icompas
(Immo)
#1
Referring to this article
I like to achieve this using the HTTP binding configured via the MainUI.
So, I have:
The result:
Requesting 'http://192.168.2.100:8080/rest/thingstr064:fritzbox:8a568ab412' (method='GET', content='null') failed: 404 Not Found
Testing this query using the API Explorer, all works fine. And issueing a CURL request on a CLI works also.
Anyone, any idea?
der_micha
(Michael)
#2
I think you need the AVM-Binding in addition. With this Binding you get the Device Informations.
icompas
(Immo)
#3
That one is installed also.
But, the TR-064 is actually providing this information via a REST-API call.
hare0815
(Harald)
#4
may be this will help you:
icompas
(Immo)
#5
Ok, I tried the suggested link again,
and figured, I had some cut & paste issues in that provided rule.
So, although I made a step forward, I would like to see that working using the HTTP binding.
