mstormi
(Markus Storm)
Split this topic
December 14, 2021, 3:19pm
86
12 posts were split to a new topic: Breaking changes in 3.2?
jimtng
(jimtng)
December 13, 2021, 10:46pm
97
Does anyone experience an issue with Google TTS in M5?
My google TTS has been working fine for months. The last issue was due to the google app profile not set to production, and I got that fixed back in February 2021 I think.
After upgrading to M5, Iām getting
org.openhab.core.voice.TTSException: Missing service configuration.
I have tried re-entering the Authorization Code in the main ui, but this didnāt help.
Downgrading to M4 made it work again. Also restarting Openhab (3.2M5) seems to fix it for a while.
mstormi
(Markus Storm)
Split this topic
December 15, 2021, 10:46am
98
A post was merged into an existing topic: Breaking changes in 3.2?
I am on 3.2.0.M5 and quickly tried it out with
and I can confirm that it still works well. So I would say it is not related to M5 then.
helmar74
(Helmar)
December 19, 2021, 9:21am
101
Hi, does anyone know, if 3.2.0 stable will be released tomorrow or if it is posponed according the karaf update:
https://community.openhab.org/t/openhab-3-2-milestone-builds/125096/6
Thanks in advance
mstormi
(Markus Storm)
Split this topic
December 19, 2021, 5:10pm
104
A post was split to a new topic: Warning in 3.2RC1
michaeljoos
(Michael Joos)
December 19, 2021, 4:15pm
105
Hi all
Did update to RC1 today and my f7-icons are not visible anymore. E.g.:
f7:arrow_down_right_square
Did also a quick check with material-icons. But this does also not work. No issues with OH-Icons.
Can someone else see this in RC1?
wborn
(Wouter Born)
December 19, 2021, 8:41pm
106
I think this is the same issue as this one:
opened 05:23PM - 18 Dec 21 UTC
closed 06:54PM - 18 Dec 21 UTC
bug
main ui
I'm still trying to track down this on my end, but i just pulled down the latest⦠build 3.2.0.202112181015 and none of my widgets that use `f7:...` or `material:...` are displaying. Interesting enough, loading system local images with `oh:...` does work. I also tested this on a version 3.2.0.202112122130 which i have running for development purposes, and the issue is not there, so either something is wrong with my main system, or this is a recent regression.
Please DO NOT ERASE this template, but fill in the details as requested. This will ensure your issue is properly filed and will be considered. Otherwise, we may reserve the right to close it without further action.
## The problem
Describe the issue you're having. In most cases it is appreciated to share screenshots or
even animated GIFs of your issue.
To make screenshots:
* On Windows: use Win+Shift+S
* On macOS: use Cmd+Shift+4
To make animated GIFs we recommend:
* On Windows: ShareX - https://getsharex.com/
* On macOS: Giphy Capture - https://giphy.com/apps/giphycapture
* On GNU/Linux: Peek - https://github.com/phw/peek
## Expected behavior
Describe what you expected to happen or how it should look/behave.
## Steps to reproduce
Provide accurate steps to reproduce the issue, including pastes of widget/page code if necessary.
1.
## Your environment
As an admin, in the main UI, choose *Help & About* on the left sidebar, expand *Technical information* and click on *View details*, then click *Copy* and paste the results here. You may omit information that is not pertinent to this issue if you feel it's divulging information you'd like not to share.
```yaml
## Browser console
Open the developer tools in your browser, go to the Console tab and paste errors and other messages that might be relevant to this issue.
You may also paste a screenshot if you prefer.
```txt
## Browser network traffic
Open the developer tools in your browser, go to the Network tab and paste
screenshots of the network traffic and the details of individual requests that failed.
## Additional information
Provide any information not pertinent to the above sections that you'd still like to share.
With final release 3.2.0 version icons are back again.
