Props are not saved in “Widgets” section - this is where you edit your widget and you can set some temporary props to see whether the widget works properly.
You need to go to the page on which you use the widget and set props there. Don’t forget to save the page.
Please double check whether you followed the guideline from this topic .
in1t5
(init5)
November 19, 2022, 7:29pm
64
What a bummer. I was not aware of that. Thanks a lot. Works out of the box.
Do you have some screenshots of your UIs somewhere?
DeBaschdi
(Bastian )
March 22, 2023, 3:46am
65
Great Widget!
maybe someone can help including a datepicker “Kalender”?
uid: Grafana chart with timeranges
tags: []
props:
parameters:
- description: Title of the chart
label: Title
required: false
type: TEXT
- description: URL to show in the frame
label: Source URL
- default: https://xxxx.de/solaranzeige/d-solo/KyT4EHHVz/eiche-10?orgId=1&refresh=5s&{period}&panelId=118"
required: true
type: TEXT
- default: from=now%2Fd&to=now%2Fd;Heute,from=now-1d%2Fd&to=now-1d%2Fd;Gestern,from=now-2d%2Fd&to=now-2d%2Fd;Vorgestern,from=now-3d&to=now;Die letzten 3 Tage,from=now-7d&to=now;Die letzten 7 Tage,from=now-14d&to=now;Kalender
description: Comma-separated List of options. Example "from=now-6h&to=now;-6h,from=now-1d/d&to=now-1d/d;yesterday" for past "6h" and "yesterday". First entry is default.
label: Time range options
required: true
type: TEXT
- description: Height of the Frame (empty = default)
label: Height
required: false
type: TEXT
parameterGroups: []
timestamp: Mar 22, 2023, 4:21:08 AM
component: f7-card
title: =props.title
outline: true
style:
--f7-card-margin-horizontal: 10px
--f7-card-margin-vertical: 3px
--f7-card-padding-horizontal: 10px
--f7-card-padding-vertical: 100px
margin-top: 10px
margin-bottom: 10px
noShadow: false
box-shadow: 5px 5px 10px 1px rgba(0,0,0,0.3)
slots:
default:
- component: oh-webframe-card
borders: false
noBorder: false
noShadow: true
height: =props.height
src: =props.URL.replace('{period}', vars.selectedPeriod || [props.timerange.split(',')[0].split(';')[0]])
class:
- display-block
- component: f7-segmented
round: false
outline: false
class:
- padding-bottom-half
style:
margin-left: 10px
margin-right: 10px
--f7-button-font-size: 14px
--f7-button-text-color: "=themeOptions.dark === 'light' ? 'black' : 'white'"
--f7-button-text-transform: none
--f7-button-border-radius: 4px
--f7-button-outline-border-width: 1px
--f7-button-font-weight: 300
--f7-button-padding-vertical: 0px
--f7-button-padding-horizontal: 0px
slots:
default:
- component: oh-repeater
sourceType: range
for: size
fragment: true
slots:
default:
fragment: true
for: period
in: =[props.timerange.split(",")[loop.size].split(";")[1]]
slots:
default:
- component: oh-button
text: =loop.period
fill: "=(([props.timerange.split(',')[loop.size].split(';')[0]] == vars.selectedPeriod) || (props.timerange.split(',')[0].split(';')[1] === loop.period) && !vars.selectedPeriod) ? true : false"
round: false
outline: true
style:
--f7-button-border-color: var(--f7-card-outline-border-color)
action: variable
actionVariable: selectedPeriod
actionVariableValue: =props.timerange.split(",")[loop.size].split(";")[0]
