Hi Everybody
based on thermostat widget from Nico_R i develop a widget for Personal Weather Station
These are some images
The widget is configurable, you can enable only wind, temperature,UV index information or a combination.
Shapes are configurable for every single “sub Widget” (wind, temperature/humidity, UV index and solar irradiation)
data information can be showed under every single sub widget or in a single box at the bottom, you can decide to show or not group information.
font colors are configurable for every single sub widget
following the txt file with yaml code
OH3_Livio_PWS_FULL_Information.txt (86.0 KB)
comment, and improvements are welocme…
