openHAB 3.0 Milestone 1 discussion
Indeed, nobody started migrating this binding to openHAB 2/3.
There was a poll quite some time ago, showing just 2 users for this binding.
In general: this issue tracks the status of existing bindings, and what will happen in v3
Thanks for the quick reply.
Oh .. that is unfortunate. My main HA controller is the Leviton OMNIPro IIe.
I love OH, but will need to migrate to another platform if this binding is not supported in the long-term.
There might be another possibility on the horizon. If no one will pick up the work on the OH3-version of the Leviton binding, this might fulfill your needs (even it requires another openHAB instance)
It seems that it´s WiP due to the issue tracker… https://github.com/orgs/openhab/projects/3#card-46836599
You can link 2 OH instances today already using the MQTT event bus so you can keep an OH2 instance to serve all the v1 bindings you need that are not in OH3.
Thanks @RGroll. I’ll keep an eye on this.
You are right :slight_smile: - even if this seems not as easy as install a binding and use autodiscovery
Thanks @mstormi.
FYI - The setup is documented here → how to create such a setup with MQTT
OMG looks so cool the new design! You are the best :wink: Can we help the translate part? I didn’t find any information regarding this
If you’ll do a search a search on the forum here you’ll find there is a openHAB 2 version of the binding in development (The openHAB 1 migration issue actually links to the source code). So that would mean it won’t be to hard to create a version 3. I would suggest start using that openHAB 2 version and test to see if that works on your system, so the developers can make sure the binding works correctly.
A post was split to a new topic: ZigBee Bitron stick
A post was merged into an existing topic: ZigBee Bitron stick
Please people don’t paste any issues into this thread that are not of general nature or not specific to OH3.
Open separate, specific threads, else we’ll all lose the overview quickly, devaluating this thread.
Thank you.
A post was split to a new topic: OH3 logging on start
have migrated from 2.5.9 yesterday, after cleanup most of the setup is working fine.
Have still some issues with rules and exec binding.
anyone has issues with Influx db ? i have cleaned the database after upgrade but still recieve the below error for several items, any expalantion why the data type changes ?
2020-10-16 10:58:00.784 [ERROR] [org.influxdb.impl.BatchProcessor    ] - Batch could not be sent. Data will be lost
org.influxdb.InfluxDBException$FieldTypeConflictException: partial write: field type conflict: input field "value" on measurement "Echo_Kueche_links_TTS_Volume" is type float, already exists as type integer dropped=5
	at org.influxdb.InfluxDBException.buildExceptionFromErrorMessage(InfluxDBException.java:144) ~[bundleFile:?]
	at org.influxdb.InfluxDBException.buildExceptionForErrorState(InfluxDBException.java:173) ~[bundleFile:?]
	at org.influxdb.impl.InfluxDBImpl.execute(InfluxDBImpl.java:827) ~[bundleFile:?]
	at org.influxdb.impl.InfluxDBImpl.write(InfluxDBImpl.java:460) ~[bundleFile:?]
	at org.influxdb.impl.OneShotBatchWriter.write(OneShotBatchWriter.java:22) ~[bundleFile:?]
	at org.influxdb.impl.BatchProcessor.write(BatchProcessor.java:340) [bundleFile:?]
	at org.influxdb.impl.BatchProcessor$2.run(BatchProcessor.java:370) [bundleFile:?]
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
2020-10-16 10:58:00.834 [ERROR] [org.influxdb.impl.BatchProcessor    ] - Batch could not be sent. Data will be lost
org.influxdb.InfluxDBException$FieldTypeConflictException: partial write: field type conflict: input field "value" on measurement "Fibaro_TEMP_12" is type float, already exists as type integer dropped=34
Thomas
For now we’re still in the process of adding the necessary infrastructure ([Main UI] How to organize i18n source files? · Issue #394 · openhab/openhab-webui · GitHub), when it’s ready we’ll probably post an announcement. Thanks for your interest!
I can confirm I’m seeing the same exceptions. I’ve not done any looking into it yet. I see it for many Item types, not just float/integers.
I’m facing an issue with the REST API which is new in 3.0.0, using it with HomeBridge (historically, the HomeKit binding was not satisfying and not supporting enough device types, so I switched to HB for HK)
When HB tries to interact with the REST API, the following happens in stack trace:
2020-10-16 18:58:25.848 [ERROR] [rg.apache.cxf.jaxrs.utils.JAXRSUtils] - No message body reader has been found for class java.lang.String, ContentType: application/octet-stream
2020-10-16 18:58:25.858 [WARN ] [s.impl.WebApplicationExceptionMapper] - javax.ws.rs.WebApplicationException: HTTP 415 Unsupported Media Type
	at org.apache.cxf.jaxrs.utils.JAXRSUtils.readFromMessageBody(JAXRSUtils.java:1382)
	at org.apache.cxf.jaxrs.utils.JAXRSUtils.processRequestBodyParameter(JAXRSUtils.java:877)
	at org.apache.cxf.jaxrs.utils.JAXRSUtils.processParameters(JAXRSUtils.java:822)
	at org.apache.cxf.jaxrs.interceptor.JAXRSInInterceptor.processRequest(JAXRSInInterceptor.java:214)
	at org.apache.cxf.jaxrs.interceptor.JAXRSInInterceptor.handleMessage(JAXRSInInterceptor.java:78)
	at org.apache.cxf.phase.PhaseInterceptorChain.doIntercept(PhaseInterceptorChain.java:308)
	at org.apache.cxf.transport.ChainInitiationObserver.onMessage(ChainInitiationObserver.java:121)
	at org.apache.cxf.transport.http.AbstractHTTPDestination.invoke(AbstractHTTPDestination.java:267)
	at org.apache.cxf.transport.servlet.ServletController.invokeDestination(ServletController.java:234)
	at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:208)
	at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:160)
	at org.apache.cxf.transport.servlet.CXFNonSpringServlet.invoke(CXFNonSpringServlet.java:216)
	at org.apache.cxf.transport.servlet.AbstractHTTPServlet.handleRequest(AbstractHTTPServlet.java:301)
	at org.apache.cxf.transport.servlet.AbstractHTTPServlet.doPost(AbstractHTTPServlet.java:220)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
	at org.apache.cxf.transport.servlet.AbstractHTTPServlet.service(AbstractHTTPServlet.java:276)
	at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:852)
	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:544)
	at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71)
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
	at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:536)
	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127)
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235)
	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1581)
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233)
	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1307)
	at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293)
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188)
	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:482)
	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1549)
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186)
	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1204)
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
	at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80)
	at org.eclipse.jetty.server.Server.handle(Server.java:494)
	at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:374)
	at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:268)
	at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311)
	at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103)
	at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117)
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336)
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313)
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171)
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129)
	at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:367)
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:782)
	at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:918)
	at java.base/java.lang.Thread.run(Thread.java:834)
The request generating this error is the following:
This was perfectly running in 2.5.x.
Please let me know if I’m not reporting the bug in the right place!
Cheers,
Ben
This is more an issue with the HomeBridge plugin than with openHAB.
It’s already been opened as an issue: https://github.com/steilerDev/homebridge-openhab2-complete/issues/87
Well it breaks a backward compatibility with systems compatible with 2.5.x - but anyway good to see that there is already work in progress on this.
