Hi, all together,
I am fairly new to camera binding and trying to get the binding running faultlessly in my OpenHAB environment.
Regardings the documentation I turned the trace logs on as well as searching for a related topic here.
Unfortunately, I could not find any solution, yet.
Currently, I am running an OpenHAB Server on a Windows 10 WSL2 Docker image.
Everything is working well until I add at least one thing related to the IpCamear binding.
All bound cameras are configured the same way, as described bellow:
Thing ipcamera:onvif:BackDoor "Camera back door" @ "backyard" [
ipAddress="192.168.178.106",
username="username",
password="password",
onvifPort="8899",
port="80",
updateImageWhen="1",
pollTime="60000",
serverPort="5503",
mjpegUrl="ffmpeg",
mjpegOptions="-c:v libx265 -q:v 3 -vf scale=640:-2",
ffmpegLocation="/usr/bin/ffmpeg",
ffmpegOutput="/openhab/html/cameras/cam_backdoor/",
ffmpegInput="rtsp://192.168.178.106:554/user=username_password=password_channel=1_stream=0.sdp?real_stream",
snapshotUrl="http://192.168.178.106:80/webcapture.jpg?command=snap&channel=1&user=username&password=password"
The items are mapped accordingly:
Switch Cam_BackDoor_PollImage "Camera back door - Poll Image" <camera> {channel="ipcamera:onvif:BackDoor:pollImage"}
As well as the link within the sitemap:
Text label="Camera back door" icon="camera" {
Video url="http://127.0.0.1:5503/snapshots.mjpeg" encoding="mjpeg"
Switch item=Cam_BackDoor_PollImage label="Refrash image" mappings=[ON="Refresh"]
With this configuration, I noticed, that the cameras are refreshed/polled several times during the day due to a communication error within the events.log:
2021-03-31 01:38:47.082 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'ipcamera:onvif:BackDoor' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Connection Timeout: Check your IP and PORT are correct and the camera can be reached.
2021-03-31 01:39:54.128 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'ipcamera:onvif:BackDoor' changed from OFFLINE (COMMUNICATION_ERROR): Connection Timeout: Check your IP and PORT are correct and the camera can be reached. to ONLINE
2021-03-31 01:41:59.642 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'ipcamera:onvif:BackDoor' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Connection Timeout: Check your IP and PORT are correct and the camera can be reached.
2021-03-31 01:42:03.161 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'ipcamera:onvif:BackDoor' changed from OFFLINE (COMMUNICATION_ERROR): Connection Timeout: Check your IP and PORT are correct and the camera can be reached. to ONLINE
2021-03-31 01:56:41.846 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'ipcamera:onvif:BackDoor' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Connection Timeout: Check your IP and PORT are correct and the camera can be reached.
2021-03-31 01:56:50.760 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'ipcamera:onvif:BackDoor' changed from OFFLINE (COMMUNICATION_ERROR): Connection Timeout: Check your IP and PORT are correct and the camera can be reached. to ONLINE
2021-03-31 02:40:56.268 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'ipcamera:onvif:BackDoor' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Connection Timeout: Check your IP and PORT are correct and the camera can be reached.
2021-03-31 02:41:03.833 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'ipcamera:onvif:BackDoor' changed from OFFLINE (COMMUNICATION_ERROR): Connection Timeout: Check your IP and PORT are correct and the camera can be reached. to ONLINE
Finally, the system breaks after about 20 to 24 hours with the following exception within the openhab.log:
2021-03-31 03:16:47.395 [WARN ] [io.netty.channel.AbstractChannel ] - Force-closing a channel whose registration task was not accepted by an event loop: [id: 0x027dc1f5]
java.util.concurrent.RejectedExecutionException: event executor terminated
at io.netty.util.concurrent.SingleThreadEventExecutor.reject(SingleThreadEventExecutor.java:981) ~[bundleFile:4.1.42.Final]
at io.netty.util.concurrent.SingleThreadEventExecutor.offerTask(SingleThreadEventExecutor.java:388) ~[bundleFile:4.1.42.Final]
at io.netty.util.concurrent.SingleThreadEventExecutor.addTask(SingleThreadEventExecutor.java:381) ~[bundleFile:4.1.42.Final]
at io.netty.util.concurrent.SingleThreadEventExecutor.execute(SingleThreadEventExecutor.java:880) ~[bundleFile:4.1.42.Final]
at io.netty.channel.AbstractChannel$AbstractUnsafe.register(AbstractChannel.java:472) [bundleFile:4.1.42.Final]
at io.netty.channel.SingleThreadEventLoop.register(SingleThreadEventLoop.java:87) [bundleFile:4.1.42.Final]
at io.netty.channel.SingleThreadEventLoop.register(SingleThreadEventLoop.java:81) [bundleFile:4.1.42.Final]
at io.netty.channel.MultithreadEventLoopGroup.register(MultithreadEventLoopGroup.java:86) [bundleFile:4.1.42.Final]
at io.netty.bootstrap.AbstractBootstrap.initAndRegister(AbstractBootstrap.java:311) [bundleFile:4.1.42.Final]
at io.netty.bootstrap.Bootstrap.doResolveAndConnect(Bootstrap.java:157) [bundleFile:4.1.42.Final]
at io.netty.bootstrap.Bootstrap.connect(Bootstrap.java:141) [bundleFile:4.1.42.Final]
at org.openhab.binding.ipcamera.internal.onvif.OnvifConnection.sendOnvifRequest(OnvifConnection.java:518) [bundleFile:?]
at org.openhab.binding.ipcamera.internal.onvif.OnvifConnection.connect(OnvifConnection.java:818) [bundleFile:?]
at org.openhab.binding.ipcamera.internal.handler.IpCameraHandler.pollCameraRunnable(IpCameraHandler.java:1572) [bundleFile:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) [?:?]
2021-03-31 03:16:47.397 [ERROR] [ent.DefaultPromise.rejectedExecution] - Failed to submit a listener notification task. Event loop shut down?
at io.netty.util.concurrent.DefaultPromise.safeExecute(DefaultPromise.java:841) [bundleFile:4.1.42.Final]
at io.netty.util.concurrent.DefaultPromise.notifyListeners(DefaultPromise.java:498) [bundleFile:4.1.42.Final]
at io.netty.util.concurrent.DefaultPromise.addListener(DefaultPromise.java:183) [bundleFile:4.1.42.Final]
at io.netty.channel.DefaultChannelPromise.addListener(DefaultChannelPromise.java:95) [bundleFile:4.1.42.Final]
at io.netty.channel.DefaultChannelPromise.addListener(DefaultChannelPromise.java:30) [bundleFile:4.1.42.Final]
This warnign and error log occures until the system is down with the las logs:
2021-03-31 03:28:12.188 [WARN ] [concurrent.SingleThreadEventExecutor] - An event executor terminated with non-empty task queue (9)
2021-03-31 03:28:12.188 [WARN ] [concurrent.SingleThreadEventExecutor] - An event executor terminated with non-empty task queue (10)
2021-03-31 03:28:12.190 [WARN ] [concurrent.SingleThreadEventExecutor] - An event executor terminated with non-empty task queue (11)
2021-03-31 03:28:12.193 [WARN ] [concurrent.SingleThreadEventExecutor] - Unexpected exception from an event executor:
java.lang.OutOfMemoryError: Java heap space
2021-03-31 03:28:12.195 [WARN ] [til.concurrent.AbstractEventExecutor] - A task raised an exception. Task: ScheduledFutureTask@4b685a0d(uncancellable, task: Callable(task: io.netty.handler.timeout.IdleStateHandler$AllIdleTimeoutTask@75ba9067, result: null), deadline: 64216832269600, period: 0)
2021-03-31 03:28:12.196 [WARN ] [e.jetty.util.thread.QueuedThreadPool] -
2021-03-31 03:28:12.197 [WARN ] [concurrent.SingleThreadEventExecutor] - Unexpected exception from an event executor:
2021-03-31 03:28:12.204 [WARN ] [concurrent.SingleThreadEventExecutor] - An event executor terminated with non-empty task queue (40)
2021-03-31 03:28:12.205 [WARN ] [io.netty.channel.nio.NioEventLoop ] - Unexpected exception in the selector loop.
2021-03-31 03:28:12.206 [WARN ] [concurrent.SingleThreadEventExecutor] - An event executor terminated with non-empty task queue (1)
2021-03-31 03:28:12.206 [WARN ] [concurrent.SingleThreadEventExecutor] - An event executor terminated with non-empty task queue (7)
2021-03-31 03:28:12.320 [WARN ] [e.jetty.util.thread.QueuedThreadPool] -
2021-03-31 03:28:12.322 [WARN ] [e.jetty.util.thread.QueuedThreadPool] -
2021-03-31 03:28:12.325 [WARN ] [e.jetty.util.thread.QueuedThreadPool] -
2021-03-31 03:28:12.330 [WARN ] [concurrent.SingleThreadEventExecutor] - An event executor terminated with non-empty task queue (11)
2021-03-31 03:28:12.330 [WARN ] [e.jetty.util.thread.QueuedThreadPool] -
So with this knowledge, I tried to find similar issues and started reading the documentation a second and a third, without any progress.
Might you know why the errors occur or do you have any hints or suggestions on how I can solve the problem?
Best regards
Stephan
