Hi Kai,
ok
Hi Kai,
ok
i upgraded my [manual] installation on my VM with my usual script (updating the paths to OH2.1) and everything seems to work flawlessly. Many thanks to Kai and all developers for this awesome work! I will donate a few bucks to the foundation.
Greetings,
Stef
For all who were waiting for it: The next 2.2.0-SNAPSHOT builds are now available as well
@george.erhan The heise article is more or less a summary of the english article by Kai himself: openHAB 2.1 Release - Kai Kreuzer
Congratulations. What is the best method to update openHab from 2.0 to 2.1 on Synology ?
Regards,
Jibet
Hello good sir, will there be an updated raspberry pi image for openhab 2.1 ?
Sorry , i figured it out.
sudo apt-get update
sudo apt-get install
sudo apt-get upgrade
I already working on it, please patience âŠ
My openhabian installation is crashing after update/upgrade more information in
Iâm not sure if it is related to 2.1 or linux upgrade.
MIchal
My RFXtrx433E stopped working after I upgraded (from 2.0 stable) because the /etc/default/openhab2 file was overwritten. So I had to re-add â-Dgnu.io.rxtx.SerialPorts=/dev/ttyUSBrfxtrxâ under EXTRA_JAVA_OPTS to get it to work again. (I had previously created a symlink for it: symlinks · openhab/openhab1-addons Wiki · GitHub).
Perhaps it can help someone who has the same problem.
Thanks to openhabian-config upgrading went very smooth.
I donât need the z-wave binding SNAPSHOT anymore, because openhab2-addons contains the binding already.
Currrently I only have to add the Jeelink Binding.
My configuration of Paper UI survived the update.
Even the /etc/default/openhab2 configuration was kept.
Only the udev rules got deleted some how and I had to restore them.
All in all Iâm courious what OH2.1 has to offer.
Unfortunately the homematic variables cannot be updated any more after upgrading to openhab 2.1! Even in the console smarthome:send varxxx REFRESH does not work any more! Only a complete stop&start of openhab service updates homematic variables once.
Upgraded to 2.1 - (on ubuntu 14.04 lts) using:
sudo apt-get update
/etc/init.d/openhab2 status show that it is running
but accessing the webpage doesnâ t show anything (nor accessing via my App) (connection refused)
same problem with ssh openhab@localhost -p 8101 (connection refused)
I am not a Linux expert - but what am I missing - I have a Unifi NVR running on the same machine (:8443) and that one works still as it should after the upgrade ?
Can someone point me in direction where to look ?
thx
I am running Openhab1 with RFXcom, Zwave & Nikobus-bindings - and until today it was working without a glitch !
If you are coming from openHAB version 1 you should follow the migration tutorial:
this is a typo - I am running Openhab2
That sounds like what I experienced.
I gave up and went to sleep. - And all worked the next morning.
Do know what was wrong, what fixed it, if it will work for you.
I didnât see any traces of OH starting in the log files , neither openhab nor events.
@chris_van_aalst Try stopping openhab, clearing /var/lib/openhab2/cache
and. `/var/lib/openhab2/tmpâ then starting the service.
edit: To those reading, only clear the folders, do not delete.
Ben,
thanks ! this fixed the problem !
fyi:
When I delete the two folders Benjy mentioned, I hget this error in syslog.
Jun 30 22:05:02 openhab start.sh[3625]: Launching the openHAB runtime...
Jun 30 22:05:10 openhab start.sh[3625]: java.lang.RuntimeException: Exception instantiating lock class org.apache.karaf.main.lock.SimpleFileLock
Jun 30 22:05:10 openhab start.sh[3625]: Could not create file lock: Invalid karaf.lock.dir system property '/var/lib/openhab2/tmp' : does not exist
Jun 30 22:05:10 openhab start.sh[3625]: at org.apache.karaf.main.Main.createLock(Main.java:443)
Jun 30 22:05:10 openhab start.sh[3625]: at org.apache.karaf.main.Main.doMonitor(Main.java:371)
Jun 30 22:05:10 openhab start.sh[3625]: at org.apache.karaf.main.Main.access$100(Main.java:72)
Jun 30 22:05:10 openhab start.sh[3625]: at org.apache.karaf.main.Main$2.run(Main.java:362)
Jun 30 22:05:10 openhab start.sh[3625]: Caused by: java.lang.reflect.InvocationTargetException
Recreating the folder helps.
But maybe this should be handled by openhab, like it is for the cache folder.
Yeah, I did the same some time agoâŠ
You can safely delete cache but you shouldnât delete tmp because Karaf needs that.
I usually clear all the stuff within the 2 dirs but donât remove them
Good idea !
