Fresh install of OH3, no icons are showing anywhere.
From my understanding, using categories should show the icon. This is straight from the installation instructions walkthrough
Besides my problem with some icons not shown ([SOLVED][OH3] Icons "hidden" after reboot) , i also realiized this right now (but it did work before)
Is firstfloor working in your setup? Because groundfloor is not but firstfloor is showing an icon.
Iβve found the problem with my system:
Some bundles were stopped. Can you log onto the openhab console
(ssh to your raspi if you have one) and type
sudo openhab-cli console
password is habopen
type
bundle:list
and check if the icon set bundle is running (openHAB UI :: Bundles :: Icon Set :: Classic
I dont actually have that bundle listed at all
openhab> bundle:list
START LEVEL 100 , List Threshold: 50
ID β State β Lvl β Version β Name
βββββΌβββββββββΌββββββΌββββββββββββββββββββββββββΌββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ
22 β Active β 80 β 2.10.3 β Jackson-annotations
23 β Active β 80 β 2.10.3 β Jackson-core
24 β Active β 80 β 2.10.3 β jackson-databind
25 β Active β 80 β 2.10.3 β Jackson-dataformat-YAML
26 β Active β 80 β 2.10.3 β Jackson datatype: JSR310
27 β Active β 80 β 2.8.2.v20180104-1110 β Gson: Google Json Library for Java
28 β Active β 80 β 27.1.0.jre β Guava: Google Core Libraries for Java
29 β Active β 80 β 1.0.1 β Guava InternalFutureFailureAccess and InternalFutures
30 β Active β 80 β 3.0.0.v201312141243 β Google Guice (No AOP)
31 β Active β 80 β 4.8.35.v20190528-1517 β ClassGraph
32 β Active β 80 β 2.1.0 β swagger-annotations
33 β Active β 80 β 2.1.0 β swagger-core
34 β Active β 80 β 2.1.0 β swagger-integration
35 β Active β 80 β 2.1.0 β swagger-jaxrs2
36 β Active β 80 β 2.1.0 β swagger-models
38 β Active β 80 β 3.5.6 β JmDNS
39 β Active β 80 β 1.0.0 β Units of Measurement API
41 β Active β 80 β 1.1.0.Final β Bean Validation API
43 β Active β 80 β 0.5.10 β Jollyday
44 β Active β 80 β 3.2.0.v201101311130 β ANTLR Runtime
45 β Active β 80 β 1.0.1 β Apache Aries JAX-RS Specification API
46 β Active β 80 β 1.0.9 β Apache Aries JAX-RS Whiteboard
48 β Active β 80 β 3.11.0 β Apache Commons Lang
57 β Active β 80 β 4.2.7 β Apache Karaf :: OSGi Services :: Event
68 β Active β 80 β 1.0.0.2 β Apache ServiceMix :: Bundles :: javax.inject
72 β Active β 80 β 1.3.0.1 β Apache ServiceMix :: Specs :: Annotation API 1.3
73 β Active β 80 β 2.3.0.3 β Apache ServiceMix :: Specs :: JAXWS API 2.3
76 β Active β 80 β 4.14.0 β Apache XBean OSGI Bundle Utilities
77 β Active β 80 β 4.14.0 β Apache XBean :: Classpath Resource Finder
78 β Active β 80 β 0.7.0 β jose4j
79 β Active β 80 β 2.17.0.v20190920-0401 β EMF Common
80 β Active β 80 β 2.20.0.v20190920-0401 β EMF Ecore
81 β Active β 80 β 2.14.0.v20190528-0725 β EMF Change Model
82 β Active β 80 β 2.16.0.v20190528-0725 β EMF XML/XMI Persistence
83 β Active β 80 β 3.10.400.v20190516-1504 β Common Eclipse Runtime
112 β Active β 80 β 0.9.0.v20200229-1009 β org.eclipse.lsp4j
113 β Active β 80 β 0.9.0.v20200229-1009 β org.eclipse.lsp4j.jsonrpc
114 β Active β 80 β 2.23.0.v20200831-0723 β Xtend Runtime Library
115 β Active β 80 β 2.23.0.v20200831-0723 β Xtend Macro Interfaces
116 β Active β 80 β 2.23.0.v20200831-0730 β Xtext
117 β Active β 80 β 2.23.0.v20200831-0745 β Xtext Common Types
118 β Active β 80 β 2.23.0.v20200831-0730 β Xtext IDE Core
119 β Active β 80 β 2.23.0.v20200831-0730 β Xtext Utility
120 β Active β 80 β 2.23.0.v20200831-0745 β Xbase Model
121 β Active β 80 β 2.23.0.v20200831-0745 β Xbase Generic IDE Services
122 β Active β 80 β 2.23.0.v20200831-0723 β Xbase Runtime Library
124 β Active β 80 β 7.1.0 β org.objectweb.asm
126 β Active β 80 β 7.1.0 β org.objectweb.asm.commons
127 β Active β 80 β 7.1.0 β org.objectweb.asm.tree
128 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: Core
129 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: Audio
130 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: JAAS Authentication
131 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: OAuth2Client
132 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: Automation
133 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: Automation Media Modules
134 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: Automation Script Modules
135 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: Automation Script RuleSupport
136 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: Automation REST API
137 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: Binding XML
138 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: Configuration Core
139 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: Configuration Discovery
140 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: Configuration mDNS Discovery
141 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: Configuration Dispatcher
142 β Active β 75 β 3.0.0 β openHAB Core :: Bundles :: Configuration XML
143 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: Ephemeris
144 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: ID
145 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: Console
146 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: Console for OSGi runtime Karaf
147 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: HTTP Interface
148 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: HTTP Interface Authentication
150 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: Monitor
151 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: Network I/O
152 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: REST Interface
153 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: Audio REST Interface
154 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: Authentication Support for the REST Interface
155 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: REST Interface :: Core
156 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: REST mDNS Announcer
157 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: Sitemap REST Interface
158 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: SSE Interface
159 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: REST Interface :: Swagger 1
160 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: UI REST Interface
161 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: Voice REST Interface
162 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: mDNS Service
163 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: Karaf Integration
164 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: Model Core
165 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: Model Items
166 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: Model Item IDE
167 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: Model Items Runtime
168 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: Language Server
169 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: Model Persistence
170 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: Model Persistence IDE
171 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: Model Persistence Runtime
172 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: Model Rules
173 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: Model Rule IDE
174 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: Model Rules Runtime
175 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: Model Script
176 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: Model Script IDE
177 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: Model Script Runtime
178 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: Model Sitemap
179 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: Model Sitemap IDE
180 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: Model Sitemap Runtime
181 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: Model Thing
182 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: Model Thing IDE
183 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: Model Thing Runtime
184 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: Persistence
185 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: Semantics
186 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: JSON Storage
187 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: Thing
188 β Active β 75 β 3.0.0 β openHAB Core :: Bundles :: Thing XML
189 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: Transformation Service
190 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: UI
191 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: UI Icon Support
192 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: Voice
193 β Active β 80 β 3.0.0 β openHAB UI :: Bundles :: Main UI
200 β Active β 80 β 1.0.0.201802012106 β org.osgi:org.osgi.service.jaxrs
201 β Active β 80 β 1.1.0.201802012106 β org.osgi:org.osgi.util.function
202 β Active β 80 β 1.1.0.201802012106 β org.osgi:org.osgi.util.promise
203 β Active β 80 β 1.5.0 β ThreeTen-Extra
204 β Active β 80 β 1.26.0 β SnakeYAML
205 β Active β 80 β 1.0.3 β Units of Measurement Common Library
206 β Active β 80 β 1.0.10 β Units of Measurement Implementation for Java SE
207 β Active β 80 β 1.4.13 β XStream Core
208 β Active β 80 β 2.5.2 β JUPnP Library
210 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: Configuration UPnP Discovery
211 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: UPnP Transport
212 β Active β 80 β 2.6 β Commons Lang
213 β Active β 80 β 3.0.0 β openHAB Add-ons :: Bundles :: Yamaha Receiver Binding
214 β Active β 80 β 3.0.0 β openHAB Add-ons :: Bundles :: SamsungTV Binding
215 β Active β 80 β 3.0.0 β openHAB Add-ons :: Bundles :: Xiaomi Mi Smart Home Binding
216 β Active β 80 β 2.20 β Dagger
217 β Active β 80 β 1.1.2 β hivemq-mqtt-client
218 β Active β 80 β 4.1.42.Final β Netty/Buffer
219 β Active β 80 β 4.1.42.Final β Netty/Codec
220 β Active β 80 β 4.1.42.Final β Netty/Codec/HTTP
221 β Active β 80 β 4.1.42.Final β Netty/Common
222 β Active β 80 β 4.1.42.Final β Netty/Handler
223 β Active β 80 β 4.1.42.Final β Netty/Resolver
224 β Active β 80 β 4.1.42.Final β Netty/Transport
225 β Active β 80 β 4.1.42.Final β Netty/Transport/Native/Epoll
226 β Active β 80 β 4.1.42.Final β Netty/Transport/Native/Unix/Common
227 β Active β 80 β 2.2.5 β rxjava
228 β Active β 80 β 2.1.2 β Java Concurrency Tools Core Library
229 β Active β 80 β 3.0.0 β openHAB Add-ons :: Bundles :: MQTT Broker Binding
230 β Active β 81 β 3.0.0 β openHAB Add-ons :: Bundles :: MQTT Things and Channels
231 β Active β 82 β 3.0.0 β openHAB Add-ons :: Bundles :: MQTT HomeAssistant Convention
232 β Active β 82 β 3.0.0 β openHAB Add-ons :: Bundles :: MQTT Homie Convention
233 β Active β 80 β 3.0.0 β openHAB Core :: Bundles :: MQTT Transport
234 β Active β 80 β 1.0.2 β reactive-streams
235 β Active β 80 β 3.0.0 β openHAB Add-ons :: Bundles :: Remote openHAB Binding
236 β Active β 75 β 3.0.0 β openHAB Add-ons :: Bundles :: Transformation Service :: Map
238 β Active β 80 β 3.0.0 β openHAB Add-ons :: Bundles :: Konnected Binding
strange - how did you install openhab?
using etcher. from the download file on the website
Sorted
