an upgrade: 3.0.1.1 → 3.0.1.2 → 3.1.0 M3
Fronius first showed up as uninitialized, I hat to add it again, seems to work.
But …
I have the binding of
JimT
copied in my /usr/share/openhab/addons which has version 3.1.0
Hi all,
I’ve got a question on the Fronius binding as well.
I have installed the binding and have created the Bridge, Smart meter and Symo Inverter things. So far, so good.
The Symo Inverter things works fine, but with the Smart meter thing, I have the issue that all values returned by the channels (powerrealphase1, …) are zero. The thing has a valid looking serial number, the model shows the correct type (Smart Meter TS 65A-3), so it seems the binding is able to communicate with the smart meter.
Any ideas here ?
Many thanks
Brandy
Can you please open this link on your browser and paste the result here:
http://%IP%/solar_api/v1/GetMeterRealtimeData.cgi?Scope=Device&DeviceId=0&DataCollection=MeterRealtimeData
Replace %IP%
with the ip address of your fronius device
this is what comes back (device id = 0):
Many thanks, Brandy
Body | |
Data | |
ACBRIDGE_CURRENT_ACTIVE_MEAN_01_F32 | 1.52 |
ACBRIDGE_CURRENT_ACTIVE_MEAN_02_F32 | -1.965 |
ACBRIDGE_CURRENT_ACTIVE_MEAN_03_F32 | -2.021 |
ACBRIDGE_CURRENT_AC_SUM_NOW_F64 | -2.466 |
ACBRIDGE_VOLTAGE_MEAN_12_F32 | 400.7 |
ACBRIDGE_VOLTAGE_MEAN_23_F32 | 397.5 |
ACBRIDGE_VOLTAGE_MEAN_31_F32 | 402.4 |
COMPONENTS_MODE_ENABLE_U16 | 1 |
COMPONENTS_MODE_VISIBLE_U16 | 1 |
COMPONENTS_TIME_STAMP_U64 | 1644325180 |
Details | |
Manufacturer | Fronius |
Model | Smart Meter TS 65A-3 |
Serial | 3550740957 |
GRID_FREQUENCY_MEAN_F32 | 50 |
SMARTMETER_ENERGYACTIVE_ABSOLUT_MINUS_F64 | 3189830 |
SMARTMETER_ENERGYACTIVE_ABSOLUT_PLUS_F64 | 1957120 |
SMARTMETER_ENERGYACTIVE_CONSUMED_SUM_F64 | 1957120 |
SMARTMETER_ENERGYACTIVE_PRODUCED_SUM_F64 | 3189830 |
SMARTMETER_ENERGYREACTIVE_CONSUMED_SUM_F64 | 2554678 |
SMARTMETER_ENERGYREACTIVE_PRODUCED_SUM_F64 | 493639 |
SMARTMETER_FACTOR_POWER_01_F64 | 0.992 |
SMARTMETER_FACTOR_POWER_02_F64 | -0.991 |
SMARTMETER_FACTOR_POWER_03_F64 | 0.998 |
SMARTMETER_FACTOR_POWER_SUM_F64 | -0.992 |
SMARTMETER_POWERACTIVE_01_F64 | 335 |
SMARTMETER_POWERACTIVE_02_F64 | -445.8 |
SMARTMETER_POWERACTIVE_03_F64 | -463.9 |
SMARTMETER_POWERACTIVE_MEAN_01_F64 | -499.6365448504982 |
SMARTMETER_POWERACTIVE_MEAN_02_F64 | -1275.8328903654478 |
SMARTMETER_POWERACTIVE_MEAN_03_F64 | 244.6508305647839 |
SMARTMETER_POWERACTIVE_MEAN_SUM_F64 | -574.8 |
SMARTMETER_POWERAPPARENT_01_F64 | 337.8 |
SMARTMETER_POWERAPPARENT_02_F64 | 449.8 |
SMARTMETER_POWERAPPARENT_03_F64 | 464.7 |
SMARTMETER_POWERAPPARENT_MEAN_01_F64 | 610.6837209302328 |
SMARTMETER_POWERAPPARENT_MEAN_02_F64 | 1325.1717607973417 |
SMARTMETER_POWERAPPARENT_MEAN_03_F64 | 1185.0568106312296 |
SMARTMETER_POWERAPPARENT_MEAN_SUM_F64 | 1252.4 |
SMARTMETER_POWERREACTIVE_01_F64 | -43.4 |
SMARTMETER_POWERREACTIVE_02_F64 | -59.5 |
SMARTMETER_POWERREACTIVE_03_F64 | 27.6 |
SMARTMETER_POWERREACTIVE_MEAN_SUM_F64 | -75.4 |
SMARTMETER_VALUE_LOCATION_U16 | 0 |
SMARTMETER_VOLTAGE_01_F64 | 231.9 |
SMARTMETER_VOLTAGE_02_F64 | 230.9 |
SMARTMETER_VOLTAGE_03_F64 | 230.5 |
SMARTMETER_VOLTAGE_MEAN_01_F64 | 232.36212624584707 |
SMARTMETER_VOLTAGE_MEAN_02_F64 | 231.48704318936893 |
SMARTMETER_VOLTAGE_MEAN_03_F64 | 228.83920265780753 |
Head | |
RequestArguments | |
DeviceClass | Meter |
DeviceId | 0 |
Scope | Device |
Status | |
Code | 0 |
Reason | |
UserMessage | |
Timestamp | 2022-02-08T12:59:41+00:00 |
Thanks! Could you please paste the raw JSON, and enclose it in triple backticks (code fence)
"Body" : {
"Data" : {
"ACBRIDGE_CURRENT_ACTIVE_MEAN_01_F32" : 3.9510000000000001,
"ACBRIDGE_CURRENT_ACTIVE_MEAN_02_F32" : -7.5899999999999999,
"ACBRIDGE_CURRENT_ACTIVE_MEAN_03_F32" : -7.0250000000000004,
"ACBRIDGE_CURRENT_AC_SUM_NOW_F64" : -10.664,
"ACBRIDGE_VOLTAGE_MEAN_12_F32" : 402.10000000000002,
"ACBRIDGE_VOLTAGE_MEAN_23_F32" : 393.89999999999998,
"ACBRIDGE_VOLTAGE_MEAN_31_F32" : 401.0,
"COMPONENTS_MODE_ENABLE_U16" : 1.0,
"COMPONENTS_MODE_VISIBLE_U16" : 1.0,
"COMPONENTS_TIME_STAMP_U64" : 1644326328.0,
"Details" : {
"Manufacturer" : "Fronius",
"Model" : "Smart Meter TS 65A-3",
"Serial" : "3550740957"
"GRID_FREQUENCY_MEAN_F32" : 49.899999999999999,
"SMARTMETER_ENERGYACTIVE_ABSOLUT_MINUS_F64" : 3190110.0,
"SMARTMETER_ENERGYACTIVE_ABSOLUT_PLUS_F64" : 1957135.0,
"SMARTMETER_ENERGYACTIVE_CONSUMED_SUM_F64" : 1957135.0,
"SMARTMETER_ENERGYACTIVE_PRODUCED_SUM_F64" : 3190110.0,
"SMARTMETER_ENERGYREACTIVE_CONSUMED_SUM_F64" : 2555222.0,
"SMARTMETER_ENERGYREACTIVE_PRODUCED_SUM_F64" : 493641.0,
"SMARTMETER_FACTOR_POWER_01_F64" : -0.59699999999999998,
"SMARTMETER_FACTOR_POWER_02_F64" : 0.94099999999999995,
"SMARTMETER_FACTOR_POWER_03_F64" : 0.089999999999999997,
"SMARTMETER_FACTOR_POWER_SUM_F64" : 0.41199999999999998,
"SMARTMETER_POWERACTIVE_01_F64" : 543.89999999999998,
"SMARTMETER_POWERACTIVE_02_F64" : -1644.7,
"SMARTMETER_POWERACTIVE_03_F64" : -124.8,
"SMARTMETER_POWERACTIVE_MEAN_01_F64" : 896.16333333333387,
"SMARTMETER_POWERACTIVE_MEAN_02_F64" : -1308.6926666666659,
"SMARTMETER_POWERACTIVE_MEAN_03_F64" : -371.48033333333325,
"SMARTMETER_POWERACTIVE_MEAN_SUM_F64" : -1225.5999999999999,
"SMARTMETER_POWERAPPARENT_01_F64" : 910.39999999999998,
"SMARTMETER_POWERAPPARENT_02_F64" : 1747.7,
"SMARTMETER_POWERAPPARENT_03_F64" : 1392.0999999999999,
"SMARTMETER_POWERAPPARENT_MEAN_01_F64" : 1049.5296666666666,
"SMARTMETER_POWERAPPARENT_MEAN_02_F64" : 1352.2953333333328,
"SMARTMETER_POWERAPPARENT_MEAN_03_F64" : 1198.6346666666675,
"SMARTMETER_POWERAPPARENT_MEAN_SUM_F64" : 4050.3000000000002,
"SMARTMETER_POWERREACTIVE_01_F64" : 730.0,
"SMARTMETER_POWERREACTIVE_02_F64" : 591.20000000000005,
"SMARTMETER_POWERREACTIVE_03_F64" : 1386.5,
"SMARTMETER_POWERREACTIVE_MEAN_SUM_F64" : 2707.9000000000001,
"SMARTMETER_VALUE_LOCATION_U16" : 0.0,
"SMARTMETER_VOLTAGE_01_F64" : 231.59999999999999,
"SMARTMETER_VOLTAGE_02_F64" : 230.40000000000001,
"SMARTMETER_VOLTAGE_03_F64" : 229.19999999999999,
"SMARTMETER_VOLTAGE_MEAN_01_F64" : 232.21633333333332,
"SMARTMETER_VOLTAGE_MEAN_02_F64" : 232.00266666666664,
"SMARTMETER_VOLTAGE_MEAN_03_F64" : 231.04800000000003
"Head" : {
"RequestArguments" : {
"DeviceClass" : "Meter",
"DeviceId" : "0",
"Scope" : "Device"
"Status" : {
"Code" : 0,
"Reason" : "",
"UserMessage" : ""
"Timestamp" : "2022-02-08T13:18:48+00:00"
@Ez2517 Please try this JAR:
To install, simply drop this jar file into your addons folder. It should override your existing binding.
To verify that you’ve got the right binding installed, check the version number below
bundle:list -s | grep froni
237 │ Active │ 80 │ 3.3.0.202202081345 │ org.openhab.binding.fronius
Let me know the result either way. If it works, I will submit the changes to be included into openhab-addons.
