OH3: migration of rules: transform map and strange math results
I’m trying to migrate my old OH1 rules and face some strange issues.
Here is my rule
rule "OG R1 Beschattung"
	Item OG_R1_Beschattungsautomatik received update or
        Item OGR1GlastasterBEGT2Tx01_Temperatur received update or
	Item OGR1_BeschattungMinTemp received update or
	Item OGR1_BeschattungDeadband received update or
	Item BeschattungLamellenPosition received update or
	Item OGR1Beschattungssteuerung received update
	val currentRoomTemp = OGR1GlastasterBEGT2Tx01_Temperatur.state as Number
	val tempLimit = OGR1_BeschattungMinTemp.state as Number
	val tempDeadBand = OGR1_BeschattungDeadband.state as Number
	val automatic = transform("MAP","beschatttungscontrol.map",KGR2GlastasterBEGT2Tx01_OGR1Beschattungssteuerung.state.toString)
	logInfo("openhab", " ******** OG R1 automatic = {}", automatic ) // shows transform doesnt work
	if ( automatic == "2" ) return;  //"OFF" ) return ;
	//	exectue Beschattung
	logInfo("openhab", " ******** OG R1 check automatic == FORCED or too hot {} {} {} {} {}" , currentRoomTemp > tempLimit + tempDeadBand,  currentRoomTemp , tempLimit , tempDeadBand , tempLimit + tempDeadBand )
	if ( currentRoomTemp > tempLimit + tempDeadBand ||  automatic == "3" ){ //"FORCED" ) {
		if ( OGJalousienJAL080102_KanalgRaffstore.state < 95) {
			logInfo("openhab", " ******** lowering rollershutter OG R1" )
			OGJalousienJAL080102_KanalgRaffstore.sendCommand(100)
		logInfo("openhab", " ******** update Lamelle OG R1 {}", BeschattungLamellenPosition )
		OGJalousienJAL080102_KanalGLamelle.sendCommand(BeschattungLamellenPosition.state as Number)
		return ;
	logInfo("openhab", " ******** OG R1 check automatic != FORCED or too cold")
	if ( currentRoomTemp < tempLimit && automatic != "3" ) { //"FORCED") {
		if ( OGJalousienJAL080102_KanalgRaffstore.state > 10) {
			logInfo("openhab", " ******** rising rollershutter OG R1" )
			OGJalousienJAL080102_KanalgRaffstore.sendCommand(0)
		OGJalousienJAL080102_KanalGLamelle.sendCommand(0)
		return ;
here is the openhab.log content:
2021-02-28 13:29:27.331 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Beschattung.rules'
2021-02-28 13:29:32.188 [INFO ] [rg.openhab.core.model.script.openhab] -  ******** OG R1 automatic = 3
2021-02-28 13:29:32.190 [INFO ] [rg.openhab.core.model.script.openhab] -  ******** OG R1 check automatic == FORCED or too hot false 25.2 °C 22.0 °C 0.5 °C 568.80
2021-02-28 13:29:32.192 [INFO ] [rg.openhab.core.model.script.openhab] -  ******** update Lamelle OG R1 BeschattungLamellenPosition (Type=NumberItem, State=72.20571383, Label=Lamellen Position, Category=null)
Strange is especially the math 22.0 + 0.5 = 568.80. There must be something I missed in math :slight_smile:
also, the transform obviously does not work as expected… the beschattungscontrol.map looks like
1=AUTO
2=OFF
3=FORCED
any help welcome
See
Specifically, “as Number” is not doing what you think here and is not helping..
