@hmerk wow! WOW! It seems like a fully loaded security app!! Definitely many+++ for the OH platform. Now, the “fancy stuff” sticks with your widget!
@JustinG @rlkoshak @hmerk
Dear Gents.
My first approach to design a scene it was a simple card with a ON-OFF switch, showing only which types (from semantic model) participating in the scene.
Having read some of your post (5% I think) and understanding the 10% of 5%, I realized the complexity of a simple scene.
Without having the knowledge, Im trying to put in a card all required functions? /variables? etc. My goal is to design an OH Scene card that would be easy for a user to have the control of the mechanism… As you already understand, i don’t know what exactly I want. In my eyes, the scene now has became a rule.
I cant see the logical issues or problems that this design may have, so I’m asking for help to find out if this is a start to build something or its a not efficient way of thinking.
Dooh,
I like that design, but …
Think we need to talk to better understand what you want, how it should work and then start thinking, if that is possible.
It will be very difficult to sort this out via messages here.
Or, we should postpone the scene implementation for a while, as there are some heavy discussions ongoing around that topic and a first PR is created to implement something in the core…
I agree with hmerk: it’s best to wait on trying to implement scene components.
There’s plenty of other work to do on this at the moment to get a first version ready for release to users. If it first gets released without the ability to work with scenes, that’s fine, it will offer enough other benefits that people will still want to try it. You can always add more functionality, such as scenes, at a later point (once you begin development on a project like this, you’ll never run out of things to do if you’re willing to keep up the commitment).
To answer your question a little bit from a design perspective, I would caution against trying to pack too much into a card. There are definite advantages to having every piece of information about something in one place and this should always be a priority, but that place doesn’t have to be (shouldn’t be) so small that the information is too dense to be usable. If the idea is to make a UI that is convenient, you have to also think about the actual interaction.
Yes, putting all scene information on one card means that it’s only one click away for the user. But if all the components are too small to be reliably targeted with a finger on a phone screen, then that one click turns into 4 or 5 or more just to push the one button of interest (not to mention increasing the chances that one of those clicks triggers an undesired action). If instead, clicking on the small card expands to a card with only the next layer of most useful interactions and a link to a whole configuration page then sometimes there is one extra click for the user, but never a frustrating series of repetitive clicks trying to get one component to function.
@Nic0205
Could you please try and change the bottom tabs from oh-button to oh-link.
This will be needed to add the iconBadges with e.g. information on alarm counter….
Sure, I will have a look…
Understood… Let’s go with the classic on-off switch for scenes.
Εαν κέρδιζες ένα ευρώ γαι κάθε σου απάντηση, θα ήσουν πλούσιος εκτός απο σοφός που ήδη είσαι.
Σε ευχαριστώ Δάσκαλε που στηρίζεις αυτήν την ομάδα!
@Dimitris English please
Google translated to this:
If you earned a euro for every answer you gave, you would be rich in addition to being wise as you already are.
Thank you Master for supporting this team!
Kudos go to @JustinG …
Hi at all,
just following your discussion a while and wanted to start with testing this absolute amazing looking widget.
I tried to install from the marketplace but unfortunately without any success. I get an error in the log as follows:
2022-09-28 20:46:22.692 [ERROR] [munity.CommunityUIWidgetAddonHandler] - Unable to parse YAML: Unrecognized field "blocks" (class org.openhab.core.ui.components.RootUIComponent), not marked as ignorable (7 known properties: "uid", "config", "slots", "timestamp", "tags", "component", "props"])
at [Source: (StringReader); line: 12, column: 3] (through reference chain: org.openhab.core.ui.components.RootUIComponent["blocks"])
2022-09-28 20:46:22.693 [ERROR] [munity.CommunityUIWidgetAddonHandler] - Widget from marketplace is invalid: Unable to parse YAML
I’m running openHAB 3.3.0 Release Build.
Does anyone have an idea what’s might the problem?
Best regards
Stefan
There might be an issue with the timestamp line in the code.
As this will change a lot in the near future, please copy the code and add it manually into your openhab installation.
I changed the bottom navbars to oh-link.
For some reason the stylesheet for the unselected items does not have any effect for now. I will have a further look at it tomorrow. Perhaps I simple missed a bracked or something.
@hmerk, @JustinG : if you see something at once why the unselected_bottom_navbar_item
is not interpreted correct - please let me know.
uid: main_widget
tags: []
props:
parameters:
- description: Set default color for Text
label: Text color
required: false
type: TEXT
- default: RGB(96, 96, 96)
label: Bottom-Navbar-Color
required: false
type: TEXT
- default: Somewhere
description: Name for your weather location
label: Weather Location
required: false
type: TEXT
- context: item
description: Name of scenes group item
label: Scenes Group
required: false
type: TEXT
- context: item
description: Name of security group item
label: Security Group
required: false
type: TEXT
- context: item
description: Security Mode Item
label: Security Mode
required: false
type: TEXT
- context: item
description: Security PIN Item
label: Security PIN
required: false
type: TEXT
parameterGroups: []
timestamp: Sep 28, 2022, 9:54:10 PM
component: f7-block
style:
display: flex
flex-direction: column
height: calc(100vh - var(--f7-toolbar-height) - var(--f7-safe-area-bottom) - var(--f7-safe-area-top))
justify-content: space-between
margin: 0
padding: 0
width: 100%
background: =(themeOptions.dark=="light") ? ("white"):("black")
--menu-text-color: '= (!props.textColor) ? (themeOptions.dark=="light")? black : white : props.textColor'
--f7-button-text-color: "#8c8c8c"
--opmw-menu-text-color: =(themeOptions.dark=="light")?("#8C8C8C"):("#848484")
stylesheet: >
.selected_menu_item {
color: var(--menu-text-color);
text-decoration-color: #F8BB00 !important;
text-decoration: underline;
text-underline-offset: 2.px;
font-weight: bold;
.unselected_menu_item {
color: #8C8C8C;
font-weight: 300;
.selected_bottom_navbar_item {
color: white;
font-size: 12px;
height: auto;
.unselected_bottom_navbar_item {
color: "#8c8c8c";
font-size: 12px;
height: auto;
slots:
default:
- component: f7-block
style:
flex: 0 0 auto
overflow: scroll
slots:
default:
- component: f7-segmented
style:
flex: 1 1 auto
justify-content: center
margin-left: 2%
margin-right: 2%
gap: 10px
slots:
default:
- component: oh-repeater
for: baseMenu
fragment: true
in:
- name: Home
- name: Floors
- name: Rooms
map: loop.baseMenu.name
sourceType: array
slots:
default:
- component: oh-button
action: variable
actionVariable: objVar
actionVariableValue:
selectSection: ="SECTION" + loop.baseMenu_idx
large: true
class: '=vars.objVar.selectSection=="SECTION" + loop.baseMenu_idx ? "selected_menu_item" : "unselected_menu_item"'
style:
font-size: 24px
font-weight: 200
flex: 0 1 auto
width: auto
text: =loop.baseMenu
- component: f7-row
style:
align-items: center
display: flex
flex-direction: row
flex-wrap: nowrap
height: 2em
width: 100%
flex: 1 1 auto
margin-left: 2%
margin-right: 2%
gap: 10px
visible: false
slots:
default:
action: variable
actionVariable: buttonIndexHome
actionVariableValue: =(vars.buttonIndexHome || 0) - 1
iconF7: chevron_left
style:
color: "#F8BB00"
flex: 0 0 auto
height: 2em
for: menuArray
fragment: true
sourceType: itemsWithTags
itemTags: Floor
fetchMetadata: widgetOrder
map: loop.menuArray_source
slots:
default:
- component: f7-row
style:
display: flex
height: 2em
overflow: hidden
slots:
default:
for: menuButtonHome
fragment: true
in: =loop.menuArray
filter: loop.menuArray_idx == 0
map: ((loop.menuButtonHome.metadata && loop.menuButtonHome.metadata.widgetOrder && loop.menuButtonHome.metadata.widgetOrder.value) || 0).toString().padStart(3,'0') + '&' + loop.menuButtonHome_idx
slots:
default:
action: variable
actionVariable: floor
actionVariableValue: =loop.menuArray[loop.menuButtonHome_source.sort()[loop.menuButtonHome_idx].split('&')[1]].name
style:
flex: 0 1 auto
height: 2em
width: 100%
order: =(((vars.buttonIndexHome || 0) % loop.menuButtonHome_source.length) + loop.menuButtonHome_source.length + loop.menuButtonHome_idx) % loop.menuButtonHome_source.length
text: =loop.menuArray[loop.menuButtonHome_source.sort()[loop.menuButtonHome_idx].split('&')[1]].label
action: variable
actionVariableValue: =(vars.buttonIndexHome || 0) + 1
iconF7: chevron_right
style:
color: "#F8BB00"
flex: 0 0 auto
height: 2em
- component: f7-row
style:
align-items: center
display: flex
flex-direction: row
flex-wrap: nowrap
height: 2em
width: 100%
visible: '=vars.objVar ? (vars.objVar.selectSection=="SECTION1") ? true : false : false'
slots:
default:
action: variable
actionVariable: buttonIndexFloor
actionVariableValue: =(vars.buttonIndexFloor || 0) - 1
style:
color: "#F8BB00"
flex: 0 0 auto
height: 2em
for: menuArray
fragment: true
itemTags: Floor
slots:
default:
- component: f7-row
style:
display: flex
height: 2em
overflow: hidden
slots:
default:
for: menuButtonFloor
fragment: true
in: =loop.menuArray
map: ((loop.menuButtonFloor.metadata && loop.menuButtonFloor.metadata.widgetOrder && loop.menuButtonFloor.metadata.widgetOrder.value) || 0).toString().padStart(3,'0') + '&' + loop.menuButtonFloor_idx
slots:
default:
action: variable
actionVariableValue: =loop.menuArray[loop.menuButtonFloor_source.sort()[loop.menuButtonFloor_idx].split('&')[1]].name
class: '=(vars.floor ==(loop.menuArray[loop.menuButtonFloor_source.sort()[loop.menuButtonFloor_idx].split("&")[1]].name)) ? "selected_menu_item" : "unselected_menu_item"'
style:
flex: 0 0 auto
height: 2em
order: =(((vars.buttonIndexFloor || 0) % loop.menuButtonFloor_source.length) + loop.menuButtonFloor_source.length + loop.menuButtonFloor_idx) % loop.menuButtonFloor_source.length
text-underline-offset: 4px
text: =loop.menuArray[loop.menuButtonFloor_source.sort()[loop.menuButtonFloor_idx].split('&')[1]].label
action: variable
actionVariableValue: =(vars.buttonIndexFloor || 0) + 1
style:
color: "#F8BB00"
flex: 0 0 auto
height: 2em
- component: f7-row
style:
align-items: center
display: flex
flex-direction: row
flex-wrap: nowrap
height: 2em
width: 100%
visible: '=vars.objVar ? (vars.objVar.selectSection=="SECTION2") ? true : false : false'
slots:
default:
action: variable
actionVariable: buttonIndexRoom
actionVariableValue: =(vars.buttonIndexRoom || 0) - 1
style:
color: "#F8BB00"
flex: 0 0 auto
height: 2em
for: menuArrayRoom
fragment: true
itemTags: =vars.floor
map: loop.menuArrayRoom_source
slots:
default:
- component: f7-row
style:
display: flex
height: 2em
overflow: hidden
slots:
default:
for: menuButtonRoom
fragment: true
in: =loop.menuArrayRoom
filter: loop.menuArrayRoom_idx == 0
map: ((loop.menuButtonRoom.metadata && loop.menuButtonRoom.metadata.widgetOrder && loop.menuButtonRoom.metadata.widgetOrder.value) || 0).toString().padStart(3,'0') + '&' + loop.menuButtonRoom_idx
slots:
default:
action: variable
actionVariable: room
actionVariableValue: =loop.menuArrayRoom[loop.menuButtonRoom_source.sort()[loop.menuButtonRoom_idx].split('&')[1]].name
class: '=(vars.room ==(loop.menuArrayRoom[loop.menuButtonRoom_source.sort()[loop.menuButtonRoom_idx].split("&")[1]].name)) ? "selected_menu_item" : "unselected_menu_item"'
style:
flex: 0 0 auto
height: 2em
order: =(((vars.buttonIndexRoom || 0) % loop.menuButtonRoom_source.length) + loop.menuButtonRoom_source.length + loop.menuButtonRoom_idx) % loop.menuButtonRoom_source.length
text: =loop.menuArrayRoom[loop.menuButtonRoom_source.sort()[loop.menuButtonRoom_idx].split('&')[1]].label
action: variable
actionVariableValue: =(vars.buttonIndexRoom || 0) + 1
style:
color: "#F8BB00"
flex: 0 0 auto
height: 2em
- component: widget:main_widget_Home_Card
locationTitle: =props.locationTitle
scenesGroup: =props.scenesGroup
securityGroup: =props.securityGroup
securityMode: =props.securityMode
referencePIN: =props.referencePIN
- component: widget:main_widget_Floor_Card
- component: widget:main_widget_Room_Card
style:
flex: 0 0 auto
overflow: scroll
margin-bottom: -4em
background: =props.bnavColor
border-radius: 0px 0px 10px 10px
visible: '=vars.objVar ? (vars.objVar.selectSection=="SECTION0") ? true : false : false'
slots:
default:
style:
display: flex
flex-direction: row
justify-content: space-around
slots:
default:
- component: oh-link
action: variable
selectSection: =vars.objVar.selectSection
selectThing: Security
class: '=(vars.objVar && (vars.objVar.selectThing=="Security")) ? "selected_bottom_navbar_item display-flex flex-direction-column padding-top half" : "unselected_bottom_navbar_item display-flex flex-direction-column padding-top half"'
icon-f7: shield_fill
text: Security
action: variable
selectThing: Scenes
class: '=(vars.objVar && (vars.objVar.selectThing=="Scenes")) ? "selected_bottom_navbar_item display-flex flex-direction-column padding-top half" : "unselected_bottom_navbar_item display-flex flex-direction-column padding-top half"'
icon-f7: rectangle_on_rectangle_angled
text: Scenes
action: variable
selectThing: Weather
class: '=(vars.objVar && (vars.objVar.selectThing=="Weather")) ? "selected_bottom_navbar_item display-flex flex-direction-column padding-top half" : "unselected_bottom_navbar_item display-flex flex-direction-column padding-top half"'
icon-f7: cloud
text: Weather
action: variable
selectThing: Energy
class: '=(vars.objVar && (vars.objVar.selectThing=="Energy")) ? "selected_bottom_navbar_item display-flex flex-direction-column padding-top half" : "unselected_bottom_navbar_item display-flex flex-direction-column padding-top half"'
icon-f7: bolt_fill
text: Energy
style:
flex: 0 0 auto
overflow: scroll
margin-bottom: -4em
visible: '=vars.objVar ? (vars.objVar.selectSection=="SECTION0") ? false : true : false'
slots:
default:
style:
display: flex
flex-direction: row
slots:
default:
action: variable
selectThing: Lights
class: '=(vars.objVar && (vars.objVar.selectThing=="Lights")) ? "selected_bottom_navbar_item display-flex flex-direction-column padding-top half" : "unselected_bottom_navbar_item display-flex flex-direction-column padding-top half"'
icon-f7: lightbulb_fill
text: Lights
action: variable
selectThing: Rollers
class: '=(vars.objVar && (vars.objVar.selectThing=="Rollers")) ? "selected_bottom_navbar_item display-flex flex-direction-column padding-top half" : "unselected_bottom_navbar_item display-flex flex-direction-column padding-top half"'
icon-f7: archivebox
text: Shades
action: variable
selectThing: Climate
class: '=(vars.objVar && (vars.objVar.selectThing=="Climate")) ? "selected_bottom_navbar_item display-flex flex-direction-column padding-top half" : "unselected_bottom_navbar_item display-flex flex-direction-column padding-top half"'
icon-f7: snow
text: Climate
action: variable
selectThing: Appliances
iconMaterial: power
class: '=(vars.objVar && (vars.objVar.selectThing=="Appliances")) ? "selected_bottom_navbar_item display-flex flex-direction-column padding-top half" : "unselected_bottom_navbar_item display-flex flex-direction-column padding-top half"'
text: Appliances
Just remove the hyphens around the color value
One additional wish, could you please move the display-flex options to a style block of the oh-links. This will move icons an text a bit up, which looks nicer.
Hello Hans-Jörg,
i tried to copy the resource code into a new created widget. Something strange happens. Once the code is pasted and i press the Save button, the code disappears to the default one from creating a new widget…
So I guess i need to wait for a more progressed design state to get able to test the widget. However, your work looks absolutely amazing, looking forward to see the final result!
Best regards
Stefan
Thanks, but kodos go to the team.
When creating a new widget (plus symbol),
Did you delete everything predefined before pasting?
That should work.
Yes sir, I did.
I removed all except for the “uid” part. Otherwise Openhab tells me to give an ID to the widget. I remove all below the first line “uid” and then paste your code from here.
As soon as pressing on Save the code disappears and the default code appears again.
Ah, I see.
Issue might be that the first code block is to be pasted into a new page and the code block under Ressources is the new widget code and includes the “uid” part.
@Nic0205 I have made the correction for the color in my code base and also moved the display-flex options into the style block, so nothing to change from your side now.
I will soon upload new version to github and marketplace, as I made some more changes for simplification [reoved the need for the additional “floor” and “roomGroup” tags].
Hi @hmerk,
just tested the new code. That looks really promising! I like in special the badge notifications.
I testet it with safari on Mac in responsive mode and there seems to be a broken bottom navbar:
I think that is cause of line 380 margin-bottom: -4em
and something with the height of the bottom navbar - which we perhaps have to define…
Should I have a further look this evening? Or are you right to the code at the moment?
