I am using OH3 Automower binding to control an automower but for some reason when sending a Pause/ResumeSchedule command (to pause when it’s raining) the binding doesn’t seem to send the command. The log shows this:
09:58:19.428 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'HoraceWoodsAutomower_ResumeSchedule' received command ON
09:58:19.429 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item 'HoraceWoodsAutomower_ResumeSchedule' predicted to become ON
09:58:19.430 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'HoraceWoodsAutomower_ResumeSchedule' changed from NULL to ON
If I send the command through the Husqvarna API it works and the status is reflected in the thing status.
Ok so the resume_schedule, pause, park, park_until_next_schedule and park_until_further_notice switch channels created don’t seem to do anything even if they are linked to an item.
I needed to execute a script action per the docs.
val mowerActions = getActions("automower", "automower:automower:mybridge:myAutomower")
mowerActions.parkUntilFurtherNotice()
The channels in the docs caused me to not read to the bottom and read the script actions
I am unsure whether there is a bug with the channel switches or whether they should be removed.
