Openhab 2.2 Odroid c2 - rules running very slow after a few hours
I have oh running on an odroid c2…it was running fine till after a few hours when rule processing seems to slow right down.
21:45:00.004 [INFO ] [me.model.script.MorningCentralHeating] - Command Called
21:45:00.002 [INFO ] [rthome.model.script.DayCentralHeating] - Command Called
21:50:59.456 [INFO ] [rthome.model.script.DayCentralHeating] - Checking end time against current.  End: 22 and current 21:50:59.456
21:52:29.500 [INFO ] [rthome.model.script.DayCentralHeating] - (0)   Calculated average: 19.6
21:53:59.522 [INFO ] [rthome.model.script.DayCentralHeating] - (0) Getting average group
21:49:29.375 [INFO ] [me.model.script.MorningCentralHeating] - Checking start/end time against current.  Start: 5 End: 8 and current 21:49:29.374
21:56:59.576 [INFO ] [me.model.script.MorningCentralHeating] - (0)  Getting average from manually calulated average as default
21:58:29.604 [INFO ] [me.model.script.MorningCentralHeating] - (0)   Calculated average: 19.6
21:59:59.626 [INFO ] [me.model.script.MorningCentralHeating] - (0) Getting average group
22:01:29.648 [INFO ] [me.model.script.MorningCentralHeating] - (0)   Calculated average from group: 19.6
21:48:32.179 [INFO ] [.smarthome.model.script.CarportLights] - Command Called
21:47:59.348 [WARN ] [core.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.io.monitor.internal.EventLogger@7e7a7ef7' takes more than 5000ms.
21:47:40.597 [INFO ] [me.model.script.MorningCentralHeating] - Command Called
21:47:40.594 [INFO ] [rthome.model.script.DayCentralHeating] - Command Called
22:08:59.777 [INFO ] [rthome.model.script.DayCentralHeating] - Checking end time against current.  End: 22 and current 22:08:59.777
21:47:39.774 [INFO ] [me.model.script.br_master_temperature] - Posting update as difference < 3:  Sensor: 20.1000003815 Stored: 20.1000003815 Difference: 0.0
22:11:59.908 [INFO ] [marthome.model.script.SMSGateway Date] - Command Called
22:13:29.931 [INFO ] [marthome.model.script.SMSGateway Date] - Getting time from raw sms gateway state
22:14:59.956 [INFO ] [marthome.model.script.SMSGateway Date] - Raw time is 1526206492187
21:46:35.573 [INFO ] [marthome.model.script.SMSGateway Date] - Command Called
you can see the times flicking around on these rules where they should be instant. Its after running for about 5 hours.
Java is openjdk since zulu doesn’t see to easily support 64 bit ubuntu on arm.
Afaik you shouldn’t use 64bit java at arm anyway.
https://docs.openhab.org/installation/index.html#prerequisites
oh that works for me, how do I force install of 32bit then? If I follow the zulu instructions it complains that it can’t find a 64 bit version.
Maybe this will help:
So I got it working on zulu, took a bit.
Had it running over night and it’s performance was better. Didn’t pay attention to my heating control which is supposed to be based on change of temps and between a time period…but when I manually kicked it on, its seemed to come to life.
There seems to be a bunch of processor modes on these boards, and it looked like it was interactive…maybe that scales up and down the cpu. I need to find a more always on option.
