OH3 with InfluxDB (1.8.x) and Grafana - unable to write to database
OH: 3.1
InfluxDB: 1.8.6
Rpi: Raspberry Pi 3 B+ (B Plus) with 1.4 GHz 64-bit Quad-Core Processor, 1 GB RAM
I’ve followed the steps in the setup guide found at: InfluxDB+Grafana persistence and graphing
I’m getting a log error stating that InfluxDB cannot write to my database:
and
My files appear to all be the same as the influxdb/grafana as those in the set up guide (and the sine wave example from the guide does write data to my database and display in Grafana):
openhab/services/influxdb.cfg
url=http://10.0.0.3:8086
user=openhab
password=password123
db=openhab
retentionPolicy=autogen
openhab/persistence/influxdb.persist
Strategies {
        everyHour : "0 0 * * * ?"
        everyDay  : "0 0 0 * * ?"
        // if no strategy is specified for an Item entry below, the default list will be used
       default = everyChange
Items {
	pulseOx_wellue_bloodOx : strategy = everyChange, restoreOnStartup
	pulseOx_wellue_pulseRate : strategy = everyChange, restoreOnStartup
	* : strategy = everyUpdate, restoreOnStartup
I’m using a transformation for each item (both are essentially the same):
openhab/transform/pulseOx-wellue-bloodOx.js
(function(i){
	var newStr = i;
	var compStr = newStr.substring(0,8);
	if (compStr == "FE0A5500") {
		var retVal = newStr.substring(10,12);
		retVal = parseInt(retVal,16);
		return retVal;
})(input)
Here is one of my item files:
openhab/items/pulseOx_wellue_oxygenLevel.items
Number pulseOx_wellue_bloodOx "Wellue Blood Oxygen" {influxdb="bloodOxWellue", channel="bluetooth:generic:hci0:pulseOxWellue:service-0xFFE0-char-0xFFE4" [profile="transform:JS", function="pulseOx-wellue-bloodOx.js"]}
Has anyone run into this problem? Can anyone point me to a solution?
I have read through the following topics - sadly, have not helped me find a solution:
thanks!
This thread: OH3 InfluxDB2 is about influxdb2 but it shows the same error message. May be suggestions from that thread help in your case as well.
@Wolfgang_S
Thank you, for sending along that link.
There is a slight difference between the error in that post (OH3 InfluxDB2) and the one I’m experiencing:
OH3 InfluxDB2 : …UnauthorizedException: unauthorized access
Error I’m experiencing : …UnauthorizedException: null
I will definitely try using a token (as per the post).
thanks again for your response.
UPDATE: unable to create a token because I’m using InfluxDB 1.8.x and not Influx DB 2.x — Still not working.
