openHAB 3.1 Milestone discussion
exactly the same problem with the mail binding for me. Windows machine. Worked fine in 3.0.1 but not in 3.1.0.M1. Since I did not change anything I guess there is some sort of a change that is causing this so I will not investigate more and instead wait for the next milestone or maybe go for one of the other builds. If someone needs some info about this I will gladly add it here if I can help in any way. I did not get any more errors than the one stated though.
I just installed 3.1.0 M2 on my Pi v4 via openHabian Config, but unfortunately on system start up I see this error..
2021-02-28 16:50:57.663 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model '24g.rules'
2021-02-28 16:50:59.152 [ERROR] [ypes.access.impl.AbstractClassMirror] - resource is empty: java:/Objects/org.openhab.core.model.script.actions.Semantics
java.lang.IllegalStateException: null
	at org.eclipse.xtext.common.types.access.impl.AbstractClassMirror.getEObject(AbstractClassMirror.java:95) [bundleFile:?]
	at org.eclipse.xtext.common.types.access.TypeResource.getEObject(TypeResource.java:95) [bundleFile:?]
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getEObject(ResourceSetImpl.java:223) [bundleFile:?]
	at org.eclipse.xtext.common.types.access.impl.IndexedJvmTypeAccess.getIndexedJvmType(IndexedJvmTypeAccess.java:80) [bundleFile:?]
	at org.eclipse.xtext.common.types.access.impl.IndexedJvmTypeAccess.getIndexedJvmType(IndexedJvmTypeAccess.java:70) [bundleFile:?]
	at org.eclipse.xtext.common.types.access.reflect.ReflectionTypeProvider.findTypeByClass(ReflectionTypeProvider.java:146) [bundleFile:?]
	at org.eclipse.xtext.common.types.access.reflect.ReflectionTypeProvider.findTypeByName(ReflectionTypeProvider.java:88) [bundleFile:?]
	at org.eclipse.xtext.common.types.util.TypeReferences.findDeclaredType(TypeReferences.java:256) [bundleFile:?]
	at org.eclipse.xtext.common.types.util.TypeReferences.findDeclaredType(TypeReferences.java:233) [bundleFile:?]
	at org.eclipse.xtext.xbase.scoping.batch.ImplicitlyImportedFeatures.getTypes(ImplicitlyImportedFeatures.java:82) [bundleFile:?]
	at org.eclipse.xtext.xbase.scoping.batch.ImplicitlyImportedFeatures.getExtensionClasses(ImplicitlyImportedFeatures.java:76) [bundleFile:?]
	at org.eclipse.xtext.xbase.imports.TypeUsageCollector.collectTypeUsages(TypeUsageCollector.java:171) [bundleFile:?]
	at org.eclipse.xtext.xbase.validation.XbaseValidator.checkImports(XbaseValidator.java:1151) [bundleFile:?]
	at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
	at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
	at org.eclipse.xtext.validation.AbstractDeclarativeValidator$MethodWrapper.invoke(AbstractDeclarativeValidator.java:129) [bundleFile:?]
	at org.eclipse.xtext.validation.AbstractDeclarativeValidator.internalValidate(AbstractDeclarativeValidator.java:337) [bundleFile:?]
	at org.eclipse.xtext.validation.AbstractInjectableValidator.validate(AbstractInjectableValidator.java:72) [bundleFile:?]
	at org.eclipse.xtext.validation.CompositeEValidator.validate(CompositeEValidator.java:151) [bundleFile:?]
	at org.eclipse.emf.ecore.util.Diagnostician.doValidate(Diagnostician.java:257) [bundleFile:?]
	at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:244) [bundleFile:?]
	at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:201) [bundleFile:?]
	at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:131) [bundleFile:?]
	at org.openhab.core.model.core.internal.ModelRepositoryImpl.lambda$2(ModelRepositoryImpl.java:280) [bundleFile:?]
	at org.openhab.core.model.core.internal.SafeEMFImpl.call(SafeEMFImpl.java:30) [bundleFile:?]
	at org.openhab.core.model.core.internal.ModelRepositoryImpl.validateModel(ModelRepositoryImpl.java:280) [bundleFile:?]
	at org.openhab.core.model.core.internal.ModelRepositoryImpl.addOrRefreshModel(ModelRepositoryImpl.java:105) [bundleFile:?]
	at org.openhab.core.model.core.internal.folder.FolderObserver.checkFile(FolderObserver.java:249) [bundleFile:?]
	at org.openhab.core.model.core.internal.folder.FolderObserver.processIgnoredFiles(FolderObserver.java:151) [bundleFile:?]
	at org.openhab.core.model.core.internal.folder.FolderObserver.addModelParser(FolderObserver.java:94) [bundleFile:?]
	at org.apache.felix.scr.impl.inject.methods.BaseMethod.invokeMethod(BaseMethod.java:228) [bundleFile:?]
	at org.apache.felix.scr.impl.inject.methods.BaseMethod.access$500(BaseMethod.java:41) [bundleFile:?]
	at org.apache.felix.scr.impl.inject.methods.BaseMethod$Resolved.invoke(BaseMethod.java:664) [bundleFile:?]
	at org.apache.felix.scr.impl.inject.methods.BaseMethod.invoke(BaseMethod.java:510) [bundleFile:?]
	at org.apache.felix.scr.impl.inject.methods.BindMethod.invoke(BindMethod.java:42) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:1813) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.java:1788) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:435) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:325) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:294) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1216) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1137) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:944) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:880) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1168) [bundleFile:?]
	at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:125) [bundleFile:?]
	at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:920) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:469) [org.eclipse.osgi-3.12.100.jar:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:906) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:892) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:128) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:959) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:732) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:1045) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:999) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:666) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:432) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:665) [bundleFile:?]
	at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:338) [bundleFile:?]
	at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:382) [bundleFile:?]
	at org.apache.felix.scr.impl.Activator.access$200(Activator.java:49) [bundleFile:?]
	at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:264) [bundleFile:?]
	at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) [bundleFile:?]
	at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) [bundleFile:?]
	at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) [bundleFile:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) [osgi.core-6.0.0.jar:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) [osgi.core-6.0.0.jar:?]
	at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) [osgi.core-6.0.0.jar:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) [osgi.core-6.0.0.jar:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.container.Module.start(Module.java:467) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1634) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1614) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1585) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1528) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [org.eclipse.osgi-3.12.100.jar:?]
I can reproduce the issue. Unfortunately I do not know how to solve it in a second - I do not use DSL Rules or *.rules files anymore. I used JSR223 Rules for testing and it worked flawlessly.
@Kai Any ideas what I missed in my PR [semantics] Add ActionService to support using Semantics features in Rules by cweitkamp Ā· Pull Request #2088 Ā· openhab/openhab-core Ā· GitHub? I compared everything to Ephemeris and was sure to implemented it in the same way.
Something weird in 3.0.1.M2, here is the openhab.log
2021-02-28 20:54:45.052 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'Europe/Lisbon'.
2021-02-28 20:54:45.095 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to '40.638903841256,-8.648986816406252'.
2021-02-28 20:54:45.098 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to 'pt_PT'.
2021-02-28 20:54:54.228 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mapdb.persist'
2021-02-28 20:54:59.133 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Garden.rules'
2021-02-28 20:55:00.238 [ERROR] [ypes.access.impl.AbstractClassMirror] - resource is empty: java:/Objects/org.openhab.core.model.script.actions.Semantics
	at org.eclipse.xtext.xbase.scoping.batch.XbaseBatchScopeProvider.newSession(XbaseBatchScopeProvider.java:121) [bundleFile:?]
	at org.eclipse.xtext.xbase.typesystem.internal.DefaultReentrantTypeResolver.resolve(DefaultReentrantTypeResolver.java:164) [bundleFile:?]
	at org.eclipse.xtext.xbase.typesystem.internal.DefaultReentrantTypeResolver.reentrantResolve(DefaultReentrantTypeResolver.java:140) [bundleFile:?]
	at org.eclipse.xtext.xbase.typesystem.internal.CachingBatchTypeResolver$LazyResolvedTypes.resolveTypes(CachingBatchTypeResolver.java:81) [bundleFile:?]
	at org.eclipse.xtext.xbase.typesystem.internal.CachingBatchTypeResolver$2.process(CachingBatchTypeResolver.java:58) [bundleFile:?]
	at org.eclipse.xtext.xbase.typesystem.internal.CachingBatchTypeResolver$2.process(CachingBatchTypeResolver.java:54) [bundleFile:?]
	at org.eclipse.xtext.util.concurrent.IUnitOfWork$Void.exec(IUnitOfWork.java:38) [bundleFile:?]
	at org.eclipse.xtext.util.OnChangeEvictingCache.execWithoutCacheClear(OnChangeEvictingCache.java:135) [bundleFile:?]
	at org.eclipse.xtext.xbase.typesystem.internal.CachingBatchTypeResolver.doResolveTypes(CachingBatchTypeResolver.java:54) [bundleFile:?]
	at org.eclipse.xtext.xbase.typesystem.internal.AbstractBatchTypeResolver.resolveTypes(AbstractBatchTypeResolver.java:70) [bundleFile:?]
	at org.eclipse.xtext.xbase.resource.BatchLinkingService.resolveBatched(BatchLinkingService.java:61) [bundleFile:?]
	at org.eclipse.xtext.xbase.resource.BatchLinkingService.resolveBatched(BatchLinkingService.java:42) [bundleFile:?]
	at org.eclipse.xtext.xbase.resource.BatchLinkableResource.getEObject(BatchLinkableResource.java:118) [bundleFile:?]
	at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java:209) [bundleFile:?]
	at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java:269) [bundleFile:?]
	at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eResolveProxy(BasicEObjectImpl.java:1477) [bundleFile:?]
	at org.eclipse.xtext.xbase.impl.XAbstractFeatureCallImplCustom.getFeature(XAbstractFeatureCallImplCustom.java:49) [bundleFile:?]
	at org.eclipse.xtext.xbase.impl.XAbstractFeatureCallImpl.eGet(XAbstractFeatureCallImpl.java:529) [bundleFile:?]
	at org.eclipse.xtext.xbase.impl.XMemberFeatureCallImpl.eGet(XMemberFeatureCallImpl.java:474) [bundleFile:?]
	at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1011) [bundleFile:?]
	at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1003) [bundleFile:?]
	at org.eclipse.emf.ecore.util.EContentsEList$FeatureIteratorImpl.hasNext(EContentsEList.java:439) [bundleFile:?]
	at org.eclipse.emf.ecore.util.EObjectValidator.validate_EveryReferenceIsContained(EObjectValidator.java:782) [bundleFile:?]
	at org.eclipse.emf.ecore.util.EObjectValidator.validate_EveryDefaultConstraint(EObjectValidator.java:355) [bundleFile:?]
	at org.eclipse.emf.ecore.util.EObjectValidator$DynamicEClassValidator.validate(EObjectValidator.java:1426) [bundleFile:?]
	at org.eclipse.emf.ecore.util.EObjectValidator$DynamicEClassValidator.validate(EObjectValidator.java:1429) [bundleFile:?]
	at org.eclipse.emf.ecore.util.EObjectValidator.validate(EObjectValidator.java:333) [bundleFile:?]
2021-02-28 20:55:00.731 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Cloudiness.rules'
2021-02-28 20:55:01.310 [INFO ] [.core.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2021-02-28 20:55:06.322 [INFO ] [org.openhab.ui.internal.UIService   ] - Started UI on port 52288
2021-02-28 20:55:07.618 [INFO ] [nding.http.internal.HttpThingHandler] - Using the insecure client for thing 'http:url:e5a14ec3b0'.
2021-02-28 20:55:07.951 [INFO ] [o.internal.handler.AstroThingHandler] - Scheduled Positional job astro:sun:aveiro every 300 seconds
2021-02-28 20:55:08.578 [WARN ] [rg.openhab.core.io.net.exec.ExecUtil] - Failed to execute commandLine '[arping, --help]'
2021-02-28 20:55:08.784 [INFO ] [ternal.dhcp.DHCPPacketListenerServer] - DHCP request packet listener online
2021-02-28 20:55:09.091 [WARN ] [rg.openhab.core.io.net.exec.ExecUtil] - Failed to execute commandLine '[arping, --help]'
2021-02-28 20:55:10.476 [INFO ] [e.automation.internal.RuleEngineImpl] - Rule engine started.
2021-02-28 20:55:13.294 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.130.1' with clientid 9ba48fb8-c42f-40ea-a4bc-c290b2eef938
2021-02-28 20:55:14.456 [ERROR] [ypes.access.impl.AbstractClassMirror] - resource is empty: java:/Objects/org.openhab.core.model.script.actions.Semantics
	at org.eclipse.xtext.xbase.resource.BatchLinkingService.resolveBatched(BatchLinkingService.java:72) [bundleFile:?]
	at org.eclipse.xtext.xbase.resource.BatchLinkableResource.resolveLazyCrossReferences(BatchLinkableResource.java:166) [bundleFile:?]
	at org.eclipse.xtext.EcoreUtil2.resolveLazyCrossReferences(EcoreUtil2.java:505) [bundleFile:?]
	at org.eclipse.xtext.validation.ResourceValidatorImpl.resolveProxies(ResourceValidatorImpl.java:162) [bundleFile:?]
	at org.eclipse.xtext.validation.ResourceValidatorImpl.validate(ResourceValidatorImpl.java:75) [bundleFile:?]
	at org.openhab.core.model.script.runtime.internal.engine.ScriptEngineImpl.validate(ScriptEngineImpl.java:177) [bundleFile:?]
	at org.openhab.core.model.script.runtime.internal.engine.ScriptEngineImpl.getValidationErrors(ScriptEngineImpl.java:181) [bundleFile:?]
	at org.openhab.core.model.script.runtime.internal.engine.ScriptEngineImpl.parseScriptIntoXTextEObject(ScriptEngineImpl.java:147) [bundleFile:?]
	at org.openhab.core.model.script.runtime.internal.engine.ScriptEngineImpl.newScriptFromString(ScriptEngineImpl.java:111) [bundleFile:?]
	at org.openhab.core.model.script.runtime.internal.engine.DSLScriptEngine.eval(DSLScriptEngine.java:126) [bundleFile:?]
	at org.openhab.core.automation.module.script.internal.handler.ScriptActionHandler.lambda$0(ScriptActionHandler.java:62) [bundleFile:?]
	at java.util.Optional.ifPresent(Optional.java:183) [?:?]
	at org.openhab.core.automation.module.script.internal.handler.ScriptActionHandler.execute(ScriptActionHandler.java:59) [bundleFile:?]
	at org.openhab.core.automation.internal.RuleEngineImpl.executeActions(RuleEngineImpl.java:1179) [bundleFile:?]
	at org.openhab.core.automation.internal.RuleEngineImpl.runRule(RuleEngineImpl.java:987) [bundleFile:?]
	at org.openhab.core.automation.internal.TriggerHandlerCallbackImpl$TriggerData.run(TriggerHandlerCallbackImpl.java:89) [bundleFile:?]
2021-02-28 20:55:17.993 [INFO ] [ab.ui.habpanel.internal.HABPanelTile] - Started HABPanel at /habpanel
2021-02-28 20:58:33.941 [INFO ] [internal.handler.MiIoAbstractHandler] - Mi Device model Unknown Mi IO Device (unknown) identified as: miio:unsupported, thingtype miio:basic. Does not matches thingtype miio:unsupported. Unexpected, unless manual override.
I’ve tried rebooting 3x and it’s always the same.
See openHAB 3.1 Milestone discussion - #23 by AndrewFG
No, but I am trying to investigate.
This seems to break our M2 release unfortunately, so I guess we’ll have to find a fix and do M3 right away :frowning: .
It is weird as I had tested the snapshot yesterday and didn’t come across this issue. But now it is clearly reproducible for everyone…
I’ve converted all *.rules to UI except two, that give an error when converted to UI. Both calculate an average, I’de love to convert then to the UI but I don’t know how to do it.
rule "Calcular Nebulosidade mƩdia"
    Item painel_iluminado changed to OFF
    OU_Weather_Actual_Cloudiness_avg.postUpdate(OU_Weather_Actual_Cloudiness.averageSince(now().minusMinutes(360),"rrd4j"))
I’ve created IllegalStateException during startup when validating DSL rules Ā· Issue #2220 Ā· openhab/openhab-core Ā· GitHub for tracking. (/cc @cweitkamp)
I’m now on 3.1.0 M2. I had two minor problems:
  1. Unifi binding - has a new parameter UniFi OS and I had to turn it ON and then OFF
  2. http binding - I was in 3.1.0.M1 but using a snapshot version. 3.1.0.M2 did not install the included binding automatically
Had the same problem with Unifi with the same soltion (turning UniFi OS on and off). It was giving me a error_handle_uninitialized (in case anyone googles for that problem :slight_smile:)
I just upgraded from 3.0.1 to 3.1.0M2 and can confirm, that all channels from Hue lights with the exception of the Scene channel disappear.
The items are still in the items folder, but disassociated.
After deleting the items and things, going for re-discovering and adding them again, all the channels are back.
/M
Also, there is something wrong with ā€œimageā€ type.
Take for example the Sonos binding. This will transmit the coverart in a channel. This works in BasicUI and PaperUI under OH2.5, but in OH3.1.0M2, the image of the item is broken. If seems, the image field has the value ā€œUNDEFā€.
/M
In version 3.1.0-snapshot this worked very fine:
sendHttpGetRequest(executeCommandLine("curl@@--anyauth@@-u@@MySecretUserID:MySecretPWDWithSpecialCharacters@@http://192.168.1.25/axis-cgi/virtualinput/activate.cgi?schemaversion=1&port=10"))
However, in version 3.1.0.M2 I receive this error message:
java.io.IOException: Cannot run program "curl@@--anyauth@@-u@@MySecretUserID:MySecretPWDWithSpecialCharacters@@http://192.168.1.25/axis-cgi/virtualinput/activate.cgi?schemaversion=1&port=10": error=2, No such file or directory
I have masked my userid and pwd in this post to protect these. When I execute the http in the browser, it prompts for userid and pwd, and after that is entered it executes the command correctly.
Edit : it seems that I now also get the error when reverting to 3.1.0-snapshot version, so it is probably not related to M2 milestone.
I don’t see how that could have worked before. The arguments to executeCommandLine changed in OH 3. If you care about what the script returned, you need to pass a java.time.Duration as the first argument. Then you break up the command (curl) and each individual argument into separate arguments to the call to executeCommandLine. No more is @@ used.
Thanks - I will look at this. I guess it slipped when I tested my migration from 2.5.x to version 3.x.
@rlkoshak : Thanks for the hint, and I realize that I need to change it. However, I do not really know how to achieve this with the new OH 3 syntax in combination with curl. Any input would be highly appreciated - thanks.
Try this instead:
sendHttpGetRequest(executeCommandLine("curl", "--anyauth", "-u", "MySecretUserID:MySecretPWDWithSpecialCharacters", "http://192.168.1.25/axis-cgi/virtualinput/activate.cgi?schemaversion=1&port=10"))
Duration is still missing. Without that there gets no output from curl to sendHttpGetRequest.
Please try this instead:
sendHttpGetRequest(executeCommandLine(Duration.ofSeconds(5), "curl", "--anyauth", "-u", "MySecretUserID:MySecretPWDWithSpecialCharacters", "http://192.168.1.25/axis-cgi/virtualinput/activate.cgi?schemaversion=1&port=10"))
Thanks guys. Now it looks like this:
which gives this response:
2021-03-07 19:19:43.713 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'ihc-17' failed: Illegal character in scheme name at index 0:   % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
100   381  100   381    0     0  63500      0 --:--:-- --:--:-- --:--:-- 63500
100   457    0   457    0     0   1117      0 --:--:-- --:--:-- --:--:--  223k
<?xml version="1.0" encoding="utf-8"?>
<VirtualInputResponse SchemaVersion="1.0" xmlns="http://www.axis.com/vapix/http_cgi/virtualinput1" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.axis.com/vapix/http_cgi/virtualinput1 http://www.axis.com/vapix/http_cgi/virtualinput1_0.xsd">
	<Success>
		<DeactivateSuccess>
			<StateChanged>
				true
			</StateChanged>
		</DeactivateSuccess>
	</Success>
</VirtualInputResponse>
 in ihc
Please note that it indicates that the state on the device actually changed. And when I check the actual device - my Axis camera - it seems to be working correct. However, I do not understand what the errror message in the openhab log means.
The respons in the browser by manually executing the http command is:
<VirtualInputResponse xmlns="http://www.axis.com/vapix/http_cgi/virtualinput1" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" SchemaVersion="1.0" xsi:schemaLocation="http://www.axis.com/vapix/http_cgi/virtualinput1 http://www.axis.com/vapix/http_cgi/virtualinput1_0.xsd">
<Success>
<DeactivateSuccess>
<StateChanged> false </StateChanged>
</Success>
I think the curl option -s (silent) is missing to suppress progress meter or error messages.
So please try:
sendHttpGetRequest(executeCommandLine(Duration.ofSeconds(5), "curl", "-s", "--anyauth", "-u", "MySecretUserID:MySecretPWDWithSpecialCharacters", "http://192.168.1.25/axis-cgi/virtualinput/activate.cgi?schemaversion=1&port=10"))
Thanks - however, the response is the same with the ā€œ-sā€ parameter.
