Iāve tried, does not help. Probably I will try to restore my old system and upgrade once again.
I think it is related to permission rights. When I upgraded using āapt-get upgradeā server started but I had different problem.
after Update my Influx DB Service must be reinstalled, does that mean I also have to reconfigure everything?? I also noticed every Thing is rediscovered, so now I have every thing 2 timesā¦ even Astro moon data and Astro sun data is lsited twice o0
OK, if the IDs are different then there really are two Things. Iāve not seen anyone else report an issue like this so Iāve absolutely no clue how or why it happened. But all I can recommend is to delete the Things, or if you happen to have a backup of your old OH config restore that.
I tried to update from openhab 2.2 to 2.3.
Epic fail.
No uiās - no Paper UI, No Hab Panels.
I checked the status of openhab - it said that it was running.
I tried shutting down and restarting openhabian twice, but no change. Nothing working.
Loaded my 2.2 image.
Everything working again.
Is there any documentation on the openhabian config panel.
The first option is supposedly redundant because the config tool now updates itself when you open the application, so why is there still an update option.
I had an option to update to a stable 2 version, but there was no stable 2.3 as in the upgrade instructions.
What other options in the config panel should I also run?
The fun thing is that my RSS reader actually told me today that openHAB 2.3 was released (guess @Kai did something with his blog to make that old post turn up as new) and then when I checked the forum this thread turn up at the top. Got me kinda confused for a second
