Sorry guys,
I have finally decided to try install OH on my Raspberry pi 4 and I am stuck in the manual installation steps (need to run other stuff on Pi so Openhabian is not a good choice for me)
Problem is the installation of Zulu 11.
first question is: is it really required or the java which comes with the latest raspbian img suffices? Because otherwise I won’t spoil further time in this (and yours as well)
current status is
$ java -version
openjdk version “11.0.9.1” 2020-11-04
OpenJDK Runtime Environment (build 11.0.9.1+1-post-Raspbian-1deb10u2)
OpenJDK Server VM (build 11.0.9.1+1-post-Raspbian-1deb10u2, mixed mode)
Supposing Zulu 11 really needs to be installed,
I have tried to follow the manual installation steps in https://www.openhab.org/docs/installation/rasppi.html
in particular where it mentions
Please refer to the Linux article for instructions on how to install the latest Java 11 revision.`
which jumps to the totally unclear (to me) section Meeting the Requirements
to cut the long story short, after squandering some more time in the ocean of pages of azul.com, I understood that to install Zulu on armhf the only way seems to be doing it through tar.gz
So I downloaded zulu11.43.100-ca-jdk11.0.9.1-linux_aarch32hf.tar from here and I am trying to follow the instructions found here, that is
- Download the installation package from Azul Downloads.
- Extract the downloaded
<zulu_package>.tar.gzfile.tar -xzvf <zulu_package>.tar.gzThe command extracts all Zulu files into the<zulu_package>folder in the current directory.- Verify your Zulu installation.
which is missing the installation step I guess, as I end up with a bunch of files in a folder not installed.
So, what should I do to install it? Does anybody know?
Should I follow the directions I read in this thread which is marked outdated - and mentions a change request which should include this in the OH3 UI?
I also tried to install using SDKMAN as follows
install SDK MAN
curl -s "https://get.sdkman.io" | bash
and then
source "/home/pi/.sdkman/bin/sdkman-init.sh" -
list the javas
sdk list java
I gort something like
Available Java VersionsVendor Use | Version | Dist | Status | Identifier
** Azul Zulu | | 15.0.1 | zulu | | 15.0.1-zulu**
** | | 15.0.1.fx | zulu | | 15.0.1.fx-zulu**
** | | 14.0.2 | zulu | | 14.0.2-zulu**
** | | 14.0.2.fx | zulu | | 14.0.2.fx-zulu**
** | | 13.0.5 | zulu | | 13.0.5-zulu**
** | | 13.0.5.fx | zulu | | 13.0.5.fx-zulu**
** | | 12.0.2 | zulu | | 12.0.2-zulu**
** | | 11.0.9 | zulu | | 11.0.9-zulu**
** | | 11.0.9.fx | zulu | | 11.0.9.fx-zulu**
** | | 10.0.2 | zulu | | 10.0.2-zulu**
** | | 9.0.7 | zulu | | 9.0.7-zulu**
** | | 8.0.275 | zulu | | 8.0.275-zulu**
** | | 8.0.275.fx | zulu | | 8.0.275.fx-zulu**
** | | 7.0.282 | zulu | | 7.0.282-zulu**
** | | 6.0.119 | zulu | | 6.0.119-zulu**
** BellSoft | | 15.0.1.fx | librca | | 15.0.1.fx-librca**
Use the Identifier for installation: $ sdk install java 11.0.3.hs-adpt
I used
sdk install java 11.0.9-zulu
which seems to be successfull and it is even telling me that it has changed the default java, unfortunately when I do
sudo update-alternatives --config java
I get this demeaning reply
There is only one alternative in link group java (providing /usr/bin/java): /usr/lib/jvm/java-11-openjdk-armhf/bin/java
so I am totally confused and don’t know what else to try.
Did anyone already go through this ordeal??
