[OH4 StartUp WARN] The transformation add-on 'javascript' does not exist - ignoring it
I did startOH 4 with a fresh openhabian install on a raspi4 and used a BackUp from 3.4.2 to get all things, items etc…
Since I used JavaScript Transformation before, the restore from BackUp did put it on the “list” for installs.
How can I remove this transformation from this “list”?
The file “/var/lib/openhab/config/org/openhab/addons.config” does show this entry, but that is not a place for user interference (IMHO).
Perhaps not but that’s the only way I know of to remove it. It’s not actually installed so you can’t do it with karaf console nor the REST API. If you are not already using /etc/openhab/addons.cfg you probably don’t want to start doing so now.
The following startup was nice and clean :smiley:
Many thanks from an
I have the same problem.
I removed addons.config and restarted openhab.
Afterwards this file was created automatically with the following content:
:org.apache.felix.configadmin.revision:=L"1"
package=“standard”
service.pid=“org.openhab.addons”
But my problem is the same. Hundreds of warnings like
2023-07-29 01:28:17.161 [WARN ] [s.internal.SingleValueTransformation] - couldn’t transform response because transformationService of type ‘JS’ is unavailable
Any suggestions?
I used this method as well as editing: /var/lib/openhab/config/org/openhab/addons.config
Mine looked like this:
openha-cli console
config:edit org.openhab.addons
config:property-list
config:property-set transformation regex,jsonpath
config:update
Then restarted OH4 and no more javascript messages.
The posted WARN tells that your setup uses a JavaScrpt transform (in a sitemap file for example).
and how can I find it in my sitemaps?
Search for any of your .js files mentioned in your sitemap files.
Hi, ich habe oh4 im qnap container und scheinbar keine openhab-cli console
Wenn ich den container beende, und im addons.config
transformation=“exec,javascript,map,regex,xpath,jsonpath”
javascript entferne.. ist es nach dem neustart wieder da..weil es wohl irgendwo in der db och steht.. oder ?
irgendwelche ideen ?
Yes, english please, this is an international community! :wink:
Did you edit this file:
It is in there as well.
Sorry, didn’t recognized it yesterday when looking quick for a solution…
I have openhab running in a qnap container and migrated via a new docke/composer file to version 4. I have mounted volumes outsite the container with all my items, tthings etc. files and for sure i also edited the addons.config… once after having stopped the container.. once within the running container… allways it come back! I don’t have the openhab-cli console or the path is not mounted… i cannot run it.. i only have console access to the container… where to look for openhab-cli maybe or which oher solution is possible? is there another adaption to made for using oh4 instead of oh3?
I have the same issue on my system. I mv addons.cfg to addons.cfg.bak. I get this message on every reboot and if i remove or install bindings.
There is no .js on my sitemap.
See @ubeaut’s reply above. If you are not using addons.cfg, there is a different file to check as well.
OK now I understand.
openhab-cli console
config:property-set transformation regex,jsonpath,exec,...
config:update
ctrl d
This will edit both files:
and
/var/lib/openhab/etc/org.openhab.addons.cfg
Important is, that you check your list before you set transformation. Only javascript isn’t needed here. I copy what i get in list and remove javascript.
My list look like this: regex,jsonpath,exec,map,regex,jinja
For me that is the real solution for this issue.
Thanks.
