You certainly welcome, though I can’t say I’ve done much more than answers a few questions.
I think you’re not seeing what you expect due to textColor.
The expression parser is treating that as a variable which is undefined. I’m sure just changing that to 'black' will get you the correct text color.
However, at this point I think I would recommend moving to a more general css system and take advantage of the stylesheet. Then you only need a single expression in each component to give it a class which will greatly reduce the complexity of the styling at this point. The stylesheet can be added at the top f7-block level like this:
This will also make it easier for you to eventually add theme options and personalization as you see see the example I put in of creating an open page main widget specific variable in the style section and using that variable in the stylesheet.
@rubenfuser Hmmm. All devices in my perspective is indeed energy devices. That I had in my mind for the tab bar is to filter equipment by type. So if your smart plug controls a light, then you have an on-off light widget that shows up under lights tab. Energy for me drives my mind to report section under Home menu. Again, maybe I’m wrong.
as said before, i have smartplugs, that have anything related to lights.
smartplug, for example in my case, one controls fridge, one controls hoover, one control washing machine…and so on.
'cause we’re creating something that will be suitable for everyone, we have to think what users can have at home.
like i’ve already wrote about people that have 2 or 3 floors home, you can’t remove floors menu.
and about this topic, can we do another thing?
floor menu will show all devices in floor devided by type., and room show all rooms and devices are devided by type.
this avoid us to add another line on the top menu, and at the same time, makes more suitable that menu.
ok this is not what widget does at the moment. @hmerk@Nic0205, so Rooms menu should be independent, menu selection will be vertical.
Floor show only → frist,second,ground floors
Rooms show only → bedroom,kitchen,dining room…and rooms can be selected directly, and not only after floor selection.
mmm…ok but only in room selection in my opinion.
also security, in room selection, is useless, security could be available only in Home bottom menu.
last, i suggest to rename “HVAC” to “Clima”.
Dimitri could you please describe (perhaps with images ) how the structure cascade should be in your mind and then we could discuss if all could agree to it? For me this thread with the image was a great help to see what we have to do…
For me it looks at the moment that we have lots of construction sites that should be followed in a structured form. Like an kanban-Board / todo_list or similar. At least for me it is sometimes hard to follow who works on what and how we could put the things together…
For now I know:
Ruben is working on the widgets
hmerk is working on cutting the main code in pieces with extra widgets for rooms and floors
Justin gives always the right advice
Dimitris looks at the correct design pattern
Nic is waiting for hmerk to have the poc ready and then would try the theming options.
completely agree!
in my mind, hmerk and you are working on main widget code.
i’m working on sub widgets
dimitris graphical info.
i talk for my job, we need to put in first post also RGB colors (if someone in future will join/help us), and maybe put an empty widget f7-card with preset layout defined.
also @Dimitris we need explained functions for widgets, which buttons have to do what…
eventually @Nic0205, can you be the widget beta tester and “code corrector”? i’m not very good and sure i make big mistakes, so i need a teacher supervisor for this
No, that‘s not how I understood the design concept.
What @Dimitris explained today is what I was talking about yesterday and what I am going to bild a poc of.
Moving the middle (information) part out of the main_widget and show it as a „Room Card“ or a „Floor Card“ based on Menu selection. These new cards will then show the different equipment widgets.
maybe we’re saying same thing in different words.
i understood that Floor menu show ALL devices of the floor, of every room.
room menu show all devices of that room. so room menu will have all rooms of all floors.
Not exactly, as per my understanding, room menu will only show the rooms of the prior selected floor. Orherwise, the menu might need to much clicking to get to the right room.
why too much clicking? should be less than actual
open main widget, click floor to show everything for that floor
or
open main widget, click rooms and then room name to show category (lights, rollers…) of that room.
now, we have to chose floors, then floor name, then move to rooms, and then select room name, and then category.
Think of having a house with 3 floors and 4 rooms each, makes 12 rooms in total. Cause ao name length, you might see 3 rooms in the menu at once, so to reach the last room you need to press the chevron 8 times, whereas it would be one or two clicks to select the floor and anothe one or two for the room….
