@ bhomeyer
Thanks for the binding - it is working quite well.
During configuration of the bridge I cannot set the serverID - following warning message:
2021-02-02 12:53:21.309 [WARN ] [re.config.core.internal.ConfigMapper] - Could not set field value for field ‘serverID’: Can not set java.lang.String field org.openhab.binding.speedtest.internal.speedtestConfiguration.serverID to java.math.BigDecimal
If it is blank there is no warning.
Thanks for any advice.
Georg
Today I updated the binding to make use of that new trigger channel you talked about. Maybe I’m just blind, but I can’t see any new channels that would allow me to trigger the speedtest.
These are the channels that are available with the latest version (0.4)
It is the items file that is autogenerated from the equipment configuration which holds all available channels - so it’s the same as the UI Things → Channels tab
Thanks for putting the work into this addon. I tried in vain to get the Network binding speedtest to work. It just wasn’t successful as I’m not a network guy.
I run OH3.1 snapshot on an old Windows 10 laptop as a server. I installed the Ookla Cli .exe file as documented and this runs as expected. I got the standard GDPR stuff initially but it doesn’t require this again ater the initial run.
On installing the addon I have tried to configure the Binding without success. Once pointed to the path on my laptop I get the following:
The strange thing is that the local servers are being picked up?
The Thing initially goes green and online for about 1 second before the “configuration error” is displayed. Any thoughts?
can you guys help me with this issue. i am running openHAB in a Docker, Synology DS218+, i installed the speedtest binding and ookla speedtest. I test it and it is running well:
EDIT: i got this sorted. It was the GDPR issue, if i run this in the docker instance it runs with root and not openhab. changing the user to openhab, run the speedtest and accepting the license agreement did the trick.
