Please restrict your discussion and question to issues that are specific to latest OH 3.1 milestone
else open your own thread.
On VSC “slowing” OH, think of the LSP server which does “remote” syntax checking of the VSC code in OH. This is particularly nasty if compilation/parsing of a file takes long on your OH box as is sometimes the case e.g. when using Java primitives on ARM.
I understand I should have opened a different thread, sorry for that.
Let me just report my status, for the sake of consistency…
I had various other problems with my OH3 system. Not only the system was slow, stopping VSC did improve, stopping OH did improve even more… but also I had group Items that were simple migration from my OH2 setup that were not updating properly.
All this to say, I ended up changing my SD card and things are now looking much more normal now.
When scanning using zigbee binding or anything really I get in dev console:
TypeError: t.$inputEl is undefined
value http://192.168.0.76:8080/js/app.js:7
loadInbox http://192.168.0.76:8080/js/16.app.js:1
at http://192.168.0.76:8080/js/app.js:7
Qe http://192.168.0.76:8080/js/app.js:7
promise callback*Ye http://192.168.0.76:8080/js/app.js:7
update http://192.168.0.76:8080/js/app.js:7
notify http://192.168.0.76:8080/js/app.js:7
set http://192.168.0.76:8080/js/app.js:7
promise callback*loadInbox http://192.168.0.76:8080/js/16.app.js:1
intervalId http://192.168.0.76:8080/js/16.app.js:1
setInterval handler*scan/< http://192.168.0.76:8080/js/16.app.js:1
promise callback*scan http://192.168.0.76:8080/js/16.app.js:1
qe http://192.168.0.76:8080/js/app.js:7
n http://192.168.0.76:8080/js/app.js:7
$emit http://192.168.0.76:8080/js/app.js:7
a http://192.168.0.76:8080/js/app.js:7
dispatchEvent http://192.168.0.76:8080/js/app.js:23
onClick http://192.168.0.76:8080/js/app.js:23
mounted http://192.168.0.76:8080/js/app.js:23
tn http://192.168.0.76:8080/js/app.js:7
insert http://192.168.0.76:8080/js/app.js:7
O http://192.168.0.76:8080/js/app.js:7
Fr http://192.168.0.76:8080/js/app.js:7
_update http://192.168.0.76:8080/js/app.js:7
get http://192.168.0.76:8080/js/app.js:7
run http://192.168.0.76:8080/js/app.js:7
pn http://192.168.0.76:8080/js/app.js:7
app.js:7:11689
Would this prevent scanning? How can I see in the logs that the zigbee binding is actually scanning?
Yesterday I installed M3 SNAPSHOT Build 2307 which seems to have introduced a new issue in the Mail binding (see log below). The error NoSuchMethodError seems to imply a broken dependency. => Any thoughts?
2021-04-05 10:56:46.104 [WARN ] [ab.binding.mail.internal.SMTPHandler] - Sending the email to the following server failed : <myserver>:465
2021-04-05 10:56:46.106 [WARN ] [ab.binding.mail.internal.SMTPHandler] - java.lang.NoSuchMethodError: 'boolean javax.activation.MimeType.isSpecial(char)'
I have been using the 3.1 M3 official docker image (debian based) on a Synology 920+ since it came out. I noticed a strange behaviour with the rules engine in M3. The rule engine (13:06:33.782 [INFO ] [re.automation.internal.RuleEngineImpl] - Rule engine started.) started only 5 minutes after system startup. If I remember correctly it used to start up much faster in M2.
Well, I consider it an unwanted behaviour. During that time my logs are full of exceptions of rules which cannot be executed and basically a restart of the container takes around 10 minutes … I cannot imagine this is as intended.
