openHAB 2 on Ubuntu
Hi there,
i deceided to move on to openHAB 2, but this is not an easy task. Maybe out there is some one who cpuld help me a little bit.
1.) I really would like to use the nightly build, and i am perfectly aware that from one moment to the other my system could stop working, but i am really not sure what to download and what is about the deb packages.
2.) I read sometime that i should set the propoer rights for the openhab folders in for example /opt/openhab, but i did not find any hints what are the proper rights are
3.) What about the designer for openHAB 2 i did not find anything, is there something like that?
So any hint would be appreciated. Most wanted is a hint for the initial installation and a method to regular update the nightlies.
Thomas
There’s some good info on nightly updates here -:
Either use the offline distro (addons are included) or the online distro (addons are automatically downloaded when you try to install them).
Use the eclipse smart home designer:
Continuing the discussion from Designer:
