There might be an issue with the timestamp line in the code.
As this will change a lot in the near future, please copy the code and add it manually into your openhab installation.
I changed the bottom navbars to oh-link.
For some reason the stylesheet for the unselected items does not have any effect for now. I will have a further look at it tomorrow. Perhaps I simple missed a bracked or something.
@hmerk, @JustinG : if you see something at once why the unselected_bottom_navbar_item
is not interpreted correct - please let me know.
uid: main_widget
tags: []
props:
parameters:
- description: Set default color for Text
label: Text color
required: false
type: TEXT
- default: RGB(96, 96, 96)
label: Bottom-Navbar-Color
required: false
type: TEXT
- default: Somewhere
description: Name for your weather location
label: Weather Location
required: false
type: TEXT
- context: item
description: Name of scenes group item
label: Scenes Group
required: false
type: TEXT
- context: item
description: Name of security group item
label: Security Group
required: false
type: TEXT
- context: item
description: Security Mode Item
label: Security Mode
required: false
type: TEXT
- context: item
description: Security PIN Item
label: Security PIN
required: false
type: TEXT
parameterGroups: []
timestamp: Sep 28, 2022, 9:54:10 PM
component: f7-block
style:
display: flex
flex-direction: column
height: calc(100vh - var(--f7-toolbar-height) - var(--f7-safe-area-bottom) - var(--f7-safe-area-top))
justify-content: space-between
margin: 0
padding: 0
width: 100%
background: =(themeOptions.dark=="light") ? ("white"):("black")
--menu-text-color: '= (!props.textColor) ? (themeOptions.dark=="light")? black : white : props.textColor'
--f7-button-text-color: "#8c8c8c"
--opmw-menu-text-color: =(themeOptions.dark=="light")?("#8C8C8C"):("#848484")
stylesheet: >
.selected_menu_item {
color: var(--menu-text-color);
text-decoration-color: #F8BB00 !important;
text-decoration: underline;
text-underline-offset: 2.px;
font-weight: bold;
.unselected_menu_item {
color: #8C8C8C;
font-weight: 300;
.selected_bottom_navbar_item {
color: white;
font-size: 12px;
height: auto;
.unselected_bottom_navbar_item {
color: "#8c8c8c";
font-size: 12px;
height: auto;
slots:
default:
- component: f7-block
style:
flex: 0 0 auto
overflow: scroll
slots:
default:
- component: f7-segmented
style:
flex: 1 1 auto
justify-content: center
margin-left: 2%
margin-right: 2%
gap: 10px
slots:
default:
- component: oh-repeater
for: baseMenu
fragment: true
in:
- name: Home
- name: Floors
- name: Rooms
map: loop.baseMenu.name
sourceType: array
slots:
default:
- component: oh-button
action: variable
actionVariable: objVar
actionVariableValue:
selectSection: ="SECTION" + loop.baseMenu_idx
large: true
class: '=vars.objVar.selectSection=="SECTION" + loop.baseMenu_idx ? "selected_menu_item" : "unselected_menu_item"'
style:
font-size: 24px
font-weight: 200
flex: 0 1 auto
width: auto
text: =loop.baseMenu
- component: f7-row
style:
align-items: center
display: flex
flex-direction: row
flex-wrap: nowrap
height: 2em
width: 100%
flex: 1 1 auto
margin-left: 2%
margin-right: 2%
gap: 10px
visible: false
slots:
default:
action: variable
actionVariable: buttonIndexHome
actionVariableValue: =(vars.buttonIndexHome || 0) - 1
iconF7: chevron_left
style:
color: "#F8BB00"
flex: 0 0 auto
height: 2em
for: menuArray
fragment: true
sourceType: itemsWithTags
itemTags: Floor
fetchMetadata: widgetOrder
map: loop.menuArray_source
slots:
default:
- component: f7-row
style:
display: flex
height: 2em
overflow: hidden
slots:
default:
for: menuButtonHome
fragment: true
in: =loop.menuArray
filter: loop.menuArray_idx == 0
map: ((loop.menuButtonHome.metadata && loop.menuButtonHome.metadata.widgetOrder && loop.menuButtonHome.metadata.widgetOrder.value) || 0).toString().padStart(3,'0') + '&' + loop.menuButtonHome_idx
slots:
default:
action: variable
actionVariable: floor
actionVariableValue: =loop.menuArray[loop.menuButtonHome_source.sort()[loop.menuButtonHome_idx].split('&')[1]].name
style:
flex: 0 1 auto
height: 2em
width: 100%
order: =(((vars.buttonIndexHome || 0) % loop.menuButtonHome_source.length) + loop.menuButtonHome_source.length + loop.menuButtonHome_idx) % loop.menuButtonHome_source.length
text: =loop.menuArray[loop.menuButtonHome_source.sort()[loop.menuButtonHome_idx].split('&')[1]].label
action: variable
actionVariableValue: =(vars.buttonIndexHome || 0) + 1
iconF7: chevron_right
style:
color: "#F8BB00"
flex: 0 0 auto
height: 2em
- component: f7-row
style:
align-items: center
display: flex
flex-direction: row
flex-wrap: nowrap
height: 2em
width: 100%
visible: '=vars.objVar ? (vars.objVar.selectSection=="SECTION1") ? true : false : false'
slots:
default:
action: variable
actionVariable: buttonIndexFloor
actionVariableValue: =(vars.buttonIndexFloor || 0) - 1
style:
color: "#F8BB00"
flex: 0 0 auto
height: 2em
for: menuArray
fragment: true
itemTags: Floor
slots:
default:
- component: f7-row
style:
display: flex
height: 2em
overflow: hidden
slots:
default:
for: menuButtonFloor
fragment: true
in: =loop.menuArray
map: ((loop.menuButtonFloor.metadata && loop.menuButtonFloor.metadata.widgetOrder && loop.menuButtonFloor.metadata.widgetOrder.value) || 0).toString().padStart(3,'0') + '&' + loop.menuButtonFloor_idx
slots:
default:
action: variable
actionVariableValue: =loop.menuArray[loop.menuButtonFloor_source.sort()[loop.menuButtonFloor_idx].split('&')[1]].name
class: '=(vars.floor ==(loop.menuArray[loop.menuButtonFloor_source.sort()[loop.menuButtonFloor_idx].split("&")[1]].name)) ? "selected_menu_item" : "unselected_menu_item"'
style:
flex: 0 0 auto
height: 2em
order: =(((vars.buttonIndexFloor || 0) % loop.menuButtonFloor_source.length) + loop.menuButtonFloor_source.length + loop.menuButtonFloor_idx) % loop.menuButtonFloor_source.length
text-underline-offset: 4px
text: =loop.menuArray[loop.menuButtonFloor_source.sort()[loop.menuButtonFloor_idx].split('&')[1]].label
action: variable
actionVariableValue: =(vars.buttonIndexFloor || 0) + 1
style:
color: "#F8BB00"
flex: 0 0 auto
height: 2em
- component: f7-row
style:
align-items: center
display: flex
flex-direction: row
flex-wrap: nowrap
height: 2em
width: 100%
visible: '=vars.objVar ? (vars.objVar.selectSection=="SECTION2") ? true : false : false'
slots:
default:
action: variable
actionVariable: buttonIndexRoom
actionVariableValue: =(vars.buttonIndexRoom || 0) - 1
style:
color: "#F8BB00"
flex: 0 0 auto
height: 2em
for: menuArrayRoom
fragment: true
itemTags: =vars.floor
map: loop.menuArrayRoom_source
slots:
default:
- component: f7-row
style:
display: flex
height: 2em
overflow: hidden
slots:
default:
for: menuButtonRoom
fragment: true
in: =loop.menuArrayRoom
filter: loop.menuArrayRoom_idx == 0
map: ((loop.menuButtonRoom.metadata && loop.menuButtonRoom.metadata.widgetOrder && loop.menuButtonRoom.metadata.widgetOrder.value) || 0).toString().padStart(3,'0') + '&' + loop.menuButtonRoom_idx
slots:
default:
action: variable
actionVariable: room
actionVariableValue: =loop.menuArrayRoom[loop.menuButtonRoom_source.sort()[loop.menuButtonRoom_idx].split('&')[1]].name
class: '=(vars.room ==(loop.menuArrayRoom[loop.menuButtonRoom_source.sort()[loop.menuButtonRoom_idx].split("&")[1]].name)) ? "selected_menu_item" : "unselected_menu_item"'
style:
flex: 0 0 auto
height: 2em
order: =(((vars.buttonIndexRoom || 0) % loop.menuButtonRoom_source.length) + loop.menuButtonRoom_source.length + loop.menuButtonRoom_idx) % loop.menuButtonRoom_source.length
text: =loop.menuArrayRoom[loop.menuButtonRoom_source.sort()[loop.menuButtonRoom_idx].split('&')[1]].label
action: variable
actionVariableValue: =(vars.buttonIndexRoom || 0) + 1
style:
color: "#F8BB00"
flex: 0 0 auto
height: 2em
- component: widget:main_widget_Home_Card
locationTitle: =props.locationTitle
scenesGroup: =props.scenesGroup
securityGroup: =props.securityGroup
securityMode: =props.securityMode
referencePIN: =props.referencePIN
- component: widget:main_widget_Floor_Card
- component: widget:main_widget_Room_Card
style:
flex: 0 0 auto
overflow: scroll
margin-bottom: -4em
background: =props.bnavColor
border-radius: 0px 0px 10px 10px
visible: '=vars.objVar ? (vars.objVar.selectSection=="SECTION0") ? true : false : false'
slots:
default:
style:
display: flex
flex-direction: row
justify-content: space-around
slots:
default:
- component: oh-link
action: variable
selectSection: =vars.objVar.selectSection
selectThing: Security
class: '=(vars.objVar && (vars.objVar.selectThing=="Security")) ? "selected_bottom_navbar_item display-flex flex-direction-column padding-top half" : "unselected_bottom_navbar_item display-flex flex-direction-column padding-top half"'
icon-f7: shield_fill
text: Security
action: variable
selectThing: Scenes
class: '=(vars.objVar && (vars.objVar.selectThing=="Scenes")) ? "selected_bottom_navbar_item display-flex flex-direction-column padding-top half" : "unselected_bottom_navbar_item display-flex flex-direction-column padding-top half"'
icon-f7: rectangle_on_rectangle_angled
text: Scenes
action: variable
selectThing: Weather
class: '=(vars.objVar && (vars.objVar.selectThing=="Weather")) ? "selected_bottom_navbar_item display-flex flex-direction-column padding-top half" : "unselected_bottom_navbar_item display-flex flex-direction-column padding-top half"'
icon-f7: cloud
text: Weather
action: variable
selectThing: Energy
class: '=(vars.objVar && (vars.objVar.selectThing=="Energy")) ? "selected_bottom_navbar_item display-flex flex-direction-column padding-top half" : "unselected_bottom_navbar_item display-flex flex-direction-column padding-top half"'
icon-f7: bolt_fill
text: Energy
style:
flex: 0 0 auto
overflow: scroll
margin-bottom: -4em
visible: '=vars.objVar ? (vars.objVar.selectSection=="SECTION0") ? false : true : false'
slots:
default:
style:
display: flex
flex-direction: row
slots:
default:
action: variable
selectThing: Lights
class: '=(vars.objVar && (vars.objVar.selectThing=="Lights")) ? "selected_bottom_navbar_item display-flex flex-direction-column padding-top half" : "unselected_bottom_navbar_item display-flex flex-direction-column padding-top half"'
icon-f7: lightbulb_fill
text: Lights
action: variable
selectThing: Rollers
class: '=(vars.objVar && (vars.objVar.selectThing=="Rollers")) ? "selected_bottom_navbar_item display-flex flex-direction-column padding-top half" : "unselected_bottom_navbar_item display-flex flex-direction-column padding-top half"'
icon-f7: archivebox
text: Shades
action: variable
selectThing: Climate
class: '=(vars.objVar && (vars.objVar.selectThing=="Climate")) ? "selected_bottom_navbar_item display-flex flex-direction-column padding-top half" : "unselected_bottom_navbar_item display-flex flex-direction-column padding-top half"'
icon-f7: snow
text: Climate
action: variable
selectThing: Appliances
iconMaterial: power
class: '=(vars.objVar && (vars.objVar.selectThing=="Appliances")) ? "selected_bottom_navbar_item display-flex flex-direction-column padding-top half" : "unselected_bottom_navbar_item display-flex flex-direction-column padding-top half"'
text: Appliances
Just remove the hyphens around the color value
One additional wish, could you please move the display-flex options to a style block of the oh-links. This will move icons an text a bit up, which looks nicer.
Hello Hans-Jörg,
i tried to copy the resource code into a new created widget. Something strange happens. Once the code is pasted and i press the Save button, the code disappears to the default one from creating a new widget…
So I guess i need to wait for a more progressed design state to get able to test the widget. However, your work looks absolutely amazing, looking forward to see the final result!
Best regards
Stefan
Thanks, but kodos go to the team.
When creating a new widget (plus symbol),
Did you delete everything predefined before pasting?
That should work.
Yes sir, I did.
I removed all except for the “uid” part. Otherwise Openhab tells me to give an ID to the widget. I remove all below the first line “uid” and then paste your code from here.
As soon as pressing on Save the code disappears and the default code appears again.
Ah, I see.
Issue might be that the first code block is to be pasted into a new page and the code block under Ressources is the new widget code and includes the “uid” part.
@Nic0205 I have made the correction for the color in my code base and also moved the display-flex options into the style block, so nothing to change from your side now.
I will soon upload new version to github and marketplace, as I made some more changes for simplification [reoved the need for the additional “floor” and “roomGroup” tags].
Hi @hmerk,
just tested the new code. That looks really promising! I like in special the badge notifications.
I testet it with safari on Mac in responsive mode and there seems to be a broken bottom navbar:
I think that is cause of line 380 margin-bottom: -4em
and something with the height of the bottom navbar - which we perhaps have to define…
Should I have a further look this evening? Or are you right to the code at the moment?
Yes please, as I am struggling with some other nice new ideas
Copy&Patse error, updated on github
Hi @hmerk ,
I updated the code and put also the flex-classes from the style tags into the stylesheet.
On my iPhone 12 it now works could you please have a look at your iPhone 8?
@all: Could you please try if the bottom nav bar is a) right sized in the height and b) completely shown ?
@Dimitris : Could you please have a look if the right proportions are in the widget now?
btw - how do you face your design with the actual screenshots? Do you use an extra app for it?
uid: main_widget
tags: []
props:
parameters:
label: Text color
required: false
type: TEXT
required: false
type: TEXT
required: false
type: TEXT
- context: item
label: Scenes Group
required: false
type: TEXT
- context: item
required: false
type: TEXT
- context: item
required: false
type: TEXT
- context: item
label: Security PIN
required: false
type: TEXT
parameterGroups: []
timestamp: Sep 29, 2022, 5:41:17 PM
component: f7-block
style:
display: flex
margin: 0
padding: 0
width: 100%
stylesheet: >
text-underline-offset: 2px;
font-weight: bold;
color: #8C8C8C;
font-weight: 300;
color: white;
font-size: 12px;
height: auto;
--f7-button-bg-color: transparent;
display: flex;
flex-direction: column;
align-items: center;
padding-top: 1%;
padding-bottom: 1%;
color: #8c8c8c;
font-size: 12px;
height: auto;
display: flex;
padding-top: 2%;
padding-bottom: 2%;
slots:
default:
style:
flex: 0 0 auto
overflow: scroll
slots:
default:
style:
flex: 1 1 auto
margin-left: 2%
margin-right: 2%
gap: 10px
slots:
default:
for: baseMenu
fragment: true
in:
- name: Home
- name: Floors
- name: Rooms
sourceType: array
slots:
default:
action: variable
floor: =vars.objVar.floor
room: =vars.objVar.room
large: true
style:
font-size: 24px
font-weight: 200
flex: 0 1 auto
width: auto
- component: f7-row
style:
align-items: center
display: flex
flex-direction: row
flex-wrap: nowrap
height: 2em
width: 100%
visible: false
slots:
default:
action: variable
style:
color: "#F8BB00"
flex: 0 0 auto
height: 2em
fetchMetadata: metadata,semantics,widgetOrder
fragment: true
for: menuArray
itemTags: ","
filter: (loop.menuArray.metadata) && (loop.menuArray.metadata.semantics.value).includes("Floor")
slots:
default:
- component: f7-row
style:
display: flex
height: 2em
overflow: hidden
slots:
default:
for: menuButtonHome
fragment: true
in: =loop.menuArray
slots:
default:
action: variable
selectSection: = vars.objVar.selectSection
floor: =loop.menuArray[loop.menuButtonHome_source.sort()[loop.menuButtonHome_idx].split('&')[1]].name
style:
flex: 0 0 auto
height: 2em
action: variable
style:
color: "#F8BB00"
flex: 0 0 auto
height: 2em
- component: f7-row
style:
align-items: center
display: flex
flex-direction: row
flex-wrap: nowrap
height: 2em
width: 100%
slots:
default:
action: variable
style:
color: "#F8BB00"
flex: 0 0 auto
height: 2em
fragment: true
for: menuArray
itemTags: ","
slots:
default:
- component: f7-row
style:
display: flex
height: 2em
overflow: hidden
slots:
default:
fragment: true
in: =loop.menuArray
slots:
default:
action: variable
floor: =loop.menuArray[loop.menuButtonFloor_source.sort()[loop.menuButtonFloor_idx].split('&')[1]].name
class: '=(vars.objVar.floor ==(loop.menuArray[loop.menuButtonFloor_source.sort()[loop.menuButtonFloor_idx].split("&")[1]].name)) ? "selected_menu_item" : "unselected_menu_item"'
style:
flex: 0 0 auto
height: 2em
action: variable
style:
color: "#F8BB00"
flex: 0 0 auto
height: 2em
- component: f7-row
style:
align-items: center
display: flex
flex-direction: row
flex-wrap: nowrap
height: 2em
width: 100%
slots:
default:
action: variable
style:
color: "#F8BB00"
flex: 0 0 auto
height: 2em
fragment: true
for: menuArrayRoom
sourceType: itemsInGroup
groupItem: =vars.objVar.floor
filter: (loop.menuArrayRoom.metadata) && (loop.menuArrayRoom.metadata.semantics.value).includes("Room")
slots:
default:
- component: f7-row
style:
display: flex
height: 2em
overflow: hidden
slots:
default:
for: menuButtonRoom
fragment: true
slots:
default:
action: variable
room: =loop.menuArrayRoom[loop.menuButtonRoom_source.sort()[loop.menuButtonRoom_idx].split('&')[1]].name
class: '=(vars.objVar.room ==(loop.menuArrayRoom[loop.menuButtonRoom_source.sort()[loop.menuButtonRoom_idx].split("&")[1]].name)) ? "selected_menu_item" : "unselected_menu_item"'
style:
flex: 0 0 auto
height: 2em
action: variable
style:
color: "#F8BB00"
flex: 0 0 auto
height: 2em
style:
flex: 0 0 auto
overflow: scroll
margin-bottom: -4em
slots:
default:
style:
display: flex
flex-direction: row
slots:
default:
action: variable
class: '=(vars.objVar && (vars.objVar.selectThing=="Security")) ? "selected_bottom_navbar_item" : "unselected_bottom_navbar_item"'
iconBadge: 1
badgeColor: '=(vars.objVar && (vars.objVar.selectThing=="Security")) ? "orange" : "red"'
text: Security
action: variable
selectThing: Scenes
class: '=(vars.objVar && (vars.objVar.selectThing=="Scenes")) ? "selected_bottom_navbar_item" : "unselected_bottom_navbar_item"'
text: Scenes
action: variable
class: '=(vars.objVar && (vars.objVar.selectThing=="Weather")) ? "selected_bottom_navbar_item" : "unselected_bottom_navbar_item"'
icon-f7: cloud
text: Weather
action: variable
selectThing: Energy
class: '=(vars.objVar && (vars.objVar.selectThing=="Energy")) ? "selected_bottom_navbar_item" : "unselected_bottom_navbar_item"'
icon-f7: bolt_fill
text: Energy
style:
flex: 0 0 auto
overflow: scroll
margin-bottom: -4em
slots:
default:
style:
display: flex
flex-direction: row
slots:
default:
action: variable
selectThing: Lights
class: '=(vars.objVar && (vars.objVar.selectThing=="Lights")) ? "selected_bottom_navbar_item" : "unselected_bottom_navbar_item"'
text: Lights
action: variable
class: '=(vars.objVar && (vars.objVar.selectThing=="Rollers")) ? "selected_bottom_navbar_item" : "unselected_bottom_navbar_item"'
icon-f7: archivebox
text: Shades
action: variable
class: '=(vars.objVar && (vars.objVar.selectThing=="Climate")) ? "selected_bottom_navbar_item" : "unselected_bottom_navbar_item"'
icon-f7: snow
text: Climate
action: variable
iconMaterial: power
class: '=(vars.objVar && (vars.objVar.selectThing=="Appliances")) ? "selected_bottom_navbar_item" : "unselected_bottom_navbar_item"'
text: Appliances
Bottom navbar looks good on my iPhone 8.
Will check tomorrow on iPhone 12 mini…
Hey @Dimitris
your screenshots look curious. Did you use the latest code of the other parts from hmerks GitHub account? Concrete the main_wdidget I posted here and the other parts that hmerk put on GitHub ?
He is definitely using older versions, otherwithe no dummy for floor level would be shown.
I am still struggling with the visibility tag for the floor card and the included widgets. Ned to do some further testing.
Apart from that issue, it already looks promising….
ok last try for me…then i leave
@hmerk can you please add to main widget, floor amd rooms cards, the support for HVAC and Conditioner? i’ve update these 3 yaml, so i could just give you the part of the code to allow support for widgets.
it’s all ready, you just need to copy paste to github related widgets.
please let me know.
hey @rubenfuser
one suggestion: Why not simple fork the GitHub Repo of hmerk and add the widgets there?
If hmerk is ready with the main_widget stuff we can merge things together.
Or did I understand something wrong?
