Hi @job,
could you also please post the error message you get while executing the original script? Which version did you use when running the script successfully?
Thanks in advance. Cheers,
Henning
Hi @job,
Henning
Iām terribly sorry, but it looks like i received this error for some time. This wasnāt introduced with 2.3, just some bad testing when implementing the rule.
My logs go back to 2018-04-30 and already include this error. The addition using modulo was done sometimes between 2018-04-23 and 2018-04-30.
Sorry! ![]()
No problem at all, thanks for the feedback. We then do not need to fix this ![]()
Dear Team,
First of all, thanks for your unbelievable efforts that you are investing in the development and maintenance of openhab2!
Allow me to report an issue after the upgrade to OH 2.3 (which was done overnight by a cron job containing āsudo apt-get update/upgrade/dist-upgradeā sequence of commands).
Symptoms:
Logs:
2018-05-29 15:46:32.946 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'Europe/Bucharest'.
2018-05-29 15:46:32.969 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to '44.4239065,26.0739061'.
2018-05-29 15:46:36.937 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-voice-mactts, openhab-voice-marytts, openhab-misc-restdocs, openhab-misc-openhabcloud, openhab-binding-network, openhab-persistence-influxdb, openhab-ui-habpanel, openhab-persistence-mysql, openhab-misc-hueemulation, openhab-binding-mqtt1, openhab-binding-chromecast, openhab-action-nma, openhab-transformation-map, openhab-ui-classic, openhab-binding-kodi, openhab-ui-habmin, openhab-action-mqtt, openhab-ui-paper, openhab-binding-wol1, openhab-binding-http1, openhab-voice-voicerss, openhab-ui-homebuilder, openhab-misc-market, openhab-binding-weather1, openhab-misc-ruleengine, openhab-transformation-jsonpath, openhab-binding-mihome, openhab-binding-wifiled, openhab-ui-basic, openhab-action-mail': Error:
Resource mvn:org.openhab.binding/org.openhab.binding.wifiled/2.3.0 does not contain a manifest
2018-05-29 15:46:42.359 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'weather.items'
2018-05-29 15:46:42.477 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'test.items'
2018-05-29 15:46:42.567 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'sonoff.items', using it anyway:
Duplicate ModelItem 'Sonoff_SC_Light'
2018-05-29 15:46:42.576 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'sonoff.items'
2018-05-29 15:46:43.275 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mapdb.persist'
2018-05-29 15:46:43.313 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'influxdb.persist'
2018-05-29 15:46:46.123 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2018-05-29 15:46:49.845 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'sonoff.rules'
2018-05-29 15:46:50.706 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'smoke_alarm.rules'
2018-05-29 15:46:50.833 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'button.rules'
2018-05-29 15:46:50.917 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'water_leakage.rules'
2018-05-29 15:46:51.840 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'entrance_door_gw_light_on.rules'
2018-05-29 15:46:52.282 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'kids_bedroom.rules'
2018-05-29 15:46:52.465 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'kitchen.rules'
2018-05-29 15:46:52.526 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'refresh.rules' has errors, therefore ignoring it: [8,3]: mismatched input 'else' expecting 'end'
2018-05-29 15:46:53.286 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'tlc.sitemap'
2018-05-29 15:46:53.671 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'kodi.things'
2018-05-29 15:46:56.080 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://10.0.0.4:8080
2018-05-29 15:46:56.089 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://10.0.0.4:8443
2018-05-29 15:47:34.941 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-voice-mactts, openhab-voice-marytts, openhab-misc-restdocs, openhab-misc-openhabcloud, openhab-binding-network, openhab-persistence-influxdb, openhab-ui-habpanel, openhab-persistence-mysql, openhab-misc-hueemulation, openhab-binding-mqtt1, openhab-binding-chromecast, openhab-action-nma, openhab-transformation-map, openhab-ui-classic, openhab-binding-kodi, openhab-ui-habmin, openhab-action-mqtt, openhab-ui-paper, openhab-binding-wol1, openhab-binding-http1, openhab-voice-voicerss, openhab-ui-homebuilder, openhab-misc-market, openhab-binding-weather1, openhab-misc-ruleengine, openhab-transformation-jsonpath, openhab-binding-mihome, openhab-binding-wifiled, openhab-ui-basic, openhab-action-mail': Error:
2018-05-29 15:48:34.771 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-voice-mactts, openhab-voice-marytts, openhab-misc-restdocs, openhab-misc-openhabcloud, openhab-binding-network, openhab-persistence-influxdb, openhab-ui-habpanel, openhab-persistence-mysql, openhab-misc-hueemulation, openhab-binding-mqtt1, openhab-binding-chromecast, openhab-action-nma, openhab-transformation-map, openhab-ui-classic, openhab-binding-kodi, openhab-ui-habmin, openhab-action-mqtt, openhab-ui-paper, openhab-binding-wol1, openhab-binding-http1, openhab-voice-voicerss, openhab-ui-homebuilder, openhab-misc-market, openhab-binding-weather1, openhab-misc-ruleengine, openhab-transformation-jsonpath, openhab-binding-mihome, openhab-binding-wifiled, openhab-ui-basic, openhab-action-mail': Error:
(the last message is repeated every 1 minute).
openhabian@pi:~ $ sudo service openhab2 status
ā openhab2.service - openHAB 2 - empowering the smart home
Loaded: loaded (/usr/lib/systemd/system/openhab2.service; enabled; vendor preset: enabled)
Active: active (running) since Tue 2018-05-29 15:46:21 EEST; 3min 9s ago
Docs: https://www.openhab.org/docs/
https://community.openhab.org
Process: 22511 ExecStop=/usr/share/openhab2/runtime/bin/karaf stop (code=exited, status=0/SUCCESS)
Main PID: 22715 (java)
CGroup: /system.slice/openhab2.service
āā22715 /usr/bin/java -Dopenhab.home=/usr/share/openhab2 -Dopenhab.conf=/etc/openhab2 -Dopenhab.runtime=/usr/share/openhab2/runtime -Dopenhab.userdata=/var/lib/openhab2 -Dopenhab.logdir=/var/log/o
May 29 15:46:21 pi systemd[1]: Started openHAB 2 - empowering the smart home.
May 29 15:46:56 pi karaf[22715]: java.lang.IllegalArgumentException: No enum constant com.yeelight.sdk.enums.DeviceType.bslamp1
May 29 15:46:56 pi karaf[22715]: at java.lang.Enum.valueOf(Enum.java:238)
May 29 15:46:56 pi karaf[22715]: at com.yeelight.sdk.enums.DeviceType.valueOf(DeviceType.java:1)
May 29 15:46:56 pi karaf[22715]: at com.yeelight.sdk.device.DeviceFactory.build(DeviceFactory.java:29)
May 29 15:46:56 pi karaf[22715]: at com.yeelight.sdk.services.DeviceManager$2.run(DeviceManager.java:130)
May 29 15:46:56 pi karaf[22715]: at java.lang.Thread.run(Thread.java:748)
So far I have tried the following without success:
I need your advice on how to force-start the Paper UI web interface (I assume I can manage from there) or any other method to start openhab2 after the upgrade to v2.3.
Thanks a lot,
Cristian
you need to remove the wifiled binding (using addons.cfg) since the 2.3.0 stable release includes a corrupted *.jar file for this binding. Check: 2.3.0 - wifiled/2.3.0 does not contain a manifest
Check the syntax in these 2 files. You can post them here for debugging ![]()
This one: I donāt know⦠maybe a problem with the yeelight binding on 2.3.0 also? Try to uninstall it temporarily to see if things improve
First of all I want to thank everyone working on openHAB very much.
Today Iāve upgraded my installation via apt-get method. Everything looked fine, starting up the service worked, no errors in the logs. Unfortunately nothing worked anymore.
Checking in Paper-UIs Add-ons category I founf that transformations and user interfaces were untouched, but bindings and persistence were all in status āinstallā. Obviously existing choices were not upgraded but deleted.
I installed everything in Paper-UI again and could solve the issue that way. Maybe someone finds this information useful.
maybe you had configured %OPENHAB_CONF/services/addons.cfg file and you chose to replace it with the empty distribution one when apt-get upgrading?
Thank you @Dim !
Iāve removed the wifiled binding directly from file /var/lib/openhab2/config/org/openhab/addons.config:
#binding="mihome,kodi,mqtt1,wol1,weather1,chromecast,wifiled,http1,network"
binding="mihome,kodi,mqtt1,wol1,weather1,chromecast,http1,network"
It worked like a charm! Thanks again!
Regarding the other two issues, Iāll take a look and try to fix them ASAP.
For the yeelight issue, can you please advise which log is being displayed (last 10 lines of it) by the sudo service openhab2 status command? Is it an aggregation of messages from multiple log sources?
Now the output of sudo service openhab2 status has changed:
Active: active (running) since Tue 2018-05-29 18:22:03 EEST; 7min ago
Process: 8149 ExecStop=/usr/share/openhab2/runtime/bin/karaf stop (code=exited, status=0/SUCCESS)
Main PID: 9069 (java)
āā9069 /usr/bin/java -Dopenhab.home=/usr/share/openhab2 -Dopenhab.conf=/etc/openhab2 -Dopenhab.runtime=/usr/share/openhab2/runtime -Dopenhab.userdata=/var/lib/openhab2 -Dopenhab.logdir=/
āā9895 ping -w 5 -c 1 10.0.0.100
May 29 18:23:22 pi karaf[9069]: at su.litvak.chromecast.api.v2.ChromeCast.getStatus(ChromeCast.java:179)
May 29 18:23:22 pi karaf[9069]: at org.openhab.binding.chromecast.internal.ChromecastCommander.handleRefresh(ChromecastCommander.java:87)
May 29 18:23:22 pi karaf[9069]: at org.openhab.binding.chromecast.handler.ChromecastHandler$Coordinator$1.run(ChromecastHandler.java:231)
May 29 18:23:22 pi karaf[9069]: at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
May 29 18:23:22 pi karaf[9069]: at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308)
May 29 18:23:22 pi karaf[9069]: at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180)
May 29 18:23:22 pi karaf[9069]: at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294)
May 29 18:23:22 pi karaf[9069]: at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
May 29 18:23:22 pi karaf[9069]: at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
May 29 18:23:22 pi karaf[9069]: at java.lang.Thread.run(Thread.java:748)
Regards,
Cristian
May i suggest to change the release notes structure for upcoming releases a bit?
I think it would be worth to mention -breaking changes- not as the last heading of that document where new users maybe have closed it already because it is a huge amount of text.
A more popular place could be better for such important info and should not be needed to scroll that long.
Thanks @Dim for your suggestion. The config file was indeed written by the upgrade process as timestamp and an entry in the apt logfile confirms. But it was empty beforehand. This is why I allowed it to be overwritten.
I did all the configuration via Paper-UI and the configuration seems to be written to /var/lib/openhab2/config/org/openhab/addons.config
I donāt know whether this file was overwritten by the upgrade process as well as there are no log entries in the apt logs for this file. The timestamp for this file stems from my last configuration a few minutes ago when I realized the mail action was missing, too.
IF this file was overwritten during the upgrade process, it would explain the issue (and would be a bug in the upgrade process, IMHO). But I have no proof of such a behaviour, so this remains a suspicion at best. Maybe someone else who did not perform the upgrade yet can have a look at the state of the file before and after the upgrade. That might shade a bit of light on this.
Thanks to you, Kai and all the other contributors.
I am really happy with my home automation based on OH and it wouldnāt have been possible without your āsimplificationā
Thanks a lot!
thanks for the update.
one question. did the update but just to find my temp an humidity on mqtt is not functioning any more. all the rest are working. http commands also fine.checked mqtt all msg are coming trough wat can I look at.
There was a breaking json transformation change, so if you use json encoded messages you might be affected by that.
The change was to discard any result which is not a simple value.
no clean items:
Number Bathroom_Temperature "Temperature [%.1fC]" <temperature> (Bathroom) {mqtt="<[flatcntr:/TempCNTR/Bathroom/Temperature:state:default]"}
Number Bathroom_Humidity "Humidity[%.1f%%]" <humidity> (Bathroom) {mqtt="<[flatcntr:/TempCNTR/Bathroom/Humidity:state:default]"}
i update my rpi3 openhab 2.2 and i got these errors can anyone help?
2018-05-30 11:55:59.564 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing āopenhab-binding-http1, openhab-binding-gpio, openhab-misc-market, openhab-binding-nest, openhab-misc-openhabcloud, openhab-binding-network, openhab-ui-habpanel, openhab-binding-weatherunderground, openhab-binding-mqtt1, openhab-binding-chromecast, openhab-binding-harmonyhub, openhab-binding-wifiled, openhab-transformation-map, openhab-binding-expire1, openhab-action-mqtt, openhab-ui-paperā: Error:
remove wifiled binding
try to remove it from console and i get Error executing command: No matching bundles
Do a bundle:list to see if it is installed at all.
Also check your addons folder it you did install it manually ā¦
I had the same issue, for me it helped to remove it from addons.cfg as mentioned in the thread linked by @Dim
Anyone who encounters error messages when using VSE as well?
[Error - 12:01:22] Connection to server is erroring. Shutting down server.
