One again it happend and I hope to get some help here again
reading through some other forums I checked the following:
sudo nano /var/log/kern.log
and found this stuff:
A reboot at night? Why?
Does this ring a bell?
OH (kind of) crashed at 2021-05-24 00:08:45.328 according to openhab.log
May 23 19:41:00 homer kernel: [954218.155718] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
May 23 19:41:00 homer kernel: [954218.189975] scsi host0: uas_eh_device_reset_handler success
May 24 00:07:31 homer kernel: [ 0.000000] Booting Linux on physical CPU 0x0
May 24 00:07:31 homer kernel: [ 0.000000] Linux version 5.10.17-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1414 SMP Fri Apr 30 13:20:47 BST 2021
May 24 00:07:31 homer kernel: [ 0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
May 24 00:07:31 homer kernel: [ 0.000000] CPU: div instructions available: patching division code
May 24 00:07:31 homer kernel: [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
May 24 00:07:31 homer kernel: [ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.4
May 24 00:07:31 homer kernel: [ 0.000000] Memory policy: Data cache writealloc
May 24 00:07:31 homer kernel: [ 0.000000] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB
May 24 00:07:31 homer kernel: [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
May 24 00:07:31 homer kernel: [ 0.000000] Zone ranges:
May 24 00:07:31 homer kernel: [ 0.000000] DMA [mem 0x0000000000000000-0x000000002fffffff]
May 24 00:07:31 homer kernel: [ 0.000000] Normal empty
May 24 00:07:31 homer kernel: [ 0.000000] HighMem [mem 0x0000000030000000-0x00000001ffffffff]
May 24 00:07:31 homer kernel: [ 0.000000] Movable zone start for each node
May 24 00:07:31 homer kernel: [ 0.000000] Early memory node ranges
May 24 00:07:31 homer kernel: [ 0.000000] node 0: [mem 0x0000000000000000-0x000000003e5fffff]
May 24 00:07:31 homer kernel: [ 0.000000] node 0: [mem 0x0000000040000000-0x00000000fbffffff]
May 24 00:07:31 homer kernel: [ 0.000000] node 0: [mem 0x0000000100000000-0x00000001ffffffff]
May 24 00:07:31 homer kernel: [ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000001ffffffff]
May 24 00:07:31 homer kernel: [ 0.000000] On node 0 totalpages: 2074112
May 24 00:07:31 homer kernel: [ 0.000000] DMA zone: 2304 pages used for memmap
May 24 00:07:31 homer kernel: [ 0.000000] DMA zone: 0 pages reserved
May 24 00:07:31 homer kernel: [ 0.000000] DMA zone: 196608 pages, LIFO batch:63
May 24 00:07:31 homer kernel: [ 0.000000] HighMem zone: 1877504 pages, LIFO batch:63
May 24 00:07:31 homer kernel: [ 0.000000] percpu: Embedded 20 pages/cpu s50700 r8192 d23028 u81920
May 24 00:07:31 homer kernel: [ 0.000000] pcpu-alloc: s50700 r8192 d23028 u81920 alloc=20*4096
May 24 00:07:31 homer kernel: [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
May 24 00:07:31 homer kernel: [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 2071808
May 24 00:07:31 homer kernel: [ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 smsc95xx.macaddr=DC:A6:32:C5:D7:FD vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000 console=tty$
May 24 00:07:31 homer kernel: [ 0.000000] Kernel parameter elevator= does not have any effect anymore.
May 24 00:07:31 homer kernel: [ 0.000000] Please use sysfs to set IO scheduler for individual devices.
May 24 00:07:31 homer kernel: [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
May 24 00:07:31 homer kernel: [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
May 24 00:07:31 homer kernel: [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
May 24 00:07:31 homer kernel: [ 0.000000] software IO TLB: mapped [mem 0x0000000014c00000-0x0000000018c00000] (64MB)
May 24 00:07:31 homer kernel: [ 0.000000] Memory: 7850668K/8296448K available (10240K kernel code, 1358K rwdata, 3160K rodata, 2048K init, 890K bss, 183636K reserved, 262144K cma-reserved, 7510016K highmem)
May 24 00:07:31 homer kernel: [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
May 24 00:07:31 homer kernel: [ 0.000000] ftrace: allocating 33942 entries in 67 pages
May 24 00:07:31 homer kernel: [ 0.000000] ftrace: allocated 67 pages with 3 groups
May 24 00:07:31 homer kernel: [ 0.000000] rcu: Hierarchical RCU implementation.
May 24 00:07:31 homer kernel: [ 0.000000] Rude variant of Tasks RCU enabled.
May 24 00:07:31 homer kernel: [ 0.000000] Tracing variant of Tasks RCU enabled.
May 24 00:07:31 homer kernel: [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
May 24 00:07:31 homer kernel: [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
May 24 00:07:31 homer kernel: [ 0.000000] GIC: Using split EOI/Deactivate mode
May 24 00:07:31 homer kernel: [ 0.000000] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=0
May 24 00:07:31 homer kernel: [ 0.000008] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
May 24 00:07:31 homer kernel: [ 0.000034] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
May 24 00:07:31 homer kernel: [ 0.000099] bcm2835: system timer (irq = 25)
May 24 00:07:31 homer kernel: [ 0.000751] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
May 24 00:07:31 homer kernel: [ 0.000772] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
May 24 00:07:31 homer kernel: [ 0.000794] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
May 24 00:07:31 homer kernel: [ 0.000812] Switching to timer-based delay loop, resolution 18ns
May 24 00:07:31 homer kernel: [ 0.001066] Console: colour dummy device 80x30
May 24 00:07:31 homer kernel: [ 0.001821] printk: console [tty1] enabled
May 24 00:07:31 homer kernel: [ 0.001886] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
May 24 00:07:31 homer kernel: [ 0.001940] pid_max: default: 32768 minimum: 301
May 24 00:07:31 homer kernel: [ 0.002121] LSM: Security Framework initializing
May 24 00:07:31 homer kernel: [ 0.002321] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
May 24 00:07:31 homer kernel: [ 0.002366] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
May 24 00:07:31 homer kernel: [ 0.003939] Disabling memory control group subsystem
May 24 00:07:31 homer kernel: [ 0.004076] CPU: Testing write buffer coherency: ok
May 24 00:07:31 homer kernel: [ 0.004548] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
May 24 00:07:31 homer kernel: [ 0.005770] Setting up static identity map for 0x200000 - 0x20003c
May 24 00:07:31 homer kernel: [ 0.005986] rcu: Hierarchical SRCU implementation.
May 24 00:07:31 homer kernel: [ 0.006927] smp: Bringing up secondary CPUs ...
May 24 00:07:31 homer kernel: [ 0.008154] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
May 24 00:07:31 homer kernel: [ 0.009516] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
May 24 00:07:31 homer kernel: [ 0.010825] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
May 24 00:07:31 homer kernel: [ 0.010985] smp: Brought up 1 node, 4 CPUs
May 24 00:07:31 homer kernel: [ 0.011031] SMP: Total of 4 processors activated (432.00 BogoMIPS).
May 24 00:07:31 homer kernel: [ 0.011061] CPU: All CPU(s) started in HYP mode.
May 24 00:07:31 homer kernel: [ 0.011087] CPU: Virtualization extensions available.
May 24 00:07:31 homer kernel: [ 0.011937] devtmpfs: initialized
May 24 00:07:31 homer kernel: [ 0.025786] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
May 24 00:07:31 homer kernel: [ 0.026043] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
May 24 00:07:31 homer kernel: [ 0.026096] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
May 24 00:07:31 homer kernel: [ 0.033144] pinctrl core: initialized pinctrl subsystem
May 24 00:07:31 homer kernel: [ 0.034236] NET: Registered protocol family 16
May 24 00:07:31 homer kernel: [ 0.038227] DMA: preallocated 1024 KiB pool for atomic coherent allocations
May 24 00:07:31 homer kernel: [ 0.039007] audit: initializing netlink subsys (disabled)
May 24 00:07:31 homer kernel: [ 0.039291] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
May 24 00:07:31 homer kernel: [ 0.039847] thermal_sys: Registered thermal governor 'step_wise'
May 24 00:07:31 homer kernel: [ 0.040528] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
May 24 00:07:31 homer kernel: [ 0.040582] hw-breakpoint: maximum watchpoint size is 8 bytes.
May 24 00:07:31 homer kernel: [ 0.041017] Serial: AMBA PL011 UART driver
May 24 00:07:31 homer kernel: [ 0.071884] bcm2835-mbox fe00b880.mailbox: mailbox enabled
May 24 00:07:31 homer kernel: [ 0.090906] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-04-30T13:46:08, variant start_cd
May 24 00:07:31 homer kernel: [ 0.100920] raspberrypi-firmware soc:firmware: Firmware hash is d7f29d96450abfc77cd6cf011af1faf1e03e5e56
May 24 00:07:31 homer kernel: [ 0.145773] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
May 24 00:07:31 homer kernel: [ 0.149878] vgaarb: loaded
May 24 00:07:31 homer kernel: [ 0.150349] SCSI subsystem initialized
May 24 00:07:31 homer kernel: [ 0.150592] usbcore: registered new interface driver usbfs
May 24 00:07:31 homer kernel: [ 0.150679] usbcore: registered new interface driver hub
May 24 00:07:31 homer kernel: [ 0.150768] usbcore: registered new device driver usb
May 24 00:07:31 homer kernel: [ 0.151444] usb_phy_generic phy: supply vcc not found, using dummy regulator
May 24 00:07:31 homer kernel: [ 0.153343] clocksource: Switched to clocksource arch_sys_counter
May 24 00:07:31 homer kernel: [ 1.154156] VFS: Disk quotas dquot_6.6.0
May 24 00:07:31 homer kernel: [ 1.154293] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
May 24 00:07:31 homer kernel: [ 1.154493] FS-Cache: Loaded
May 24 00:07:31 homer kernel: [ 1.154702] CacheFiles: Loaded
May 24 00:07:31 homer kernel: [ 1.165120] NET: Registered protocol family 2
May 24 00:07:31 homer kernel: [ 1.166017] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
May 24 00:07:31 homer kernel: [ 1.166180] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
May 24 00:07:31 homer kernel: [ 1.166261] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
May 24 00:07:31 homer kernel: [ 1.166348] TCP: Hash tables configured (established 8192 bind 8192)
May 24 00:07:31 homer kernel: [ 1.166519] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
May 24 00:07:31 homer kernel: [ 1.166574] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
May 24 00:07:31 homer kernel: [ 1.166856] NET: Registered protocol family 1
May 24 00:07:31 homer kernel: [ 1.167589] RPC: Registered named UNIX socket transport module.
May 24 00:07:31 homer kernel: [ 1.167622] RPC: Registered udp transport module.
May 24 00:07:31 homer kernel: [ 1.167650] RPC: Registered tcp transport module.
May 24 00:07:31 homer kernel: [ 1.167679] RPC: Registered tcp NFSv4.1 backchannel transport module.
May 24 00:07:31 homer kernel: [ 1.167716] PCI: CLS 0 bytes, default 64
May 24 00:07:31 homer kernel: [ 1.170555] Initialise system trusted keyrings
May 24 00:07:31 homer kernel: [ 1.170825] workingset: timestamp_bits=14 max_order=21 bucket_order=7
May 24 00:07:31 homer kernel: [ 1.179482] zbud: loaded
May 24 00:07:31 homer kernel: [ 1.181411] FS-Cache: Netfs 'nfs' registered for caching
May 24 00:07:31 homer kernel: [ 1.182177] NFS: Registering the id_resolver key type
May 24 00:07:31 homer kernel: [ 1.182237] Key type id_resolver registered
May 24 00:07:31 homer kernel: [ 1.182265] Key type id_legacy registered
May 24 00:07:31 homer kernel: [ 1.182433] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
May 24 00:07:31 homer kernel: [ 1.183543] Key type asymmetric registered
May 24 00:07:31 homer kernel: [ 1.183576] Asymmetric key parser 'x509' registered
May 24 00:07:31 homer kernel: [ 1.183783] bounce: pool size: 64 pages
May 24 00:07:31 homer kernel: [ 1.183840] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
May 24 00:07:31 homer kernel: [ 1.184075] io scheduler mq-deadline registered
May 24 00:07:31 homer kernel: [ 1.184107] io scheduler kyber registered
May 24 00:07:31 homer kernel: [ 1.188554] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
May 24 00:07:31 homer kernel: [ 1.188606] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
May 24 00:07:31 homer kernel: [ 1.188709] brcm-pcie fd500000.pcie: MEM 0x0600000000..0x063fffffff -> 0x00c0000000
May 24 00:07:31 homer kernel: [ 1.188819] brcm-pcie fd500000.pcie: IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
May 24 00:07:31 homer kernel: [ 1.245448] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
May 24 00:07:31 homer kernel: [ 1.245829] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
May 24 00:07:31 homer kernel: [ 1.245866] pci_bus 0000:00: root bus resource [bus 00-ff]
May 24 00:07:31 homer kernel: [ 1.245901] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
May 24 00:07:31 homer kernel: [ 1.246011] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
May 24 00:07:31 homer kernel: [ 1.246270] pci 0000:00:00.0: PME# supported from D0 D3hot
May 24 00:07:31 homer kernel: [ 1.249770] PCI: bus0: Fast back to back transfers disabled
May 24 00:07:31 homer kernel: [ 1.250043] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
May 24 00:07:31 homer kernel: [ 1.250132] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
May 24 00:07:31 homer kernel: [ 1.250410] pci 0000:01:00.0: PME# supported from D0 D3hot
May 24 00:07:31 homer kernel: [ 1.253818] PCI: bus1: Fast back to back transfers disabled
May 24 00:07:31 homer kernel: [ 1.253930] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
May 24 00:07:31 homer kernel: [ 1.253971] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
May 24 00:07:31 homer kernel: [ 1.254033] pci 0000:00:00.0: PCI bridge to [bus 01]
May 24 00:07:31 homer kernel: [ 1.254072] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
May 24 00:07:31 homer kernel: [ 1.254493] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
May 24 00:07:31 homer kernel: [ 1.254749] pcieport 0000:00:00.0: PME: Signaling with IRQ 62
May 24 00:07:31 homer kernel: [ 1.263067] iproc-rng200 fe104000.rng: hwrng registered
May 24 00:07:31 homer kernel: [ 1.263424] vc-mem: phys_addr:0x00000000 mem_base=0x3f000000 mem_size:0x3f600000(1014 MiB)
May 24 00:07:31 homer kernel: [ 1.264301] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
May 24 00:07:31 homer kernel: [ 1.276651] brd: module loaded
May 24 00:07:31 homer kernel: [ 1.289008] loop: module loaded
May 24 00:07:31 homer kernel: [ 1.290663] Loading iSCSI transport class v2.0-870.
May 24 00:07:31 homer kernel: [ 1.293104] libphy: Fixed MDIO Bus: probed
May 24 00:07:31 homer kernel: [ 1.294893] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
May 24 00:07:31 homer kernel: [ 1.313410] libphy: bcmgenet MII bus: probed
May 24 00:07:31 homer kernel: [ 1.403519] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
May 24 00:07:31 homer kernel: [ 1.404672] usbcore: registered new interface driver r8152
May 24 00:07:31 homer kernel: [ 1.404758] usbcore: registered new interface driver lan78xx
May 24 00:07:31 homer kernel: [ 1.404851] usbcore: registered new interface driver smsc95xx
May 24 00:07:31 homer kernel: [ 1.452413] xhci_hcd 0000:01:00.0: xHCI Host Controller
May 24 00:07:31 homer kernel: [ 1.452466] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
May 24 00:07:31 homer kernel: [ 1.455711] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000030000000890
May 24 00:07:31 homer kernel: [ 1.457029] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
May 24 00:07:31 homer kernel: [ 1.457070] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
May 24 00:07:31 homer kernel: [ 1.457107] usb usb1: Product: xHCI Host Controller
May 24 00:07:31 homer kernel: [ 1.457137] usb usb1: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
May 24 00:07:31 homer kernel: [ 1.457168] usb usb1: SerialNumber: 0000:01:00.0
May 24 00:07:31 homer kernel: [ 1.457922] hub 1-0:1.0: USB hub found
May 24 00:07:31 homer kernel: [ 1.458035] hub 1-0:1.0: 1 port detected
May 24 00:07:31 homer kernel: [ 1.458745] xhci_hcd 0000:01:00.0: xHCI Host Controller
May 24 00:07:31 homer kernel: [ 1.458788] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
May 24 00:07:31 homer kernel: [ 1.458833] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
May 24 00:07:31 homer kernel: [ 1.459312] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
May 24 00:07:31 homer kernel: [ 1.459351] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
May 24 00:07:31 homer kernel: [ 1.459387] usb usb2: Product: xHCI Host Controller
May 24 00:07:31 homer kernel: [ 1.459416] usb usb2: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
May 24 00:07:31 homer kernel: [ 1.459447] usb usb2: SerialNumber: 0000:01:00.0
May 24 00:07:31 homer kernel: [ 1.460175] hub 2-0:1.0: USB hub found
May 24 00:07:31 homer kernel: [ 1.460263] hub 2-0:1.0: 4 ports detected
May 24 00:07:31 homer kernel: [ 1.461926] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
May 24 00:07:31 homer kernel: [ 1.462239] dwc_otg: FIQ enabled
May 24 00:07:31 homer kernel: [ 1.462253] dwc_otg: NAK holdoff enabled
May 24 00:07:31 homer kernel: [ 1.462268] dwc_otg: FIQ split-transaction FSM enabled
May 24 00:07:31 homer kernel: [ 1.462286] Module dwc_common_port init
May 24 00:07:31 homer kernel: [ 1.462737] usbcore: registered new interface driver uas
May 24 00:07:31 homer kernel: [ 1.462865] usbcore: registered new interface driver usb-storage
May 24 00:07:31 homer kernel: [ 1.463076] mousedev: PS/2 mouse device common for all mice
May 24 00:07:31 homer kernel: [ 1.464770] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
May 24 00:07:31 homer kernel: [ 1.468264] sdhci: Secure Digital Host Controller Interface driver
May 24 00:07:31 homer kernel: [ 1.468299] sdhci: Copyright(c) Pierre Ossman
May 24 00:07:31 homer kernel: [ 1.468892] sdhci-pltfm: SDHCI platform and OF driver helper
May 24 00:07:31 homer kernel: [ 1.472339] ledtrig-cpu: registered to indicate activity on CPUs
May 24 00:07:31 homer kernel: [ 1.472699] hid: raw HID events driver (C) Jiri Kosina
May 24 00:07:31 homer kernel: [ 1.472902] usbcore: registered new interface driver usbhid
May 24 00:07:31 homer kernel: [ 1.472932] usbhid: USB HID core driver
May 24 00:07:31 homer kernel: [ 1.478692] Initializing XFRM netlink socket
May 24 00:07:31 homer kernel: [ 1.478755] NET: Registered protocol family 17
May 24 00:07:31 homer kernel: [ 1.478875] Key type dns_resolver registered
May 24 00:07:31 homer kernel: [ 1.479244] Registering SWP/SWPB emulation handler
May 24 00:07:31 homer kernel: [ 1.479423] registered taskstats version 1
May 24 00:07:31 homer kernel: [ 1.479462] Loading compiled-in X.509 certificates
May 24 00:07:31 homer kernel: [ 1.480315] Key type ._fscrypt registered
May 24 00:07:31 homer kernel: [ 1.480346] Key type .fscrypt registered
May 24 00:07:31 homer kernel: [ 1.480374] Key type fscrypt-provisioning registered
May 24 00:07:31 homer kernel: [ 1.491907] uart-pl011 fe201000.serial: there is not valid maps for state default
May 24 00:07:31 homer kernel: [ 1.492237] uart-pl011 fe201000.serial: cts_event_workaround enabled
May 24 00:07:31 homer kernel: [ 1.492329] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
May 24 00:07:31 homer kernel: [ 1.499165] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
May 24 00:07:31 homer kernel: [ 1.503766] of_cfs_init
May 24 00:07:31 homer kernel: [ 1.504037] of_cfs_init: OK
May 24 00:07:31 homer kernel: [ 1.536058] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
May 24 00:07:31 homer kernel: [ 1.536897] Waiting for root device PARTUUID=cc1986ed-02...
May 24 00:07:31 homer kernel: [ 1.823384] usb 1-1: new high-speed USB device number 2 using xhci_hcd
May 24 00:07:31 homer kernel: [ 2.006067] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
May 24 00:07:31 homer kernel: [ 2.006108] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
May 24 00:07:31 homer kernel: [ 2.006142] usb 1-1: Product: USB2.0 Hub
May 24 00:07:31 homer kernel: [ 2.007916] hub 1-1:1.0: USB hub found
May 24 00:07:31 homer kernel: [ 2.008236] hub 1-1:1.0: 4 ports detected
May 24 00:07:31 homer kernel: [ 2.153829] usb 2-2: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
May 24 00:07:31 homer kernel: [ 2.185060] usb 2-2: New USB device found, idVendor=174c, idProduct=0857, bcdDevice= 1.00
May 24 00:07:31 homer kernel: [ 2.185100] usb 2-2: New USB device strings: Mfr=2, Product=3, SerialNumber=1
May 24 00:07:31 homer kernel: [ 2.185133] usb 2-2: Product: X857
May 24 00:07:31 homer kernel: [ 2.185162] usb 2-2: Manufacturer: SupTronics
May 24 00:07:31 homer kernel: [ 2.185191] usb 2-2: SerialNumber: 20200700026A
May 24 00:07:31 homer kernel: [ 2.208450] scsi host0: uas
May 24 00:07:31 homer kernel: [ 2.209801] scsi 0:0:0:0: Direct-Access TS32GMSA 370 0 PQ: 0 ANSI: 6
May 24 00:07:31 homer kernel: [ 2.212059] sd 0:0:0:0: [sda] 62533296 512-byte logical blocks: (32.0 GB/29.8 GiB)
May 24 00:07:31 homer kernel: [ 2.212275] sd 0:0:0:0: [sda] Write Protect is off
May 24 00:07:31 homer kernel: [ 2.212310] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
May 24 00:07:31 homer kernel: [ 2.212670] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
May 24 00:07:31 homer kernel: [ 2.213418] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes
May 24 00:07:31 homer kernel: [ 2.215299] sda: sda1 sda2
May 24 00:07:31 homer kernel: [ 2.218004] random: fast init done
May 24 00:07:31 homer kernel: [ 2.218477] sd 0:0:0:0: [sda] Attached SCSI disk
May 24 00:07:31 homer kernel: [ 2.238866] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
May 24 00:07:31 homer kernel: [ 2.238907] EXT4-fs (sda2): write access will be enabled during recovery
May 24 00:07:31 homer kernel: [ 2.333414] usb 1-1.3: new full-speed USB device number 3 using xhci_hcd
May 24 00:07:31 homer kernel: [ 2.474142] usb 1-1.3: New USB device found, idVendor=0658, idProduct=0200, bcdDevice= 0.00
May 24 00:07:31 homer kernel: [ 2.474191] usb 1-1.3: New USB device strings: Mfr=0, Product=0, SerialNumber=1
May 24 00:07:31 homer kernel: [ 2.474229] usb 1-1.3: SerialNumber: 12345678-9012-3456-7890-123456789012
May 24 00:07:31 homer kernel: [ 2.607869] EXT4-fs (sda2): orphan cleanup on readonly fs
May 24 00:07:31 homer kernel: [ 2.615738] EXT4-fs (sda2): 6 orphan inodes deleted
May 24 00:07:31 homer kernel: [ 2.615774] EXT4-fs (sda2): recovery complete
May 24 00:07:31 homer kernel: [ 2.630490] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
May 24 00:07:31 homer kernel: [ 2.630594] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
May 24 00:07:31 homer kernel: [ 2.633915] devtmpfs: mounted
May 24 00:07:31 homer kernel: [ 2.642729] Freeing unused kernel memory: 2048K
May 24 00:07:31 homer kernel: [ 2.663679] Run /sbin/init as init process
May 24 00:07:31 homer kernel: [ 2.663709] with arguments:
May 24 00:07:31 homer kernel: [ 2.663723] /sbin/init
May 24 00:07:31 homer kernel: [ 2.663737] with environment:
May 24 00:07:31 homer kernel: [ 2.663752] HOME=/
May 24 00:07:31 homer kernel: [ 2.663766] TERM=linux
May 24 00:07:31 homer kernel: [ 3.075865] NET: Registered protocol family 10
May 24 00:07:31 homer kernel: [ 3.077303] Segment Routing with IPv6
May 24 00:07:31 homer kernel: [ 3.884280] random: systemd: uninitialized urandom read (16 bytes read)
May 24 00:07:31 homer kernel: [ 3.899232] random: systemd: uninitialized urandom read (16 bytes read)
May 24 00:07:31 homer kernel: [ 3.903240] random: systemd: uninitialized urandom read (16 bytes read)
May 24 00:07:31 homer kernel: [ 4.513461] EXT4-fs (sda2): re-mounted. Opts: (null)
May 24 00:07:31 homer kernel: [ 5.388111] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
May 24 00:07:31 homer kernel: [ 5.390557] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
May 24 00:07:31 homer kernel: [ 5.392077] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
May 24 00:07:31 homer kernel: [ 5.393851] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
May 24 00:07:31 homer kernel: [ 5.462142] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
May 24 00:07:31 homer kernel: [ 5.463067] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
May 24 00:07:31 homer kernel: [ 5.463626] mc: Linux media interface: v0.10
May 24 00:07:31 homer kernel: [ 5.465769] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
May 24 00:07:31 homer kernel: [ 5.465796] [vc_sm_connected_init]: start
May 24 00:07:31 homer kernel: [ 5.466504] vc_sm_cma_vchi_init: failed to open VCHI service (-1)
May 24 00:07:31 homer kernel: [ 5.466525] [vc_sm_connected_init]: failed to initialize shared memory service
May 24 00:07:31 homer kernel: [ 5.486140] bcm2835_audio bcm2835_audio: card created with 8 channels
May 24 00:07:31 homer kernel: [ 5.531512] videodev: Linux video capture interface: v2.00
May 24 00:07:31 homer kernel: [ 5.547970] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
May 24 00:07:31 homer kernel: [ 5.548178] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
May 24 00:07:31 homer kernel: [ 5.563488] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
May 24 00:07:31 homer kernel: [ 5.566989] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
May 24 00:07:31 homer kernel: [ 5.586372] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
May 24 00:07:31 homer kernel: [ 5.592609] bcm2835_mmal_vchiq: Failed to open VCHI service connection (status=-1)
May 24 00:07:31 homer kernel: [ 5.593857] bcm2835_mmal_vchiq: Failed to open VCHI service connection (status=-1)
May 24 00:07:31 homer kernel: [ 5.606411] bcm2835_mmal_vchiq: Failed to open VCHI service connection (status=-1)
May 24 00:07:31 homer kernel: [ 5.855054] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
May 24 00:07:31 homer kernel: [ 5.869837] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
May 24 00:07:31 homer kernel: [ 5.872512] usbcore: registered new interface driver cdc_acm
May 24 00:07:31 homer kernel: [ 5.872530] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
May 24 00:07:31 homer kernel: [ 5.928642] sd 0:0:0:0: Attached scsi generic sg0 type 0
May 24 00:07:31 homer kernel: [ 5.938946] [drm] No displays found. Consider forcing hotplug if HDMI is attached
May 24 00:07:31 homer kernel: [ 5.939076] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
May 24 00:07:31 homer kernel: [ 5.939494] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
May 24 00:07:31 homer kernel: [ 8.317984] 8021q: 802.1Q VLAN Support v1.8
May 24 00:07:31 homer kernel: [ 8.329742] uart-pl011 fe201000.serial: no DMA platform data
May 24 00:07:31 homer kernel: [ 8.530373] cfg80211: Loading compiled-in X.509 certificates for regulatory database
May 24 00:07:31 homer kernel: [ 8.573475] Adding 2097148k swap on /var/swap. Priority:-2 extents:26 across:4308988k SSFS
May 24 00:07:31 homer kernel: [ 8.640860] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
May 24 00:07:31 homer kernel: [ 8.784552] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
May 24 00:07:31 homer kernel: [ 8.785755] bcmgenet fd580000.ethernet eth0: Link is Down
May 24 00:07:34 homer kernel: [ 11.610849] random: crng init done
May 24 00:07:34 homer kernel: [ 11.610864] random: 7 urandom warning(s) missed due to ratelimiting
May 24 00:07:36 homer kernel: [ 13.993644] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
May 24 00:07:36 homer kernel: [ 13.993701] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
May 24 00:07:37 homer kernel: [ 15.080864] Bluetooth: Core ver 2.22
May 24 00:07:37 homer kernel: [ 15.080971] NET: Registered protocol family 31
May 24 00:07:37 homer kernel: [ 15.080987] Bluetooth: HCI device and connection manager initialized
May 24 00:07:37 homer kernel: [ 15.081017] Bluetooth: HCI socket layer initialized
May 24 00:07:37 homer kernel: [ 15.081040] Bluetooth: L2CAP socket layer initialized
May 24 00:07:37 homer kernel: [ 15.081074] Bluetooth: SCO socket layer initialized
May 24 00:07:37 homer kernel: [ 15.088583] Bluetooth: HCI UART driver ver 2.3
May 24 00:07:37 homer kernel: [ 15.088606] Bluetooth: HCI UART protocol H4 registered
May 24 00:07:37 homer kernel: [ 15.088751] Bluetooth: HCI UART protocol Three-wire (H5) registered
May 24 00:07:37 homer kernel: [ 15.089107] Bluetooth: HCI UART protocol Broadcom registered
May 24 00:07:38 homer kernel: [ 15.414769] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
May 24 00:07:38 homer kernel: [ 15.414788] Bluetooth: BNEP filters: protocol multicast
May 24 00:07:38 homer kernel: [ 15.414817] Bluetooth: BNEP socket layer initialized
May 24 08:41:50 homer kernel: [ 15.922948] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
May 24 08:41:50 homer kernel: [ 16.149012] tun: Universal TUN/TAP device driver, 1.6
May 24 08:42:06 homer kernel: [ 31.832278] vcc-sd: disabling
May 24 08:43:09 homer kernel: [ 94.535514] device eth0 entered promiscuous mode
The entries from 08:4x am come from a hard reset.
