just one short question from my side. Does anybody know (or has tried it him- or herself) whether it’s still possible to place binding files in JAR format directly into the addons folder? (In my case OH seems to ignore the files.) I’m using OH3 M2 in the docker-alpine container.
Thank you for your reply. I’m aware of that difference but I’m testing some bindings in different constellations/environments and have been assuming that the java version shouldn’t have any influence on the addons folder handling. Am I wrong?
Are you sure you select the right folder? It works for me on Debian (not docker) and Windows, so very unlikely it doesn‘t work in another Debian environment.
Thank you four response - I really appreciate that. Both bindings were taken from the 3.0.0-snapshot branch. In case of incompatible binding files shouldn’t there be any comment in openhab.log?
Btw. I’ve read your gread summary concerning 3.x Bindings:
I should point out that when a jar is in the addons folder of openhab 3, it does not show up in the installed list. It is best to look for it in the INBOX and pressing the PLUS icon. I raised this on GitHub as an issue.
Maybe you could add some details concerning your problem:
What binding are you talking about?
Does the binding version match the OH-version?
If the binding is not compatible (maybe wrongly compiled) the binding will not start and you will get no information openhab.log. If the version is correct but there is a dependency error during initialization you should see an error in openhab.log
