[OH3] Main UI - main_widget - part 3 - The Light Card [3.3.0;3.4.9)
The Lights widget card used by main_widget will show all kind of lights equipment in a selected room and show controlls based on equipment group members.
Usage
All lights need to have their own Group (Group->Equipment->Lightbulb), even they just have a Switch Item.
  • Equipment Group
    • Type: Group
    • Category: light od lightbulb (not used)
    • Semantic Class: Lightbulb
  • Switch Item
    • Type : Switch
    • Category: light or lightbulb (not used)
    • Semantic Class: Point
    • Semantic Property: Switch
For a dimmable or color light, the following Items can be configured.
  • Dimmer Item (Brightness)
    • Type: Dimmer
    • Category: slider
    • Semantic Property: None
  • Color Item (Color control)
    • Type: Color
    • Category: colorlight
For a „fancy“ naming, the widget makes use of the uiSemantics.
Information on usage/configuration can be founde here
Changelog
Version 0.2.1
  • Documentation updated
Version 0.2
  • New design, added color control
Version 0.1
  • Layout changes
Version 0.1
  • initial release
Resources
uid: main_widget_Light_Card
tags: []
props:
  parameters:
    - context: item
      description: Light Equipment Group
      label: Light Equipment Group
      required: false
      type: TEXT
    - context: item
      description: Light Power Item
      label: Light Power Item
      required: false
      type: TEXT
timestamp: Oct 6, 2022, 12:03:46 PM
component: f7-block
  style:
    padding: 0px
    border-top-left-radius: var(--f7-card-expandable-border-radius)
    border-top-right-radius: var(--f7-card-expandable-border-radius)
    border-bottom-left-radius: var(--f7-card-expandable-border-radius)
    border-bottom-right-radius: var(--f7-card-expandable-border-radius)
    box-shadow: 5px 5px 15px 1px rgba(0,0,0,0.05)
    background: RGB(247, 247, 247)
slots:
  default:
    - component: f7-block
        style:
          height: 60px
          display: flex
          flex-direction: row
          align-items: center
      slots:
        default:
          - component: oh-icon
              icon: f7:lightbulb_fill
              width: 40px
              style:
                color: '=items[props.powerItem].state=="ON" ? "yellow" : "gray"'
          - component: f7-row
              style:
                display: flex
                flex-direction: row
                justify-content: flex-end
                align-self: flex-end
                flex-wrap: nowrap
                flex: 1 1 auto
            slots:
              default:
                - component: Label
                    text: =props.groupItem
                - component: f7-row
                    style:
                      display: flex
                      flex-direction: row
                      flex-wrap: nowrap
                      flex: 1 1 auto
                  slots:
                    default:
                      - component: oh-toggle
                          item: =props.powerItem
                          color: orange
                          style:
                            display: flex
                            flex-direction: row
    - component: oh-repeater
        fetchMetadata: semantics,metadata,listWidget
        for: dimmerItem
        groupItem: =props.groupItem
        sourceType: itemsInGroup
        filter: '(loop.dimmerItem.type=="Dimmer") ? true : false'
      slots:
        default:
          - component: f7-card-content
              style:
                margin-bottom: -1rem
                --f7-range-bar-size: 2px
                --f7-range-bar-border-radius: 0
                --f7-range-bar-border-color: rgba(0, 0, 0, 0.2)
                --f7-range-knob-size: 25px
                --f7-range-knob-color: white
                --f7-range-knob-box-shadow: none
                --f7-range-bar-active-bg-color: transparent
              stylesheet: >
                .range-bar  {
                  opacity: 0.3;
                } .range-knob {
                  border-color: rgba(0, 0, 0, 0.3);
                  border-width: 2px;
                  border-style: solid;
            slots:
              default:
                - component: Label
                    text: Brightness
                    style:
                      color: black
                      font-size: 13px
                      font-weight: var(--f7-list-item-footer-font-weight)
                      margin-left: 1rem
                      line-height: 0.5
                    visible: =items[props.powerItem].state=="ON"
                - component: oh-slider
                    item: =loop.dimmerItem.name
                    min: 0
                    max: 100
                    style:
                      width: calc(100% - 1rem)
                      margin-top: 15px
        for: colorItem
        filter: '(loop.colorItem.type=="Color") ? true : false'
      slots:
        default:
          - component: Label
              text: RGB Colors
              style:
                color: black
                font-size: 13px
                margin-left: 2rem
                line-height: 0.5
                margin-top: 15px
          - component: oh-colorpicker
              item: =loop.colorItem.name
              modules:
                - rgb-sliders
              style:
        style:
          height: 50px
          background: RGB(242, 242, 242)
          border-radius: 0 0 var(--f7-card-expandable-border-radius) var(--f7-card-expandable-border-radius)
          --f7-card-footer-border-color: transparent
          display: flex
          flex-direction: row
          flex-wrap: nowrap
          align-items: center
      slots:
        default:
          - component: oh-link
              visible: false```
