- Platform information:
- Hardware: Odroid XU4
- OS: Ubuntu 20.04
- Java Runtime Environment: 11
- openHAB version: OH Snapshot release
I always need two attempts to install the newest OH3 snapshot release on my odroid.
When I try to do an update it always says:
dpkg: Fehler beim Bearbeiten des Paketes openhab (--configure):
»installiertes openhab-Skript des Paketes post-installation«-Unterprozess gab den Fehlerwert 1 zurück
Trigger für systemd (245.4-4ubuntu3.3) werden verarbeitet ...
Fehler traten auf beim Bearbeiten von:
openhab
E: Sub-process /usr/bin/dpkg returned an error code (1)
Then I start the installation again and there are no errors and the installation is working.
I added the messages in the console here:
frist attempt.txt (4.8 KB) second attempt.txt (764 Bytes)
Do you have an idea? Ther seems to be similar problems in the past:
