That is your answer to if this needs a new thread. This thread people want to know what the current 3.2 Milestone is like. Create your own thread and be sure to mention what web browser you are using and have tried other ones to compare. Do not reply in this thread.
How to install it with openhabian?
use menu 41 and switch top openHAB Milestone. This will switch to the testing branch.
Hello together, I am not sure if it is right here or in the openhabian topic but same issue with the changed port by updating it is reverted to the old port
I get also this issue
2021-08-17 09:02:41.939 [ERROR] [org.knowm.yank.Yank ] - Error in SQL query!!!
java.sql.SQLException: Table 'openhabian.item0006' doesn't exist Query: SELECT time, value FROM item0006 ORDER BY time DESC LIMIT 0,1 Parameters: []
at org.apache.commons.dbutils.AbstractQueryRunner.rethrow(AbstractQueryRunner.java:392) ~[bundleFile:?]
at org.apache.commons.dbutils.QueryRunner.query(QueryRunner.java:351) ~[bundleFile:?]
at org.apache.commons.dbutils.QueryRunner.query(QueryRunner.java:289) ~[bundleFile:?]
at org.knowm.yank.Yank.queryObjectArrays(Yank.java:578) [bundleFile:?]
at org.knowm.yank.Yank.queryObjectArrays(Yank.java:560) [bundleFile:?]
at org.openhab.persistence.jdbc.db.JdbcBaseDAO.doGetHistItemFilterQuery(JdbcBaseDAO.java:340) [bundleFile:?]
at org.openhab.persistence.jdbc.internal.JdbcMapper.getHistItemFilterQuery(JdbcMapper.java:169) [bundleFile:?]
at org.openhab.persistence.jdbc.internal.JdbcPersistenceService.query(JdbcPersistenceService.java:205) [bundleFile:?]
at jdk.internal.reflect.GeneratedMethodAccessor152.invoke(Unknown Source) ~[?:?]
at org.openhab.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:154) [bundleFile:?]
at org.openhab.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
2021-08-17 09:02:41.969 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'QueryablePersistenceService.query()' on 'org.openhab.persistence.jdbc.internal.JdbcPersistenceService@ae651c': null
at org.openhab.persistence.jdbc.db.JdbcBaseDAO.doGetHistItemFilterQuery(JdbcBaseDAO.java:344) ~[?:?]
at org.openhab.persistence.jdbc.internal.JdbcMapper.getHistItemFilterQuery(JdbcMapper.java:169) ~[?:?]
at org.openhab.persistence.jdbc.internal.JdbcPersistenceService.query(JdbcPersistenceService.java:205) ~[?:?]
2021-08-17 09:02:41.976 [ERROR] [ence.internal.PersistenceManagerImpl] - Exception occurred while querying persistence service 'jdbc': null
2021-08-17 09:02:42.247 [INFO ] [nal.WeatherCalculatorEventSubscriber]
also with item004
if i look it up it belongs to this item “string_localDailyForecastTodayConditionIcon” and in the item file i see
Image string_localDailyForecastTodayConditionIcon "Aktuelle Vorhersage Icon" { channel="openweathermap:weather-and-forecast:api:smarthome:forecastToday#icon" }
how do i solve this error?
Many thanks @Kai for this.
I noticed that the release notes don’t mention any recent changes to the ZWave binding e.g. the PR that I recently made.
The release notes include everything that is correctly tagged on Github. In a few occasions (like this one), the maintainers forget doing so when merging a PR. But the change is nonetheless included!
There appears to be an issue with the release notes as it lists new bindings that were already listed for the previous milestone. Unless there was a change to compare changes against the last stable release?
You’re right, thanks for noticing. Not sure why they were added again, I have removed them from the new release notes now.
Also the (important) change in the Nuki binding is missing in the release notes.
I’m seeing some icon related issues on M2. In the Items list under Settings, if I scroll down, the icons become incorrectly associated. If I filter the items list, the icons stay as they were when first loaded, even though the items are updated as expected.
It also seems that previously, if you had set a category, the icon for that item would immediately show up. Now I have to save, close out of the item, and then it will show the new icon.
A quick question, which follows on from this topic.
- Is openHAB3 limited to Java 11, or can it run on Java 17?
I ask because Michal of DietPi is offering to add openHAB to the DietPi Software menu (alongside Home-Assistant)
(All contributions and assistance would be most welcomed)
Stuart
____ Update ____
Because I’m a gungho fool, I just updated a “fresh installation” of DietPi V7.5.2 to Debian Bullseye following these instructions.
It would seem that openHAB3 is trying to start, but crashes out after a few seconds.
root@openHAB2-C4:~# systemctl status openhab
● openhab.service - openHAB - empowering the smart home
Loaded: loaded (/usr/lib/systemd/system/openhab.service; enabled; vendor preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Fri 2021-09-10 12:12:44 BST; 4s ago
Docs: https://www.openhab.org/docs/
https://community.openhab.org
Process: 6566 ExecStart=/usr/share/openhab/runtime/bin/karaf ${OPENHAB_STARTMODE} (code=exited, status=255/EXCEPTION)
Main PID: 6566 (code=exited, status=255/EXCEPTION)
Active: active (running) since Fri 2021-09-10 12:12:49 BST; 3s ago
Main PID: 6730 (java)
Tasks: 22 (limit: 3844)
Memory: 53.7M
CGroup: /system.slice/openhab.service
└─6730 /usr/bin/java -XX:-UsePerfData -Dopenhab.home=/usr/share/openhab -Dopenhab.conf=/etc/openhab -Dopenhab.runtime=/usr/share/openhab/runtime -Dopenhab.userdata=/var/lib/openhab -Dopenhab.logdir=/var/log/openhab -Dfelix.c
m.dir=/var/lib/openhab/config -Djava.library.path=/var/lib/openhab/tmp/lib -Djetty.host=0.0.0.0 -Djetty.http.compliance=RFC2616 -Dnashorn.args=--no-deprecation-warning -Dorg.apache.cxf.osgi.http.transport.disable=true -Dorg.ops4j.pax.web
.listening.addresses=0.0.0.0 -Dorg.osgi.service.http.port=8080 -Dorg.osgi.service.http.port.secure=8443 -Djava.awt.headless=true --add-reads=java.xml=java.logging --add-exports=java.base/org.apache.karaf.specs.locator=java.xml,ALL-UNNAME
D --patch-module java.base=/usr/share/openhab/runtime/lib/endorsed/org.apache.karaf.specs.locator-4.3.2.jar --patch-module java.xml=/usr/share/openhab/runtime/lib/endorsed/org.apache.karaf.specs.java.xml-4.3.2.jar --add-opens java.base/j
ava.security=ALL-UNNAMED --add-opens java.base/java.net=ALL-UNNAMED --add-opens java.base/java.lang=ALL-UNNAMED --add-opens java.base/java.util=ALL-UNNAMED --add-opens java.naming/javax.naming.spi=ALL-UNNAMED --add-opens java.rmi/sun.rmi
.transport.tcp=ALL-UNNAMED --add-opens java.base/java.io=ALL-UNNAMED --add-opens java.base/java.lang.reflect=ALL-UNNAMED --add-opens java.base/java.text=ALL-UNNAMED --add-opens java.base/java.time=ALL-UNNAMED --add-opens java.desktop/jav
a.awt.font=ALL-UNNAMED --add-exports=java.base/sun.net.www.protocol.file=ALL-UNNAMED --add-exports=java.base/sun.net.www.protocol.ftp=ALL-UNNAMED --add-exports=java.base/sun.net.www.protocol.http=ALL-UNNAMED --add-exports=java.base/sun.n
et.www.protocol.https=ALL-UNNAMED --add-exports=java.base/sun.net.www.protocol.jar=ALL-UNNAMED --add-exports=java.base/sun.net.www.content.text=ALL-UNNAMED --add-exports=jdk.xml.dom/org.w3c.dom.html=ALL-UNNAMED --add-exports=jdk.naming.r
mi/com.sun.jndi.url.rmi=ALL-UNNAMED --add-exports java.security.sasl/com.sun.security.sasl=ALL-UNNAMED -Dkaraf.instances=/var/lib/openhab/tmp/instances -Dkaraf.home=/usr/share/openhab/runtime -Dkaraf.base=/var/lib/openhab -Dkaraf.data=/v
ar/lib/openhab -Dkaraf.etc=/var/lib/openhab/etc -Dkaraf.log=/var/log/openhab -Dkaraf.restart.jvm.supported=true -Djava.io.tmpdir=/var/lib/openhab/tmp -Djava.util.logging.config.file=/var/lib/openhab/etc/java.util.logging.properties -Dkar
af.startLocalConsole=false -Dkaraf.startRemoteShell=true -classpath /usr/share/openhab/runtime/lib/boot/org.apache.karaf.diagnostic.boot-4.3.2.jar:/usr/share/openhab/runtime/lib/boot/org.apache.karaf.jaas.boot-4.3.2.jar:/usr/share/openha
b/runtime/lib/boot/org.apache.karaf.main-4.3.2.jar:/usr/share/openhab/runtime/lib/boot/org.apache.karaf.specs.activator-4.3.2.jar:/usr/share/openhab/runtime/lib/boot/osgi.core-7.0.0.jar:/usr/share/openhab/runtime/lib/jdk9plus/istack-comm
ons-runtime-3.0.10.jar:/usr/share/openhab/runtime/lib/jdk9plus/jakarta.xml.bind-api-2.3.3.jar:/usr/share/openhab/runtime/lib/jdk9plus/javax.activation-1.2.0.jar:/usr/share/openhab/runtime/lib/jdk9plus/javax.annotation-api-1.3.1.jar:/usr/
share/openhab/runtime/lib/jdk9plus/jaxb-runtime-2.3.3.jar:/usr/share/openhab/runtime/lib/jdk9plus/txw2-2.3.3.jar org.apache.karaf.main.Main
Sep 10 12:12:49 openHAB2-C4 systemd[1]: Started openHAB - empowering the smart home.
Active: activating (auto-restart) (Result: exit-code) since Fri 2021-09-10 12:12:52 BST; 2s ago
Process: 6730 ExecStart=/usr/share/openhab/runtime/bin/karaf ${OPENHAB_STARTMODE} (code=exited, status=255/EXCEPTION)
Main PID: 6730 (code=exited, status=255/EXCEPTION)
Active: active (running) since Fri 2021-09-10 12:13:06 BST; 2s ago
Main PID: 7053 (java)
Tasks: 23 (limit: 3844)
Memory: 53.2M
└─7053 /usr/bin/java -XX:-UsePerfData -Dopenhab.home=/usr/share/openhab -Dopenhab.conf=/etc/openhab -Dopenhab.runtime=/usr/share/openhab/runtime -Dopenhab.userdata=/var/lib/openhab -Dopenhab.logdir=/var/log/openhab -Dfelix.c
Sep 10 12:13:06 openHAB2-C4 systemd[1]: Started openHAB - empowering the smart home.
Active: activating (auto-restart) (Result: exit-code) since Fri 2021-09-10 12:13:09 BST; 2s ago
Process: 7053 ExecStart=/usr/share/openhab/runtime/bin/karaf ${OPENHAB_STARTMODE} (code=exited, status=255/EXCEPTION)
Main PID: 7053 (code=exited, status=255/EXCEPTION)
Can anyone give any advice or suggestions?
Or do we say that openHAB3 must be run with Java 11?
Already answered in other topic, as it is off-topic here. Double posts are always a bad idea
Can you open a GitHub webUI issue if not already done please. Always handy to get issues raised and fixed when code is fresh in people’s minds as there were some changes made to the icon system in 3.2
I am wondering if this is related to M2 (the timing makes me suspect that it is)…
Hi actually i receive some messages, cloud someone explain what could cause this?
2021-09-30 16:20:07.870 [INFO ] [control.internal.WebSocketConnection] - Web Socket close 1005. Reason: null
2021-09-30 16:21:18.160 [INFO ] [control.internal.WebSocketConnection] - Web Socket close 1005. Reason: null
2021-09-30 16:22:28.272 [INFO ] [control.internal.WebSocketConnection] - Web Socket close 1005. Reason: null
2021-09-30 16:23:39.268 [INFO ] [control.internal.WebSocketConnection] - Web Socket close 1005. Reason: null
2021-09-30 16:24:49.716 [INFO ] [control.internal.WebSocketConnection] - Web Socket close 1005. Reason: null
Okay, the Messages came up after upgrade to M2.
But many thanks for your information.
Did rule reloading stop working on 3.2M2? I haven’t investigated further but downgrading to 3.2M1 fixed the problem.
By rule reloading I mean when you make changes to a rule file (in my case jruby, but it applies to jython / dsl I too I guess), openhab didn’t seem to reload / re-execute it.
